Problème de mapping
Servlets/JSP Java
    Janvier 2016
    Par défaut Problème de mapping
    Quand je vais un run as serveur sur mon projet web dynamic project il me dit cela :
    Exception Description: The mapping [commande] from the embedded ID class [class model.LigneDeCommandePK] is an invalid mapping for this class. An embeddable class that is used with an embedded ID specification (attribute [id] from the source [class model.LigneDeCommande]) can only contain basic mappings. Either remove the non basic mapping or change the embedded ID specification on the source to be embedded.
    Voici la classe LigneDeCommande
    package model;
    import java.io.Serializable;
    import javax.persistence.*;
     * The persistent class for the ligne_de_commande database table.
    @Entity
    @Table(name="ligne_de_commande")
    @NamedQuery(name="LigneDeCommande.findAll", query="SELECT l FROM LigneDeCommande l")
    public class LigneDeCommande implements Serializable {
    	private static final long serialVersionUID = 1L;
    	@EmbeddedId
    	private LigneDeCommandePK id;
    	private int quantite;
    	//bi-directional many-to-one association to Commande
    	@ManyToOne
    	@JoinColumn(name="commande")
    	private Commande commandeBean;
    	//bi-directional many-to-one association to Livre
    	@ManyToOne
    	@JoinColumn(name="livre")
    	private Livre livreBean;
    	public LigneDeCommande() {
    	public LigneDeCommandePK getId() {
    		return this.id;
    	public void setId(LigneDeCommandePK id) {
    		this.id = id;
    	public int getQuantite() {
    		return this.quantite;
    	public void setQuantite(int quantite) {
    		this.quantite = quantite;
    	public Commande getCommandeBean() {
    		return this.commandeBean;
    	public void setCommandeBean(Commande commandeBean) {
    		this.commandeBean = commandeBean;
    	public Livre getLivreBean() {
    		return this.livreBean;
    	public void setLivreBean(Livre livreBean) {
    		this.livreBean = livreBean;
    voici la classe LigneDeCommandePK :
    package model;
     * The primary key class for the ligne_de_commande database table.
    @Embeddable
    public class LigneDeCommandePK implements Serializable {
    	//default serial version id, required for serializable classes.
    	@Column(insertable=false, updatable=false)
    	private Livre livre;
    	private Commande commande;
    	public LigneDeCommandePK() {
    	public Livre getLivre() {
    		return this.livre;
    	public void setLivre(Livre livre) {
    		this.livre = livre;
    	public Commande getCommande() {
    		return this.commande;
    	public void setCommande(Commande commande) {
    		this.commande = commande;
    	public boolean equals(Object other) {
    		if (this == other) {
    			return true;
    		if (!(other instanceof LigneDeCommandePK)) {
    			return false;
    		LigneDeCommandePK castOther = (LigneDeCommandePK)other;
    		return
    			(this.livre == castOther.livre)
    			&& (this.commande == castOther.commande);
    	/*public int hashCode() {
    		final int prime = 31;
    		int hash = 17;
    		hash = hash * prime + this.livre;
    		hash = hash * prime + this.commande;
    		return hash;
    voici la classe Commande :
    package model;
    import java.util.Date;
    import java.util.List;
     * The persistent class for the commande database table.
    @Entity
    @NamedQuery(name="Commande.findAll", query="SELECT c FROM Commande c")
    public class Commande implements Serializable {
    	@Id
    	private int id;
    	@Temporal(TemporalType.DATE)
    	@Column(name="date_commande")
    	private Date dateCommande;
    	@Column(name="total_commande")
    	private double totalCommande;
    	//bi-directional many-to-one association to Client
    	@ManyToOne
    	@JoinColumn(name="client")
    	private Client clientBean;
    	//bi-directional many-to-one association to LigneDeCommande
    	@OneToMany(mappedBy="commandeBean")
    	private List<LigneDeCommande> ligneDeCommandes;
    	public Commande() {
    	public int getId() {
    		return this.id;
    	public void setId(int id) {
    		this.id = id;
    	public Date getDateCommande() {
    		return this.dateCommande;
    	public void setDateCommande(Date dateCommande) {
    		this.dateCommande = dateCommande;
    	public double getTotalCommande() {
    		return this.totalCommande;
    	public void setTotalCommande(double totalCommande) {
    		this.totalCommande = totalCommande;
    	public Client getClientBean() {
    		return this.clientBean;
    	public void setClientBean(Client clientBean) {
    		this.clientBean = clientBean;
    	public List<LigneDeCommande> getLigneDeCommandes() {
    		return this.ligneDeCommandes;
    	public void setLigneDeCommandes(List<LigneDeCommande> ligneDeCommandes) {
    		this.ligneDeCommandes = ligneDeCommandes;
    	public LigneDeCommande addLigneDeCommande(LigneDeCommande ligneDeCommande) {
    		getLigneDeCommandes().add(ligneDeCommande);
    		ligneDeCommande.setCommandeBean(this);
    		return ligneDeCommande;
    	public LigneDeCommande removeLigneDeCommande(LigneDeCommande ligneDeCommande) {
    		getLigneDeCommandes().remove(ligneDeCommande);
    		ligneDeCommande.setCommandeBean(null);
    voici la classe livre :
    119
    120
    121
    122
    123
    124
    125
    126
    127
    128
    129
    130
    131
    132
    133
    134
    135
    136
    137
    138
    139
    140
    141
    142
    143
    144
    145
    146
    147
    148
    149
    150
    151
    152
    153
    154
    155
    156
    157
    158
    159
    160
    161
    162
    163
    164
    165
    166
    167
    168
    169
    170
    171
    172
    173
    174
    175
    176
    177
    178
    179
    180
    181
    182
    183
    184
    185
    186
    187
    188
    189
    190
    191
    192
    193
    194
    195
    196
    197
    198
    199
    200
    201
    202
    203
    204
    205
    206
    207
    208
    209
    210
    211
    212
    213
    214
    215
    216
    217
    218
    219
    220
    221
    222
    223
    224
    225
    226
    227
    228
    229
    230
    231
    232
    233
    234
    235
    236
    237
    238
    239
    240
    241
    242
    243
    244
    245
    246
    247
    248
    249
    250
    251
    252
    253
    254
    255
    package model;
     * The persistent class for the livre database table.
    @Entity
    @NamedQueries ({
    	@NamedQuery(name="Livre.findAll", query="SELECT l FROM Livre l")
    public class Livre implements Serializable {
    	@Id
    	private int id;
    	@Column(name="annee_parution")
    	private int anneeParution;
    	@Lob
    	private String description;
    	private int ecrivain;
    	private String image;
    	private String isbn;
    	private String langue;
    	@Column(name="prix_neuf")
    	private double prixNeuf;
    	@Column(name="prix_numerique")
    	private double prixNumerique;
    	@Column(name="prix_occasion_physique")
    	private double prixOccasionPhysique;
    	@Column(name="sujet_livre")
    	private String sujetLivre;
    	private boolean telechargement;
    	private String titre;
    	//bi-directional many-to-many association to Auteur
    	@ManyToMany(mappedBy="livres")
    	private List<Auteur> auteurs;
    	@OneToMany(mappedBy="livreBean")
    	//bi-directional many-to-one association to Editeur
    	@ManyToOne
    	@JoinColumn(name="editeur")
    	private Editeur editeurBean;
    	//bi-directional many-to-one association to Genre
    	@ManyToOne
    	@JoinColumn(name="genre")
    	private Genre genreBean;
    	//bi-directional many-to-many association to FormatLivre
    	@ManyToMany
    	@JoinTable(
    		name="support"
    		, joinColumns={
    		, inverseJoinColumns={
    			@JoinColumn(name="format_livre")
    	private List<FormatLivre> formatLivres;
    	public Livre() {
    		return this.id;
    		this.id = id;
    	public int getAnneeParution() {
    		return this.anneeParution;
    	public void setAnneeParution(int anneeParution) {
    		this.anneeParution = anneeParution;
    	public String getDescription() {
    		return this.description;
    	public void setDescription(String description) {
    		this.description = description;
    	public int getEcrivain() {
    		return this.ecrivain;
    	public void setEcrivain(int ecrivain) {
    		this.ecrivain = ecrivain;
    	public String getImage() {
    		return this.image;
    	public void setImage(String image) {
    		this.image = image;
    	public String getIsbn() {
    		return this.isbn;
    	public void setIsbn(String isbn) {
    		this.isbn = isbn;
    	public String getLangue() {
    		return this.langue;
    	public void setLangue(String langue) {
    		this.langue = langue;
    	public double getPrixNeuf() {
    		return this.prixNeuf;
    	public void setPrixNeuf(double prixNeuf) {
    		this.prixNeuf = prixNeuf;
    	public double getPrixNumerique() {
    		return this.prixNumerique;
    	public void setPrixNumerique(double prixNumerique) {
    		this.prixNumerique = prixNumerique;
    	public double getPrixOccasionPhysique() {
    		return this.prixOccasionPhysique;
    	public void setPrixOccasionPhysique(double prixOccasionPhysique) {
    		this.prixOccasionPhysique = prixOccasionPhysique;
    	public String getSujetLivre() {
    		return this.sujetLivre;
    	public void setSujetLivre(String sujetLivre) {
    		this.sujetLivre = sujetLivre;
    	public boolean getTelechargement() {
    		return this.telechargement;
    	public void setTelechargement(boolean telechargement) {
    		this.telechargement = telechargement;
    	public String getTitre() {
    		return this.titre;
    	public void setTitre(String titre) {
    		this.titre = titre;
    	public List<Auteur> getAuteurs() {
    		return this.auteurs;
    	public void setAuteurs(List<Auteur> auteurs) {
    		this.auteurs = auteurs;
    		ligneDeCommande.setLivreBean(this);
    		ligneDeCommande.setLivreBean(null);
    	public Editeur getEditeurBean() {
    		return this.editeurBean;
    	public void setEditeurBean(Editeur editeurBean) {
    		this.editeurBean = editeurBean;
    	public Genre getGenreBean() {
    		return this.genreBean;
    	public void setGenreBean(Genre genreBean) {
    		this.genreBean = genreBean;
    	public List<FormatLivre> getFormatLivres() {
    		return this.formatLivres;
    	public void setFormatLivres(List<FormatLivre> formatLivres) {
    		this.formatLivres = formatLivres;
    Voilà donc ci-avant les classe qui concerne la table ligne_de_commande contenant les composites livre avec commande et un champs normal quantité avec les tables Livre et Commande en relation avec celle-ci.
    Petit coup de pouce svp...
    Janvier 2016
    Si ça peux aider quelqu'un voici l'erreur complète :
    119
    120
    121
    122
    123
    124
    125
    126
    127
    128
    129
    130
    131
    132
    133
    134
    135
    136
    137
    138
    139
    140
    141
    142
    143
    144
    145
    146
    147
    148
    149
    150
    151
    152
    153
    154
    155
    156
    157
    158
    159
    160
    161
    162
    163
    164
    165
    166
    167
    168
    169
    170
    171
    172
    173
    174
    175
    176
    177
    178
    179
    180
    181
    182
    183
    184
    185
    186
    187
    188
    189
    190
    191
    192
    193
    194
    195
    196
    197
    198
    199
    200
    201
    202
    203
    204
    205
    206
    207
    208
    209
    210
    211
    212
    213
    214
    215
    216
    217
    218
    219
    220
    221
    222
    223
    224
    225
    226
    227
    228
    229
    230
    231
    232
    233
    234
    235
    236
    237
    238
    239
    240
    241
    242
    243
    2016-02-24T10:18:08.353+0100|Infos: visiting unvisited references
    2016-02-24T10:18:08.833+0100|Infos: Java security manager is disabled.
    2016-02-24T10:18:08.833+0100|Infos: Entering Security Startup Service.
    2016-02-24T10:18:08.836+0100|Infos: Loading policy provider com.sun.enterprise.security.provider.PolicyWrapper.
    2016-02-24T10:18:08.856+0100|Infos: Security Service(s) started successfully.
    2016-02-24T10:18:09.014+0100|Infos: Created HTTP listener http-listener-1 on host/port 0.0.0.0:8080
    2016-02-24T10:18:09.018+0100|Infos: Created HTTP listener http-listener-2 on host/port 0.0.0.0:8181
    2016-02-24T10:18:09.019+0100|Infos: Created HTTP listener admin-listener on host/port 0.0.0.0:4848
    2016-02-24T10:18:09.032+0100|Infos: Created virtual server server
    2016-02-24T10:18:09.033+0100|Infos: Created virtual server __asadmin
    2016-02-24T10:18:09.208+0100|Infos: Setting JAAS app name glassfish-web
    2016-02-24T10:18:09.209+0100|Infos: Virtual server server loaded default web module
    2016-02-24T10:18:09.800+0100|Infos: visiting unvisited references
    2016-02-24T10:18:09.903+0100|Infos: visiting unvisited references
    2016-02-24T10:18:09.914+0100|Infos: visiting unvisited references
    2016-02-24T10:18:10.546+0100|Grave: Exception while invoking class org.glassfish.persistence.jpa.JPADeployer prepare method
    2016-02-24T10:18:10.559+0100|Grave: javax.persistence.PersistenceException: Exception [EclipseLink-28018] (Eclipse Persistence Services - 2.6.1.v20150605-31e8258): org.eclipse.persistence.exceptions.EntityManagerSetupException
    Exception Description: Predeployment of PersistenceUnit [livrokaz] failed.
    Internal Exception: Exception [EclipseLink-7298] (Eclipse Persistence Services - 2.6.1.v20150605-31e8258): org.eclipse.persistence.exceptions.ValidationException
    	at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.createPredeployFailedPersistenceException(EntityManagerSetupImpl.java:2030)
    	at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.predeploy(EntityManagerSetupImpl.java:2021)
    	at org.eclipse.persistence.jpa.PersistenceProvider.createContainerEntityManagerFactoryImpl(PersistenceProvider.java:347)
    	at org.eclipse.persistence.jpa.PersistenceProvider.createContainerEntityManagerFactory(PersistenceProvider.java:313)
    	at org.glassfish.persistence.jpa.PersistenceUnitLoader.loadPU(PersistenceUnitLoader.java:199)
    	at org.glassfish.persistence.jpa.PersistenceUnitLoader.<init>(PersistenceUnitLoader.java:107)
    	at org.glassfish.persistence.jpa.JPADeployer$1.visitPUD(JPADeployer.java:223)
    	at org.glassfish.persistence.jpa.JPADeployer$PersistenceUnitDescriptorIterator.iteratePUDs(JPADeployer.java:510)
    	at org.glassfish.persistence.jpa.JPADeployer.createEMFs(JPADeployer.java:230)
    	at org.glassfish.persistence.jpa.JPADeployer.prepare(JPADeployer.java:168)
    	at com.sun.enterprise.v3.server.ApplicationLifecycle.prepareModule(ApplicationLifecycle.java:925)
    	at com.sun.enterprise.v3.server.ApplicationLifecycle.deploy(ApplicationLifecycle.java:434)
    	at com.sun.enterprise.v3.server.ApplicationLifecycle.deploy(ApplicationLifecycle.java:219)
    	at org.glassfish.deployment.admin.DeployCommand.execute(DeployCommand.java:491)
    	at com.sun.enterprise.v3.admin.CommandRunnerImpl$2$1.run(CommandRunnerImpl.java:539)
    	at com.sun.enterprise.v3.admin.CommandRunnerImpl$2$1.run(CommandRunnerImpl.java:535)
    	at java.security.AccessController.doPrivileged(Native Method)
    	at javax.security.auth.Subject.doAs(Subject.java:360)
    	at com.sun.enterprise.v3.admin.CommandRunnerImpl$2.execute(CommandRunnerImpl.java:534)
    	at com.sun.enterprise.v3.admin.CommandRunnerImpl$3.run(CommandRunnerImpl.java:565)
    	at com.sun.enterprise.v3.admin.CommandRunnerImpl$3.run(CommandRunnerImpl.java:557)
    	at com.sun.enterprise.v3.admin.CommandRunnerImpl.doCommand(CommandRunnerImpl.java:556)
    	at com.sun.enterprise.v3.admin.CommandRunnerImpl.doCommand(CommandRunnerImpl.java:1464)
    	at com.sun.enterprise.v3.admin.CommandRunnerImpl.access$1300(CommandRunnerImpl.java:109)
    	at com.sun.enterprise.v3.admin.CommandRunnerImpl$ExecutionContext.execute(CommandRunnerImpl.java:1846)
    	at com.sun.enterprise.v3.admin.CommandRunnerImpl$ExecutionContext.execute(CommandRunnerImpl.java:1722)
    	at com.sun.enterprise.v3.admin.AdminAdapter.doCommand(AdminAdapter.java:534)
    	at com.sun.enterprise.v3.admin.AdminAdapter.onMissingResource(AdminAdapter.java:224)
    	at org.glassfish.grizzly.http.server.StaticHttpHandlerBase.service(StaticHttpHandlerBase.java:189)
    	at com.sun.enterprise.v3.services.impl.ContainerMapper$HttpHandlerCallable.call(ContainerMapper.java:459)
    	at com.sun.enterprise.v3.services.impl.ContainerMapper.service(ContainerMapper.java:167)
    	at org.glassfish.grizzly.http.server.HttpHandler.runService(HttpHandler.java:206)
    	at org.glassfish.grizzly.http.server.HttpHandler.doHandle(HttpHandler.java:180)
    	at org.glassfish.grizzly.http.server.HttpServerFilter.handleRead(HttpServerFilter.java:235)
    	at org.glassfish.grizzly.filterchain.ExecutorResolver$9.execute(ExecutorResolver.java:119)
    	at org.glassfish.grizzly.filterchain.DefaultFilterChain.executeFilter(DefaultFilterChain.java:283)
    	at org.glassfish.grizzly.filterchain.DefaultFilterChain.executeChainPart(DefaultFilterChain.java:200)
    	at org.glassfish.grizzly.filterchain.DefaultFilterChain.execute(DefaultFilterChain.java:132)
    	at org.glassfish.grizzly.filterchain.DefaultFilterChain.process(DefaultFilterChain.java:111)
    	at org.glassfish.grizzly.ProcessorExecutor.execute(ProcessorExecutor.java:77)
    	at org.glassfish.grizzly.nio.transport.TCPNIOTransport.fireIOEvent(TCPNIOTransport.java:536)
    	at org.glassfish.grizzly.strategies.AbstractIOStrategy.fireIOEvent(AbstractIOStrategy.java:112)
    	at org.glassfish.grizzly.strategies.WorkerThreadIOStrategy.run0(WorkerThreadIOStrategy.java:117)
    	at org.glassfish.grizzly.strategies.WorkerThreadIOStrategy.access$100(WorkerThreadIOStrategy.java:56)
    	at org.glassfish.grizzly.strategies.WorkerThreadIOStrategy$WorkerThreadRunnable.run(WorkerThreadIOStrategy.java:137)
    	at org.glassfish.grizzly.threadpool.AbstractThreadPool$Worker.doWork(AbstractThreadPool.java:591)
    	at org.glassfish.grizzly.threadpool.AbstractThreadPool$Worker.run(AbstractThreadPool.java:571)
    	at java.lang.Thread.run(Thread.java:745)
    Caused by: Exception [EclipseLink-28018] (Eclipse Persistence Services - 2.6.1.v20150605-31e8258): org.eclipse.persistence.exceptions.EntityManagerSetupException
    	at org.eclipse.persistence.exceptions.EntityManagerSetupException.predeployFailed(EntityManagerSetupException.java:231)
    	... 50 more
    Caused by: Exception [EclipseLink-7298] (Eclipse Persistence Services - 2.6.1.v20150605-31e8258): org.eclipse.persistence.exceptions.ValidationException
    	at org.eclipse.persistence.exceptions.ValidationException.invalidMappingForEmbeddedId(ValidationException.java:1310)
    	at org.eclipse.persistence.internal.jpa.metadata.accessors.mappings.EmbeddedIdAccessor.addIdFieldsFromAccessors(EmbeddedIdAccessor.java:148)
    	at org.eclipse.persistence.internal.jpa.metadata.accessors.mappings.EmbeddedIdAccessor.process(EmbeddedIdAccessor.java:186)
    	at org.eclipse.persistence.internal.jpa.metadata.MetadataDescriptor.processMappingAccessors(MetadataDescriptor.java:1526)
    	at org.eclipse.persistence.internal.jpa.metadata.accessors.classes.ClassAccessor.processMappingAccessors(ClassAccessor.java:1648)
    	at org.eclipse.persistence.internal.jpa.metadata.accessors.classes.EntityAccessor.processMappingAccessors(EntityAccessor.java:1240)
    	at org.eclipse.persistence.internal.jpa.metadata.accessors.classes.EntityAccessor.process(EntityAccessor.java:699)
    	at org.eclipse.persistence.internal.jpa.metadata.MetadataProject.processStage2(MetadataProject.java:1808)
    	at org.eclipse.persistence.internal.jpa.metadata.MetadataProcessor.processORMMetadata(MetadataProcessor.java:573)
    	at org.eclipse.persistence.internal.jpa.deployment.PersistenceUnitProcessor.processORMetadata(Persistenc
    2016-02-24T10:18:10.559+0100|Grave: eUnitProcessor.java:604)
    	at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.predeploy(EntityManagerSetupImpl.java:1943)
    	... 48 more
    2016-02-24T10:18:10.560+0100|Grave: Exception while preparing the app
    2016-02-24T10:18:10.560+0100|Grave: Exception during lifecycle processing
    	... 50 more
    	at org.eclipse.persistence.internal.jpa.deployment.PersistenceUnitProcessor.processORMetadata(PersistenceUnitProcessor.java:604)
    	... 48 more
    2016-02-24T10:18:10.650+0100|Grave: Exception while preparing the app : Exception [EclipseLink-28018] (Eclipse Persistence Services - 2.6.1.v20150605-31e8258): org.eclipse.persistence.exceptions.EntityManagerSetupException
    Local Exception Stack:
    	... 48 more
    Merci encore
  1. [IBATIS/mysql] problème de mapping
    Par iftolotfi dans le forum Persistance des données
    Dernier message: 07/07/2006, 10h40
  2. [Débutant] Problème de mapping des ports
    Par zehle dans le forum VHDL
    Dernier message: 22/05/2006, 22h37
  3. [PERL] Problème avec map
    Par LE NEINDRE dans le forum Langage
    Dernier message: 05/10/2005, 09h48
  4. [CASTOR]Problème de mapping de données
    Par chuck norris dans le forum Persistance des données
    Dernier message: 13/07/2005, 22h01
  5. [Struts] Problème de mapping
    Par ArseNic dans le forum Struts 1
    Dernier message: 10/02/2005, 10h11
