Importer fichier csv
    Mars 2019
    Secteur : Santé
    Par défaut Importer fichier csv
    Actuellement sur un cours OCR, je n'arrive pas à importer de fichier Csv afin d'analyser des données
    C'est comme si le fichier n'existait pas :
    FileNotFoundError                         Traceback (most recent call last)
    <ipython-input-14-36785e2f71ba> in <module>()
    ----> 1data = pd.read_csv("operations.csv")
    ~\Anaconda3\lib\site-packages\pandas\io\parsers.py in parser_f(filepath_or_buffer, sep, delimiter, header, names, index_col, usecols, squeeze, prefix, mangle_dupe_cols, dtype, engine, converters, true_values, false_values, skipinitialspace, skiprows, nrows, na_values, keep_default_na, na_filter, verbose, skip_blank_lines, parse_dates, infer_datetime_format, keep_date_col, date_parser, dayfirst, iterator, chunksize, compression, thousands, decimal, lineterminator, quotechar, quoting, escapechar, comment, encoding, dialect, tupleize_cols, error_bad_lines, warn_bad_lines, skipfooter, doublequote, delim_whitespace, low_memory, memory_map, float_precision)
        676                     skip_blank_lines=skip_blank_lines)
        677
    --> 678return _read(filepath_or_buffer, kwds)
        679
        680     parser_f.__name__ = name
    ~\Anaconda3\lib\site-packages\pandas\io\parsers.py in _read(filepath_or_buffer, kwds)
        438
        439# Create the parser.
    --> 440parser = TextFileReader(filepath_or_buffer,**kwds)
        441
        442if chunksize or iterator:
    ~\Anaconda3\lib\site-packages\pandas\io\parsers.py in __init__(self, f, engine, **kwds)
        785             self.options['has_index_names']= kwds['has_index_names']
        786
    --> 787self._make_engine(self.engine)
        788
        789def close(self):
    ~\Anaconda3\lib\site-packages\pandas\io\parsers.py in _make_engine(self, engine)
       1012def _make_engine(self, engine='c'):
       1013if engine =='c':
    -> 1014self._engine = CParserWrapper(self.f,**self.options)
       1015else:
       1016if engine =='python':
    ~\Anaconda3\lib\site-packages\pandas\io\parsers.py in __init__(self, src, **kwds)
       1706         kwds['usecols']= self.usecols
       1707
    -> 1708self._reader = parsers.TextReader(src,**kwds)
       1709
       1710         passed_names = self.names isNone
    pandas\_libs\parsers.pyx in pandas._libs.parsers.TextReader.__cinit__()
    pandas\_libs\parsers.pyx in pandas._libs.parsers.TextReader._setup_parser_source()
    FileNotFoundError: File b'operations.csv' does not exist
    Une personne pour m'aider ?
    Avatar de fred1599
    Lead Dev Python
    Juillet 2006
    Activité : Lead Dev Python
    Secteur : Arts - Culture
    ​Bonjour,
    operations.csv
    est-il dans le même répertoire que le fichier python que vous exécutez ?
    Mars 2019
    Secteur : Santé
    Bonjour Fred, merci pour votre réponse
    Vous voulez dire dans le même répertoire .zip ? : oui
    Avatar de fred1599
    Lead Dev Python
    Juillet 2006
    Répertoire zip ? Non, zip est une archive, pas un répertoire !
    Je répète donc ma question précédente, en souhaitant que avant de me donner une réponse, vous vous soyez renseigné sur la différence entre fichier, répertoire et archive...
    Car là, avec le message d'erreur, on peut croire que le fichier csv n'est tout simplement pas dans le même répertoire que le fichier python que vous exécutez.
    Architecte technique retraité
    Juin 2008
    Exécuter pd.read_csv("operations.csv") (depuis la console IPython) suppose que le fichier est dans le répertoire de travail courant (current working directory)... sinon vous devez précisez le chemin absolu ou relatif pour l'atteindre depuis celui ci.
    Si ces notions vous sont complétement étrangères, ouvrez un tuto.. Pas sûr que vous compreniez tout du premier coup mais au moins vous auriez quelques notions de base.
    W
    Architectures post-modernes.
  1. Import fichier CSV
    Par oki972 dans le forum SQLite
    Dernier message: 08/10/2007, 20h58
  2. [Pb Importation fichier CSV]
    Par Jeremie_Vi dans le forum Access
    Dernier message: 04/05/2007, 06h54
  3. Importation fichier CSV Excel
    Par @lex(is) dans le forum Macros et VBA Excel
    Dernier message: 22/06/2006, 02h16
  4. Update de plusieurs tables, import fichier csv sql loader
    Par fusuke dans le forum SQL*Loader
    Dernier message: 18/05/2006, 15h08
  5. Réponses: 9
    Dernier message: 31/01/2006, 22h42
