avec Java Discussion :
Problème d'affichage au chargement
avec Java
    Membre éclairé Avatar de hugoclo
    Décembre 2007
    Par défaut Problème d'affichage au chargement
    J'utilise ce code pour traiter des trames !AIVDM.
    119
    120
    121
    122
    123
    124
    125
    126
    127
    128
    129
    130
    131
    132
    133
    134
    135
    136
    137
    138
    139
    140
    141
    142
    143
    144
    145
     * To change this template, choose Tools | Templates
     * and open the template in the editor.
    package ais;
    import static java.awt.image.ImageObserver.WIDTH;
    import java.io.BufferedReader;
    import java.io.StringReader;
    import java.net.DatagramPacket;
    import java.net.DatagramSocket;
     * @author Seb et Lae
    public class Accueil extends javax.swing.JFrame implements Runnable {
        public String NewsMsg;
        Thread t=null;
       BufferedReader _monbuf;
        int ClinetPortNumber;
         * Creates new form Accueil
        public Accueil() {
            initComponents();
          NewsMsg = null;
            //super("News Client");
     public void Setup(int ClientPort)
            ClinetPortNumber=ClientPort;//ClientPort;
            t=new Thread(this);
            t.start();
        @SuppressWarnings("unchecked")
        private void exitMenuItemActionPerformed(java.awt.event.ActionEvent evt) {
            System.exit(0);
        private void jButton1ActionPerformed(java.awt.event.ActionEvent evt) {
            // TODO add your handling code here:
         * @param args the command line arguments
        public static void main(String args[]) {
            /* Set the Nimbus look and feel */
            //<editor-fold defaultstate="collapsed" desc=" Look and feel setting code (optional) ">
            /* If Nimbus (introduced in Java SE 6) is not available, stay with the default look and feel.
             * For details see http://download.oracle.com/javase/tutorial/uiswing/lookandfeel/plaf.html
            try {
                for (javax.swing.UIManager.LookAndFeelInfo info : javax.swing.UIManager.getInstalledLookAndFeels()) {
                    if ("Nimbus".equals(info.getName())) {
                        javax.swing.UIManager.setLookAndFeel(info.getClassName());
                        break;
            } catch (ClassNotFoundException ex) {
                java.util.logging.Logger.getLogger(Accueil.class.getName()).log(java.util.logging.Level.SEVERE, null, ex);
            } catch (InstantiationException ex) {
            } catch (IllegalAccessException ex) {
            } catch (javax.swing.UnsupportedLookAndFeelException ex) {
            //</editor-fold>
    final Accueil ob = new Accueil();
    ob.Setup(6020);
            /* Create and display the form */
            java.awt.EventQueue.invokeLater(new Runnable() {
                public void run() {
                    new Accueil().setVisible(true);
                     while(true)
                try
                    try (DatagramSocket ClientSoc = new DatagramSocket(6020)) {
                        byte Receivebuff[]=new byte[1024];
                        DatagramPacket dp=new DatagramPacket(Receivebuff,Receivebuff.length);
                        ClientSoc.receive(dp);
                        ob.NewsMsg = new String(dp.getData(),0,dp.getLength());
                        BufferedReader entree = new BufferedReader(new StringReader(ob.NewsMsg));
                        ClientSoc.close();
                        Thread.sleep(50);
                        AcqAIS miact = new AcqAIS(ob.NewsMsg, null);
                       ob.jTextArea1.setText(miact.resultat);
                catch(Exception ex)
                    ex.printStackTrace();
        // Variables declaration - do not modify
        private javax.swing.JMenuItem aboutMenuItem;
        private javax.swing.JMenuItem contentsMenuItem;
        private javax.swing.JMenuItem copyMenuItem;
        private javax.swing.JMenuItem cutMenuItem;
        private javax.swing.JMenuItem deleteMenuItem;
        private javax.swing.JMenu editMenu;
        private javax.swing.JMenuItem exitMenuItem;
        private javax.swing.JMenu fileMenu;
        private javax.swing.JMenu helpMenu;
        private javax.swing.JButton jButton1;
        private javax.swing.JScrollPane jScrollPane1;
        private javax.swing.JTextArea jTextArea1;
        private eu.hansolo.steelseries.extras.Led led1;
        private javax.swing.JMenuBar menuBar;
        private javax.swing.JMenuItem openMenuItem;
        private javax.swing.JMenuItem pasteMenuItem;
        private javax.swing.JMenuItem saveAsMenuItem;
        private javax.swing.JMenuItem saveMenuItem;
        // End of variables declaration
        @Override
        public void run() {
            throw new UnsupportedOperationException("Not supported yet."); //To change body of generated methods, choose Tools | Templates.
    Sur ma fenetre principale il devrais il y avoir un jtextarea , et un jbutton etc.
    Au lancement ma fenetre s'ouvre mais sans jtextarea ni jbutton ni rien.
    Par contre le traitement fonctionne.
    De
    !AIVDM,1,1,,A,13npVB002V06TVhM5Ej0lPU`0<0g,0*13
    j'obtiens bien
    1MessagePOS
    Repeat indicator 0
    MMSI: 233009000
    Nav Status: 0
    ROT: 0.17856115333363184
    SOG: 5.9
    Pos Accuracy: 0
    Longitude : 1.4910133333333333
    Latitude : 51.04416833333333
    COG: 0.0
    True heading: 62
    TimeStamp: 12
    SM: 0
    Spare: 0
    RAIM: 0
    Comm state: 2244
    Sync State: 0
    Slot Time Out: 0
    Sub Message: 2244
    voici ma mon autre class
    import java.util.*;
    import java.io.*;
    import java.util.regex.*;
    public class AcqAIS extends Thread{
    	private Thread _t;
    	private LinkedList<MessageAIS> _dest;
    	//private BufferedReader _br;
    	private String _br;
            public String resultat;
    	public AcqAIS(String br,LinkedList<MessageAIS> dest){
    		_dest=dest;
    		_br=br;
    		_t = new Thread(this);
    		_t.start();
    	public void run(){
    		try{
    			//while(_br.ready()){
    				String s = _br;//.readLine();
    				if (s.charAt(0) == "!".charAt(0)){
    					Scanner sc = new Scanner(s);
    					sc.findInLine("!AIVDM,1,1,,A,(.*),\\d\\*\\w{2}");
    					MatchResult result = sc.match();
    					sc.close();
    					String msg = result.group(1);
                                           // System.out.print(MessageAIS.getMsgType(msg));
    					if (MessageAIS.getMsgType(msg) == 1){
    						MessagePOS ms= new MessagePOS(msg);
                                                    resultat = ms.toString();
    						System.out.println(resultat);
    					else if (MessageAIS.getMsgType(msg) == 5){
    						MessageSTATIC ms= new MessageSTATIC(msg);
    						//System.out.println(ms);
    		catch(Exception e){System.out.println(e );}
    	public static void main (String[] args){
    		try{
                            String mbr = args[0];
    			//BufferedReader mbr = new BufferedReader(new FileReader(args[0]));
    			LinkedList<MessageAIS> liste = new LinkedList<MessageAIS>();
    			AcqAIS myAcqAIS= new AcqAIS(mbr,liste);
    D'autre part quand je fais ceci (class Accueil) :
      System.out.println(miact.resultat);
    j'ai nullnullnull etc.
    alors que (Class AcqAIS)
    donne un resultat.
    Avatar de joel.drigo
    Septembre 2009
    Salut :
    AcqAIS est un thread qui est démarré dans le constructeur : il est probable que la ligne qui suit le constructeur accède à la variable resultat beaucoup trop tôt, alors qu'il faudrait attendre que le thread soit terminé (ou au moins que resultat soit affecté)
    tu pourrais procéder par swingworker par exemple pour éviter de bloquer ton thread graphique en attendand que resultat soit affecté, et/ou par évenement (quand ton resultat est prêt tu lances un évenement pour dire qu'il l'est) et ton interface graphique enregistre un écouteur pour le savoir et mettre la valeur dans ton textarea.
    éventuellement tu peux décoréler le thread et la GUI en utilisant un dispatcher d'événement : l'interface enregistre son écouteur sur le dispatcher et non sur le thread, le thread envoie ses évenements vers le dispatcher
    Décembre 2007
    Merci pour la réponse,
    j'essaye le swingworker.
    public static void updateBouton(){
        //On crée un Worker générique, cette fois
        SwingWorker sw = new SwingWorker<String, String>(){
          protected String doInBackground() throws Exception {
            int i;
            Swinwor ob = new Swinwor();
            String NewsMsg;
             while(true)
                try
                        //System.out.print(ob.NewsMsg);
                        //System.out.print(ob.NewsMsg.substring(0, 2) + "\n");
                       // NMEAMessageReceiver tutu = new NMEAMessageReceiver(ob.NewsMsg);
                        BufferedReader entree = new BufferedReader(new StringReader(NewsMsg));
                        ClientSoc.close();
                        Thread.sleep(50);
                     System.out.print(NewsMsg);
                catch(Exception ex)
            return NewsMsg;
    pourquoi j'ai qui est surligné et affiche une erreur unreachable statement?
    Cordialement.
    Décembre 2007
    Je n'avais pas mis mon return au bon endroit.
    J'ai modifié mon code comme suis :
             while(true)
                String NewsMsg = null;
                String nees = null;
                try
                         ClientSoc.close();
                        Thread.sleep(50);
                        AcqAIS miac = new AcqAIS(NewsMsg, null);
                catch(Exception ex)
                return NewsMsg;
          public void done(){
                Accueil _accueil = new Accueil();
            if(SwingUtilities.isEventDispatchThread())
            // System.out.println("Dans l'EDT ! ");
              try {
                  _accueil.jTextArea1.setText(get());
              } catch (InterruptedException ex) {
                  Logger.getLogger(Accueil.class.getName()).log(Level.SEVERE, null, ex);
              } catch (ExecutionException ex) {
            try {
              //On utilise la méthode get() pour récupérer le résultat
              //de la méthode doInBackground()
             System.out.print(get());
              updateBouton();
            } catch (InterruptedException e) {
              e.printStackTrace();
            } catch (ExecutionException e) {
          //La méthode gérant les résultats intermédiaires
          public void process(List<String> list){
            for(String str : list)
              System.out.println("je suis ici : process");
        //On écoute le changement de valeur pour la propriété
        sw.addPropertyChangeListener(new PropertyChangeListener(){
          //Méthode de l'interface
          public void propertyChange(PropertyChangeEvent event) {
            //On vérifie tout de même le nom de la propriété
            if("progress".equals(event.getPropertyName())){
                System.out.println("Je suis ici : propertyChange");
        //On lance le SwingWorker
        sw.execute();
    et
    	private Thread _t;
    	public String _br;
             public String resul;
    		_dest=dest;
    		_br=br;
    		_t.start();
    	public void run(){
    		try{
                         Accueil acc = new Accueil();
    					sc.close();
                                                    acc.tutu = ms.toString();
                                            	System.out.println(acc.tutu);
    		try{
                            System.out.print("le nouveau" + mbr);
                           // updateBouton1(mbr);
    Mais mon Jtextarea reste vide.
    Décembre 2007
    Cherchant toujours une solution j'ai modifié mon code comme suit:
    119
    120
    121
    122
    123
    124
    125
    126
    127
    128
    129
    130
    131
    132
    133
    134
    135
    136
    137
    138
    139
    140
    141
    142
    143
    144
    145
    146
    147
    148
    149
    150
    151
    152
    153
    154
    155
    156
    157
    158
    159
    160
    161
    162
    163
    164
    165
    166
    167
    168
    169
    170
    171
    172
    173
    174
    175
    176
    177
    178
    179
    180
    181
    182
    183
    184
    185
        public String tutu;
        Thread t;
        JLabel lbli = new JLabel();
    //String[] toto = new String[WIDTH];
        public Accueil() {
            this.add(lbli);
            initComponents();
            System.exit(0);
                public void run() {
                   updateBouton();
        public void ecrire(String txt){
            jTextArea1.setText(txt);
           String nees = null;
             while(true)
                try
                    _accueil.jTextArea1.setText(nees);
                         ClientSoc.close();
                        Thread.sleep(50);
                        if (NewsMsg.charAt(0) == "!".charAt(0)){
    					Scanner sc = new Scanner(NewsMsg);
    					sc.close();
                                        // System.out.print(msg);
                                                  nees = ms.toString();
                catch(Exception ex)
                return nees;
          public void done(){
              try {
                  _accueil.lbli.setText(get());
                 // _accueil.jTextArea1.setText(_accueil.tutu);
            try {
               _accueil.ecrire(get());
                    updateBouton();
        sw.execute();
        @Override
        public void run() {
           // throw new UnsupportedOperationException("Not supported yet."); //To change body of generated methods, choose Tools | Templates.
    Pourquoi quand je fait dans done()
      _accueil.ecrire(get());//ou _accueil.jtextarea1.settext(get());
    Mon jtextarea reste vide alors que mon get() n'est pas null.
  1. ZEND_DOJO : problème d'affichage pendant le chargement
    Par fa6r1ce dans le forum Zend_Form
    Dernier message: 18/05/2009, 13h13
  2. Réponses: 2
    Dernier message: 01/08/2008, 12h56
  3. [Kylix] problème d'affichage
    Par scalvi dans le forum EDI
    Dernier message: 18/06/2003, 10h07
  4. Réponses: 1
    Dernier message: 06/03/2003, 11h57
  5. probléme d'affichage d'une fiche
    Par sb dans le forum Composants VCL
    Dernier message: 29/08/2002, 09h43
