Probléme de transparence dans le code.
    Juillet 2006
    Par défaut Probléme de transparence dans le code.
    Sa fait trois heures que je chipote sur ce code et j'arrive pas à trouvé le noeud du probléme.
    Dans mon module on trouve:
    Option Explicit
    'Déclaration des fonctions de l'API Windows nécessaires a ce programme
    Public Declare Function SetLayeredWindowAttributes Lib "user32.dll" (ByVal hwnd As Long, ByVal crKey As Long, ByVal bAlpha As Byte, ByVal dwFlags As Long) As Long
    Public Declare Function SetWindowLong Lib "user32" Alias "SetWindowLongA" (ByVal hwnd As Long, ByVal nIndex As Long, ByVal dwNewLong As Long) As Long
    Public Declare Function GetWindowLong Lib "user32" Alias "GetWindowLongA" (ByVal hwnd As Long, ByVal nIndex As Long) As Long
    Public Declare Function GetWindowRect Lib "user32" (ByVal hwnd As Long, lpRect As Rect) As Long
    Public Declare Function SetParent Lib "user32" (ByVal hWndChild As Long, ByVal hWndNewParent As Long) As Long
    Public Declare Function GetParent Lib "user32" (ByVal hwnd As Long) As Long
    Public Declare Function SetWindowPos Lib "user32" (ByVal hwnd As Long, ByVal hWndInsertAfter As Long, ByVal X As Long, ByVal Y As Long, ByVal cx As Long, ByVal cy As Long, ByVal wFlags As Long) As Long
    Public Const WS_CHILD = &H40000000
    Public Const GWL_STYLE = (-16)
    Public Const GWL_EXSTYLE = (-20)
    Public Const LWA_COLORKEY = &H1
    Public Const LWA_ALPHA = &H2
    Public Const WS_EX_LAYERED = &H80000
    Public Const SWP_FRAMECHANGED = &H20
    Public Function WndSetOpacity(ByVal hwnd As Long, Optional ByVal crKey As Long = &H8000000F, Optional ByVal Alpha As Byte = 255, Optional ByVal ByAlpha As Boolean = False) As Boolean
        Dim ExStyle As Long
        ExStyle = GetWindowLong(MainApp.hwnd, GWL_EXSTYLE)
        If ExStyle <> (ExStyle Or WS_EX_LAYERED) Then
            ExStyle = (ExStyle Or WS_EX_LAYERED)
            Call SetWindowLong(MainApp.hwnd, GWL_EXSTYLE, ExStyle)
        End If
        WndSetOpacity = (SetLayeredWindowAttributes(MainApp.hwnd, &H8000000F, 100, IIf(ByAlpha, LWA_ALPHA, LWA_COLORKEY)) <> 0)
    End Function
    Je remplace la valeur crKey par une couleur, je passe ByAlpha en False, Malgré ça il met toute ma FORM en transparence. Ce que je désire c'est seulement la couleur que j'ai défenie.
    Merci à vous tous.
    Avatar de ThierryAIM
    Septembre 2002
    il nous manque l'appel à WndSetOpacity dans le code fourni
    et
    Dim ExStyle As Long
    End If
    End Function
    Tu dois utiliser le hwnd transmis à la fonction
    Ce qui est en rouge est en trop
    Membre émérite Avatar de avigeilpro
    Ambulancier
    Janvier 2004
    Activité : Ambulancier
    Secteur : Transports
    Sinon sur mon site tu trouve un module tout près, juste à intégrer dans ton projet et à appeler la fonction avec les bons paramètres (regarde mon profil pour avoir l'adresse de mon site)
    La connaissance seule ne suffit pas. La vraie compréhension vient de la mise en expérience.
    Règles|FAQ|Tuto
  1. Problème d'asm dans mon code C
    Par Truffo dans le forum C
    Dernier message: 11/06/2007, 15h44
  2. Problème try-catch dans mon code
    Par little pepito dans le forum Langage
    Dernier message: 11/06/2007, 13h22
  3. Réponses: 16
    Dernier message: 18/10/2006, 23h52
  4. Problème de paramètres dans mon code javascript
    Par cocacollection dans le forum Général JavaScript
    Dernier message: 15/03/2006, 11h53
  5. Problème avec Between dans un code
    Par Sendo dans le forum Access
    Dernier message: 02/10/2005, 19h44
