| 12
 119
 120
 121
 122
 123
 124
 125
 126
 127
 128
 129
 130
 131
 132
 133
 134
 135
 136
 137
 138
 139
 140
 141
 142
 143
 144
 145
 146
 147
 148
 149
 150
 151
 152
 153
 154
 155
 156
 157
 158
 159
 160
 161
 162
 163
 164
 165
 166
 167
 168
 169
 170
 171
 172
 173
 174
/*                     cube.c                           */
/* Affiche a l'ecran un cube en 3D                      */
/* inclusion des fichiers d'en-tete Glut */
#include <GL/gl.h>
#include <GL/glu.h>
#include <GL/glut.h>
/* Notre structure point */
typedef struct
  float x;
  float y;
  float z;
  float r;
  float g;
  float b;
} point;
point p[8]={
    {-0.5,-0.5, 0.5,1.0,0.0,0.0},
    {-0.5, 0.5, 0.5,0.0,1.0,0.0},
    { 0.5, 0.5, 0.5,0.0,0.0,1.0},
    { 0.5,-0.5, 0.5,1.0,1.0,1.0},
    {-0.5,-0.5,-0.5,1.0,0.0,0.0},
    {-0.5, 0.5,-0.5,0.0,1.0,0.0},
    { 0.5, 0.5,-0.5,0.0,0.0,1.0},
    { 0.5,-0.5,-0.5,1.0,1.0,1.0}};
int f[6][4]={
  {0,1,2,3},
  {3,2,6,7},
  {4,5,6,7},
  {0,1,5,4},
  {1,5,6,2},
  {0,4,7,3}};
char presse;
int anglex,angley,x,y,xold,yold;
/* Prototype des fonctions */
void affichage();
void clavier(unsigned char touche,int x,int y);
void reshape(int x,int y);
void idle();
void mouse(int bouton,int etat,int x,int y);
void mousemotion(int x,int y);
int main(int argc,char **argv)
  /* initialisation de glut et creation
     de la fenetre */
  glutInit(&argc,argv);
  glutInitDisplayMode(GLUT_RGB | GLUT_DOUBLE | GLUT_DEPTH);
  glutInitWindowPosition(200,200);
  glutInitWindowSize(250,250);
  glutCreateWindow("cube");
  /* Initialisation d'OpenGL */
  glClearColor(0.0,0.0,0.0,0.0);
  glColor3f(1.0,1.0,1.0);
  glPointSize(2.0);
  glEnable(GL_DEPTH_TEST);
  /* enregistrement des fonctions de rappel */
  glutDisplayFunc(affichage);
  glutKeyboardFunc(clavier);
  glutReshapeFunc(reshape);
  glutMouseFunc(mouse);
  glutMotionFunc(mousemotion);
  /* Entree dans la boucle principale glut */
  glutMainLoop();
  return 0;
void affichage()
  int i,j;
  /* effacement de l'image avec la couleur de fond */
  glLoadIdentity();
  glRotatef(-angley,1.0,0.0,0.0);
  glRotatef(-anglex,0.0,1.0,0.0);
  /* Dessin du cube */
  for (i=0;i<6;i++)
      glBegin(GL_POLYGON);
      for (j=0;j<4;j++)
	  glColor3f(p[f[i][j]].r,p[f[i][j]].g,p[f[i][j]].b);
	  glVertex3f(p[f[i][j]].x,p[f[i][j]].y,p[f[i][j]].z);
      glEnd();
  glFlush();
  /* On echange les buffers */
  glutSwapBuffers();
  switch (touche)
    case 'p': /* affichage du carre plein */
      glPolygonMode(GL_FRONT_AND_BACK,GL_FILL);
      glutPostRedisplay();
      break;
    case 'f': /* affichage en mode fil de fer */
      glPolygonMode(GL_FRONT_AND_BACK,GL_LINE);
      break;
    case 's' : /* Affichage en mode sommets seuls */
      glPolygonMode(GL_FRONT_AND_BACK,GL_POINT);
      break;
    case 'd':
      break;
    case 'D':
      glDisable(GL_DEPTH_TEST);
      break;
    case 'q' : /*la touche 'q' permet de quitter le programme */
      exit(0);
  if (x<y)
    glViewport(0,(y-x)/2,x,x);
  else
    glViewport((x-y)/2,0,y,y);
void mouse(int button, int state,int x,int y)
  /* si on appuie sur le bouton gauche */
  if (button == GLUT_LEFT_BUTTON && state == GLUT_DOWN)
    presse = 1; /* le booleen presse passe a 1 (vrai) */
    xold = x; /* on sauvegarde la position de la souris */
    yold=y;
  /* si on relache le bouton gauche */
  if (button == GLUT_LEFT_BUTTON && state == GLUT_UP)
    presse=0; /* le booleen presse passe a 0 (faux) */
    if (presse) /* si le bouton gauche est presse */
      /* on modifie les angles de rotation de l'objet
	 en fonction de la position actuelle de la souris et de la derniere
	 position sauvegardee */
      anglex=anglex+(x-xold);
      angley=angley+(y-yold);
      glutPostRedisplay(); /* on demande un rafraichissement de l'affichage */
    xold=x; /* sauvegarde des valeurs courante de le position de la souris */
    yold=y;
