Delphi Discussion :
problème initialization TAPI
Delphi
    Futur Membre du Club
    Mai 2006
    Par défaut problème initialization TAPI
    j'essay d'initialiser la Telephony API avec les deux méthodes :
    initialize et initializeEX. Mais j'ai l'erreur 80000035 LINEERR_INVALPOINTER.
    et je n'arrive pas à comprentdre ou est le problème.
    extrait du code :
    unit Main;
    interface
    uses
    Windows, Messages, SysUtils, Variants, Classes, Graphics, Controls, Forms,
    Dialogs, TAPI, TAPI3Err, TSPI, StdCtrls, Buttons;
    type
    TForm1 = class(TForm)
    BitBtn1: TBitBtn;
    BTN_InitTapi: TSpeedButton;
    TapiInform: TMemo;
    Label1: TLabel;
    BTN_OldInit: TSpeedButton;
    procedure BTN_InitTapiClick(Sender: TObject);
    procedure BTN_OldInitClick(Sender: TObject);
    function InitTAPI : Longint;
    function OldInitTAPI : Longint;
    private
    { Déclarations privées }
    lineApp : PHLINEAPP;
    CallParams : TLineCallParams;
    InitParams : TLineInitializeExParams;
    public
    { Déclarations publiques }
    end;
    var
    Form1: TForm1;
    nDevs : DWord;
    TapiVers : DWord;
    Vers : record
    P,R : word
    end absolute tapivers;
    implementation
    {$R *.dfm}
    procedure CallBackFct (hDevice, dwMessage, dwInstance,
    dwParam1, dwParam2, dwParam3: Longint);
    begin
    end;
    function TFORM1.InitTAPI;
    begin
    TapiVers := $00030001;
    FillChar(InitParams, 0, SIZEOF(InitParams));
    with InitParams do
    begin
    dwTotalSize := SIZEOF(InitParams);
    dwOptions := LINEINITIALIZEEXOPTION_USEHIDDENWINDOW
    end;
    InitTAPI := lineInitializeEx(lineApp, HInstance,
    @CallBackFct, nil, nDevs, TapiVers, InitParams);
    end;
    function TForm1.OldInitTAPI;
    begin
    FillChar(CallParams, sizeof(CallParams), 0);
    with CallParams do
    begin
    dwTotalSize := sizeof(CallParams);
    dwBearerMode := LINEBEARERMODE_VOICE;
    dwMediaMode := LINEMEDIAMODE_INTERACTIVEVOICE;
    end;
    OldInitTAPI := lineInitialize(lineApp, HInstance, @CallBackFct, nil, nDevs)
    end;
    procedure TForm1.BTN_InitTapiClick(Sender: TObject);
    begin
    with TapiInform.Lines do
    begin
    Clear;
    add('Code erreure : ' + inttohex(InitTAPI, 8));
    add('TAPI Version : ' +IntTostr(Vers.P)+'.'+IntTostr(Vers.P));
    Add('Nombre des Devices : '+ IntToStr(nDevs));
    end
    end;
    procedure TForm1.BTN_OldInitClick(Sender: TObject);
    begin
    begin
    Clear;
    add('Code erreure : ' + inttohex(OldInitTAPI, 8));
    end
    end;
    end.
    Avatar de neilbgr
    Développeur .NET
    Août 2004
    Activité : Développeur .NET
    Avatar de neilbgr
    Développeur .NET
    Août 2004
    Les callback windows sont en stdcall, après ça, ça devrait aller mieux. Mais c'est juste a vu de nez !
    Mai 2006
    Par défaut Problème TAPI
    J'utilise une unité qui interface la bibliothèque TAPI (TAPI.pas) que j'ai téléchargé (Recherches avec google. les appels sont bien en stdcall.
    F1 sans résultats
    Google sans résultats
    reste les FORUMs
    Avatar de neilbgr
    Développeur .NET
    Août 2004
    Citation Envoyé par bel76
    Or :
    begin
    end;
    Je ne vois pas de stdcall.
    Je vais nettoyer mes lunettes de ce pas...
    Avril 2005
    function TfrmMain.InitTAPI():Boolean;
    var
    AppName:array[0..20] of char;
    nAPIVersionWORD;
    begin
    Result:=true;
    lineApp := 0;
    AppName := 'IP OFFICE Project';
    LogString( 'START TO INITIALIZE TAPI' );
    with lineInit do
    begin
    dwTotalSize := sizeof( lineInit );
    dwOptions := LINEINITIALIZEEXOPTION_USEHIDDENWINDOW;
    end;
    nAPIVersion := $00020000;
    nReturn := lineInitializeEx( @lineApp , HInstance , lineCallBack , AppName ,nDevs , nAPIVersion, lineInit );
    if (nReturn < 0)
    then
    begin
    // Initialize Failed
    LogString( 'FAILED TO INITIALIZE ' + IntToHex( nReturn,8 ) + ' '
    + IntToHex( HInstance ,8 ) ) ;
    Result:= false;
    end
    else if (nDevs = 0) then
    begin
    LogString ('NO TAPI LINE DEVICES' );
    lineShutDown( lineApp );
    lineApp :=0;
    Result:= false;
    end
    else
    begin
    LogString ( 'LINEAPP:' + IntToHex( lineApp , 8 ) + ' ' +
    'INSTANCE:' + IntToHex( HInstance , 8 ) + ' ' +
    'LINE DEVICES:' + IntToHex( nDevs ,8) + ' ' +
    'TAPI VERSION:' + IntToHex( nAPIVersion , 8 ) ) ;
    // save the handle
    m_lineApp := lineApp;
    end;
    end;
    je le fait de cette façon et j'en ai aucun problème d'initialisation, tu peux tester sbien !
    si tu rencontre qq problème je suis là pour tt aides !
    Avatar de Lung
    Analyste-programmeur
    Mai 2002
    Activité : Analyste-programmeur
    L'urgent est fait, l'impossible est en cours, pour les miracles prévoir un délai. :bug: ___ "http://club.developpez.com/regles/#LIII-A"Écrivez dans un français correct !!
    C++Builder 5 - Delphi 6#2 Entreprise - Delphi 2007 Entreprise - Delphi 2010 Architecte - Delphi XE Entreprise - Delphi XE7 Entreprise - Delphi 10 Entreprise - Delphi 10.4.2 Entreprise - Delphi 11.3 Entreprise - Visual studio 2022
    OpenGL 2.1 - Oracle 10g - Paradox - Interbase (XE) - PostgreSQL (15.7)
  1. [AC-2000] Problème sur l'état initial d'un bouton bascule
    Par caesar23 dans le forum VBA Access
    Dernier message: 01/06/2010, 10h14
  2. problème d'affichage initial
    Par bubblebe dans le forum wxPython
    Dernier message: 23/01/2010, 23h39
  3. Réponses: 0
    Dernier message: 23/06/2008, 22h11
  4. [Restlet] Problème d'initiation
    Par zette dans le forum Frameworks Web
    Dernier message: 07/05/2007, 14h32
  5. problème initialisation de la TAPI
    Par bel76 dans le forum API, COM et SDKs
    Dernier message: 05/05/2006, 23h13
