Erreur Vue Matérialisée
    Juillet 2011
    Par défaut Erreur Vue Matérialisée
    Bonjour, j'ai une vue matérialisée à modifier, j'essaie donc de lancer ce script :
    DROP MATERIALIZED VIEW APOLLO_REP_UK.CDIM_PRODUCT_ATT_MV;
    CREATE MATERIALIZED VIEW APOLLO_REP_UK.CDIM_PRODUCT_ATT_MV
    TABLESPACE APOLLO_REP_UK
    PCTUSED    0
    PCTFREE    0
    INITRANS   2
    MAXTRANS   255
    STORAGE    (
                INITIAL          16K
                MINEXTENTS       1
                MAXEXTENTS       UNLIMITED
                PCTINCREASE      0
                BUFFER_POOL      DEFAULT
    NOCACHE
    LOGGING
    NOCOMPRESS
    NOPARALLEL
    BUILD DEFERRED
    REFRESH COMPLETE
    START WITH TO_DATE('28-déc.-2011 15:36:51','dd-mon-yyyy hh24:mi:ss')
    NEXT SYSDATE+1
    WITH PRIMARY KEY
    AS
    /* Formatted on 2011/12/27 16:30 (Formatter Plus v4.8.8) */
    SELECT DISTINCT pr.product_sid, pr.brand_sid, pr.brand_name,
                    UPPER (NVL (sn.text_value, 'N/A')) season,
                    UPPER (NVL (hl.text_value, 'N/A')) heavy_light,
                    UPPER (NVL (ot.text_value, 'N/A')) original_tread_depth,
                    UPPER (NVL (nr.text_value, 'N/A')) new_remould,
                    UPPER (NVL (wp.text_value, 'N/A')) POSITION,
                    NVL (li.numeric_value, 0) load_index,
                    UPPER (NVL (si.text_value, 'N/A')) speed_index,
                       UPPER (NVL (se.numeric_value, 0))
                    || UPPER (NVL (ap.numeric_value, 0))
                    || UPPER (NVL (rd.numeric_value, 0)) dimensions,
                    UPPER (NVL (pn.text_value, 'N/A')) profile_name,
                    CASE
                       WHEN UPPER (NVL (hl.text_value, 'N/A')
                                  ) = 'LIGHT'
                          THEN 1.0
                       ELSE 1.6
                    END AS minimum_tread_depth
               FROM apollo_rep_uk.dim_product pr LEFT OUTER JOIN apollo_rep_uk.dim_product_attributes hl
                    ON pr.product_sid = hl.product_sid
                  AND hl.esm_attribute_name LIKE '001%'
                    LEFT OUTER JOIN apollo_rep_uk.dim_product_attributes nr
                    ON pr.product_sid = nr.product_sid
                  AND nr.esm_attribute_name LIKE '002%'
                    LEFT OUTER JOIN apollo_rep_uk.dim_product_attributes sn
                    ON pr.product_sid = sn.product_sid
                  AND sn.esm_attribute_name LIKE '017%'
                    LEFT OUTER JOIN apollo_rep_uk.dim_product_attributes wp
                    ON pr.product_sid = wp.product_sid
                  AND wp.esm_attribute_name LIKE '023%'
                    LEFT OUTER JOIN apollo_rep_uk.dim_product_attributes si
                    ON pr.product_sid = si.product_sid
                  AND si.esm_attribute_name LIKE '009%'
                    LEFT OUTER JOIN apollo_rep_uk.dim_product_attributes li
                    ON pr.product_sid = li.product_sid
                  AND li.esm_attribute_name LIKE '008%'
                    LEFT OUTER JOIN apollo_rep_uk.dim_product_attributes se
                    ON pr.product_sid = se.product_sid
                  AND se.esm_attribute_name LIKE '003%'
                    LEFT OUTER JOIN apollo_rep_uk.dim_product_attributes ap
                    ON pr.product_sid = ap.product_sid
                  AND ap.esm_attribute_name LIKE '004%'
                    LEFT OUTER JOIN apollo_rep_uk.dim_product_attributes rd
                    ON pr.product_sid = rd.product_sid
                  AND rd.esm_attribute_name LIKE '005%'
                    LEFT OUTER JOIN APOLLO_REP_UK.dim_product_attributes ot
                    ot pr.product_sid = ot.product_sid
                  AND ot.esm_attribute_name LIKE '026%'
                    LEFT OUTER JOIN apollo_rep_uk.dim_product_attributes pn
                    ON pr.product_sid = pn.product_sid
                  AND pn.esm_attribute_name LIKE '006%';
    COMMENT ON MATERIALIZED VIEW APOLLO_REP_UK.CDIM_PRODUCT_ATT_MV IS 'snapshot table for snapshot APOLLO_REP_UK.CDIM_PRODUCT_ATT_MV';
    Malheureusement, lorsque j'exécute le script, j'ai une erreur :
    Error at line 2
    ORA-00905: mot-clé absent
    Précision, je travaille avec l'outil "TOAD"
    Si quelqu'un a une idée...
    Merci d'avance.
    Avatar de Sunchaser
    OPNI (Objet Programmant Non Identifié)
    Décembre 2004
    Activité : OPNI (Objet Programmant Non Identifié)
    Secteur : Industrie Pharmaceutique
    Juste au cas ou, et ceci n'a peut être rien a voir avec l'erreur première:
    . la valeur passée dans le to_date est bonne ?
    Je suis étonné par le "déc.", que j'aurais imaginé plus en rapport avec le format date indiqué si c'était "déc" (sans le point donc, et encore, "dec").
    Avatar de Waldar
    Citation Envoyé par Tybaal Voir le message
    Merci d'avance.
    Il y a une erreur de syntaxe, cf. ligne 74 de votre script.
    Juillet 2011
    Merci bien, désolé pour le dérangement
    Juillet 2011
    En fait j'ai un léger petit souci (désolé je ne suis pas expert en oracle), mais après avoir corrigé l'erreur, je lance le script qui s'exécute correctement, mais aucune ligne n'est entrée dans ma vue, elle est bien créée mais vide, alors qu'il devrait y avoir des données.
    Y a t il quelque chose dans le script qui pourrait faire que les données ne sont pas entrées ?
    Merci pour votre aide.
    Juillet 2011
    oups, c'est bon j'avais fait une petite faute.
    BUILD IMMEDIATE au lieu de BUILD DEFERRED.
  1. Réponses: 6
    Dernier message: 06/09/2016, 14h39
  2. Réponses: 2
    Dernier message: 09/12/2008, 22h38
  3. Création d'une vue matérialisée et erreur ORA-01630
    Par beurtom dans le forum Administration
    Dernier message: 23/02/2007, 13h27
  4. Réponses: 26
    Dernier message: 27/04/2005, 12h29
  5. Fonctionnement et utilisation des vues matérialisées
    Par gOgHi dans le forum Administration
    Dernier message: 19/10/2004, 15h29
