Nom de table invalide aprés deux clauses WITH
    Membre habitué
    Mai 2011
    Par défaut Nom de table invalide aprés deux clauses WITH
    Après avoir rajouter une deuxième clause With dans ma requête afin de pouvoir stocker un calcul, pour ensuite faire une comparaison dessus, j'obtiens un message d'erreur lorsque je l'enregistre :
    WITH
    FACPRI AS (SELECT
    SOCIETE, SITE, DATFAC, NUMFAC, DEVISE, BPCCODE, CLIENT, ITEM, DES1, DES2, DESBPC, PRIHT, NUMCOM, COMCLI, DATCOM, NUMLIV, DATEXP, QTY, UOM, PRIX1, PRIX2
    FROM
    (SELECT
    SIH.CPY_0 AS SOCIETE,
    SIH.FCY_0 AS SITE,
    SIH.ACCDAT_0 AS DATFAC,
    SIH.NUM_0 AS NUMFAC,
    SIH.CUR_0 AS DEVISE,
    SID.BPCINV_0 AS BPCCODE,
    BPR.BPRNAM_0 AS CLIENT,
    SID.ITMREF_0 AS ITEM,
    SID.ITMDES_0 AS DES1,
    SID.ITMDES1_0 AS DES2,
    ITU.ITMREFBPC_0 AS DESBPC,
    SID.GROPRI_0 AS PRIHT,
    SID.SOHNUM_0 AS NUMCOM,
    SOH.CUSORDREF_0 AS COMCLI,
    SOQ.ORDDAT_0 AS DATCOM,
    SID.SDHNUM_0 AS NUMLIV,
    SDD.SHIDAT_0 AS DATEXP,
    SDD.QTY_0 AS QTY,
    SDD.SAU_0 AS UOM,
    (SELECT MIN(SPL.PRI_0) FROM SPRICLIST SPL WHERE SIH.CPY_0 = SPL.PLICRI1_0
    AND SIH.CUR_0 = SPL.CUR_0
    AND SID.ITMREF_0 = SPL.PLICRI2_0
    AND SDD.BPCORD_0 = SPL.PLICRI3_0
    AND SDD.BPAADD_0 = SPL.PLICRI4_0
    AND SIH.ACCDAT_0 >= SPL.PLISTRDAT_0
    AND SIH.ACCDAT_0 <= SPL.PLIENDDAT_0
    AND SID.QTY_0 >= SPL.MINQTY_0
    AND SID.QTY_0 <= SPL.MAXQTY_0
    AND SPL.PLI_0 = 'NIEF01') AS PRIX1,
    (SELECT MIN(SPL1.PRI_0) FROM SPRICLIST SPL1 WHERE SIH.CPY_0 = SPL1.PLICRI1_0
    AND SIH.CUR_0 = SPL1.CUR_0
    AND SID.ITMREF_0 = SPL1.PLICRI2_0
    AND SDD.BPCORD_0 = SPL1.PLICRI3_0
    AND SIH.ACCDAT_0 >= SPL1.PLISTRDAT_0
    AND SIH.ACCDAT_0 <= SPL1.PLIENDDAT_0
    AND SID.QTY_0 >= SPL1.MINQTY_0
    AND SID.QTY_0 <= SPL1.MAXQTY_0
    AND SPL1.PLI_0 = 'NIEF02') AS PRIX2
    FROM
    SINVOICED SID
    JOIN SINVOICE SIH ON SID.NUM_0 = SIH.NUM_0
    JOIN BPARTNER BPR ON SID.BPCINV_0 = BPR.BPRNUM_0
    LEFT OUTER JOIN SORDERQ SOQ ON SID.SOHNUM_0 = SOQ.SOHNUM_0 AND SID.SOPLIN_0 = SOQ.SOPLIN_0 AND SID.SOQSEQ_0 = SOQ.SOQSEQ_0
    LEFT OUTER JOIN SORDER SOH ON SID.SOHNUM_0 = SOH.SOHNUM_0
    LEFT OUTER JOIN ITMBPC ITU ON SOQ.BPCORD_0 = ITU.BPCNUM_0 AND SOQ.ITMREF_0 = ITU.ITMREF_0
    LEFT OUTER JOIN SDELIVERYD SDD ON SID.SDHNUM_0 = SDD.SDHNUM_0 AND SID.SDDLIN_0 = SDD.SDDLIN_0
    WHERE
    SIH.CPY_0 BETWEEN %1% AND %2% AND
    SIH.FCY_0 BETWEEN %3% AND %4% AND
    SIH.ACCDAT_0 BETWEEN %5% AND %6%
    RESULT AS (
    SELECT SOCIETE, SITE, DATFAC, NUMFAC, DEVISE, BPCCODE, CLIENT, ITEM, DES1, DES2, DESBPC, PRIHT, NUMCOM, COMCLI, DATCOM, NUMLIV, DATEXP, QTY, UOM, PRIX1, PRIX2,
    CASE
    WHEN (PRIX1>0 AND PRIX2>0 AND PRIX1<PRIX2 AND PRIX1<>PRIHT) THEN ((PRIX1-PRIHT)*QTY)
    WHEN (PRIX1>0 AND PRIX1 <> PRIHT) THEN ((PRIX1-PRIHT)*QTY)
    WHEN (PRIX2>0 AND PRIX2 <> PRIHT) THEN ((PRIX2-PRIHT)*QTY)
    ELSE 0
    END AS MNTREGUL
    FROM FACPRI),
    SELECT SOCIETE, SITE, DATFAC, NUMFAC, DEVISE, BPCCODE, CLIENT, ITEM, DES1, DES2, DESBPC, PRIHT, NUMCOM, COMCLI, DATCOM, NUMLIV, DATEXP, QTY, UOM, PRIX1, PRIX2, MNTREGUL
    FROM RESULT
    WHERE MNTREGUL <> 0
    Si j'utilise pas mon deuxième WITH, et que je passe par select ça marche. Mais après je ne sais comment mettre un critère sur le résultat de mon CASE.
    Merci pour votre aide par avance,
    pyth
    Avatar de al1_24
    Retraité
    Mai 2002
    Activité : Retraité
    Ce qui serait intéressant pour pouvoir t'aider à corriger ta requête, ce serait que tu nous donnes aussi le message d'erreur
    Modérateur Langage SQL
    [code]
    Août 2008
    Pas de virgule à la fin de la dernière CTE
    Membre habitué
    Mai 2011
    Citation Envoyé par skuatamad Voir le message
    La loose...
    merci bcp
    Membre habitué
    Mai 2011
    Pardon,
    ORA-00903 : invalide table name
  1. Réponses: 1
    Dernier message: 15/04/2010, 08h10
  2. [CR 9] Nom de table pas mis à jour après changement de la source de données
    Par zodeno dans le forum Connectivité
    Dernier message: 29/09/2009, 13h36
  3. Réponses: 10
    Dernier message: 12/03/2007, 12h06
  4. Réponses: 4
    Dernier message: 10/05/2006, 18h40
  5. Urgent - après la migration - les tables "Invalid Objet
    Par nnn2050 dans le forum MS SQL Server
    Dernier message: 27/12/2005, 10h50
