Retour conditionnel d'une colonne
    Octobre 2004
    Par défaut Retour conditionnel d'une colonne
    ci-apres le sql
    SELECT  p.MATRICULE,
                      p.NOM,
                      p.PRENOM,
                      c.DATEJ,
               CASE WHEN TRIM(TO_CHAR(c.DATEJ,'DAY')) = 'MONDAY'
               THEN CASE      WHEN ((ABS(c.CPT005) - trunc(ABS(c.CPT005)))*60) < 10
                     THEN
                        TRUNC(c.CPT005)||' h 0'||
                        TRUNC(ROUND((c.CPT005 - trunc(c.CPT005))*60))||' min'
                     ELSE
                        TRUNC(c.CPT005)||' '||TRUNC(ROUND((c.CPT005 - TRUNC(c.CPT005))*60))
                              ||' min'
                     END
               ELSE
                     CASE     WHEN ((ABS(c.CPT005 + c.CPT006) - trunc(ABS(c.CPT005 +
                              c.CPT006)))*60) < 10
                     THEN
                              TRUNC(c.CPT005 + c.CPT006)||' h 0'||TRUNC(ROUND(((c.CPT005 +
                              c.CPT006) - trunc(c.CPT005 + c.CPT006))*60))||' min'
                     ELSE
                              TRUNC(c.CPT005 + c.CPT006)||' h '||TRUNC(ROUND(((c.CPT005
                              + c.CPT006) - trunc(c.CPT005 + c.CPT006))*60))||' min'
                     END
               END    CUMUL_HEBDO_COMPTA,
                         THEN
                     CASE     WHEN ((ABS(c.CPT011) - trunc(ABS(c.CPT011)))*60) < 10
                     THEN
                     trunc(c.CPT011)||' h 0'||TRUNC(ROUND((c.CPT011 - trunc(c.CPT011))*60))||' min'
                     ELSE
                     trunc(c.CPT011)||' h '||TRUNC(ROUND((c.CPT011 - trunc(c.CPT011))*60))||' min'
                     END
                      ELSE
                     CASE     WHEN ((ABS(c.CPT011 + c.CPT012) - trunc(ABS(c.CPT011 + c.CPT012)))*60) < 10
                     THEN
                     trunc(c.CPT011 + c.CPT012)||' h 0'||TRUNC(ROUND((c.CPT011 + c.CPT012 - trunc(c.CPT011 + c.CPT012))*60))||' min'
                     ELSE
                     trunc(c.CPT011 + c.CPT012)||' h '||TRUNC(ROUND((c.CPT011 + c.CPT012 - trunc(c.CPT011 + c.CPT012))*60))||' min'
                     END
               END    CUMUL_HEBDO_REAL,
               CASE WHEN ((ABS(c.CPT024) - trunc(ABS(c.CPT024)))*60) < 10
                         THEN
                              DECODE(SIGN(c.CPT024),-1,'- '||trunc(ABS(c.CPT024))||' h 0'||TRUNC(ROUND((ABS(c.CPT024) - trunc(ABS(c.CPT024)))*60))||' min',trunc(ABS(c.CPT024))||' h 0'||TRUNC(ROUND((ABS(c.CPT024) - trunc(ABS(c.CPT024)))*60))||' min')
                     ELSE
                     CASE WHEN ROUND((ABS(c.CPT024) - trunc(ABS(c.CPT024)))*60) = 60
                     THEN
                      DECODE(SIGN(c.CPT024),-1,'- '||trunc(ABS(c.CPT024+1))||' h 00 min',trunc(ABS(c.CPT024+1))||' h 00 min')
                     ELSE
                     DECODE(SIGN(c.CPT024),-1,'- '||trunc(ABS(c.CPT024))||' h '||TRUNC(ROUND((ABS(c.CPT024) - trunc(ABS(c.CPT024)))*60))||' min',trunc(ABS(c.CPT024))||' h '||TRUNC(ROUND((ABS(c.CPT024) - trunc(ABS(c.CPT024)))*60))||' min')
                     END
             END      DEBIT_CREDIT_HEBDO,
             CASE WHEN ((ABS(c.CPT026) - trunc(ABS(c.CPT026)))*60) < 10
                         THEN
                              DECODE(SIGN(c.CPT026),-1,'- '||trunc(ABS(c.CPT026))||' h 0'||TRUNC(ROUND((ABS(c.CPT026) - trunc(ABS(c.CPT024)))*60))||' min',trunc(ABS(c.CPT026))||' h 0'||TRUNC(ROUND((ABS(c.CPT026) - trunc(ABS(c.CPT026)))*60))||' min')
                     ELSE
                     CASE WHEN ROUND((ABS(c.CPT026) - trunc(ABS(c.CPT026)))*60) = 60
                     THEN
                      DECODE(SIGN(c.CPT026),-1,'- '||trunc(ABS(c.CPT026+1))||' h 00 min',trunc(ABS(c.CPT026+1))||' h 00 min')
                     ELSE
                     DECODE(SIGN(c.CPT026),-1,'- '||trunc(ABS(c.CPT026))||' h '||TRUNC(ROUND((ABS(c.CPT026) - trunc(ABS(c.CPT026)))*60))||' min',trunc(ABS(c.CPT026))||' h '||TRUNC(ROUND((ABS(c.CPT026) - trunc(ABS(c.CPT026)))*60))||' min')
                     END
             END      DEBIT_CREDIT_MENS
    FROM
             PERSONNEL p,
             COMPTEURJ c
    WHERE
              (1=1)
    AND       c.NUMMAT = p.NUMMAT
    AND       TO_CHAR(c.DATEJ,'YYYYMMDD') = TO_CHAR(SYSDATE,'YYYYMMDD')
    AND       (p.MATRICULE = '00763429' )
    ORDER BY p.MATRICULE, c.DATEJ
    Je souhaite ne faire apparaitre que le debit_credit_mens ou debit_credit_hebdo
    en fonction de la valeur de la colonne p.cycle
    Est-il possible de ne selectionner que 7 sur 8 colonnes
    J'ai essayé sans succès
    SELECT  p.MATRICULE,
                      p.NOM,
                      p.PRENOM,
                      c.DATEJ,
                     THEN
                     ELSE
                              ||' min'
                     END
               ELSE
                     THEN
                     ELSE
                     END
                         THEN
                     THEN
                     ELSE
                     END
                      ELSE
                     THEN
                     ELSE
                     END
               if p.cycle like '%TPLEIN%'
               then
                         THEN
                     ELSE
                     THEN
                     ELSE
                     END
            Else
                         THEN
                     ELSE
                     THEN
                     ELSE
                     END
          End if
    FROM
             PERSONNEL p,
             COMPTEURJ c
    WHERE
              (1=1)
    Pourriez-vous m'aider
    Octobre 2007
    Citation Envoyé par velo83 Voir le message
    En SQL statique non. Mais il est possible d'afficher Null pour la colonne qui ne doit pas apparaitre.
    Octobre 2004
    Merci beaucoup pour votre réponse
  1. Réponses: 5
    Dernier message: 23/01/2012, 13h18
  2. [XL-2007] Créer une colonne à partir d'une selection conditionnelle
    Par sunstrike69 dans le forum Excel
    Dernier message: 27/07/2009, 18h33
  3. Réponses: 4
    Dernier message: 16/08/2007, 23h13
  4. [SQL]Retour d'une colonne unique
    Par Le nain Attila dans le forum Oracle
    Dernier message: 31/03/2006, 16h26
