Je rencontre un problème très embêtant avec les accents lors de la réponse d'un webservice.
Toute mon appli est en ISO-8859-1 mais lorsque j'appelle mon webservice, il me dit que je suis en UTF-8
Voici mon code:
WSDL:
Appel du webservice:
47 <wsdl:definitions name="enf_creation_dmp" targetNamespace="" xmlns="" xmlns:http-conf="http://cxf.apache.org/transports/http/configuration" xmlns:mime="http://schemas.xmlsoap.org/wsdl/mime/" xmlns:soap="http://schemas.xmlsoap.org/wsdl/soap/" xmlns:wsdl="http://schemas.xmlsoap.org/wsdl/" xmlns:xs="http://www.w3.org/2001/XMLSchema"> <wsdl:types> <schema xmlns="http://www.w3.org/2001/XMLSchema"> <include schemaLocation="enf_dmp_creation0.3.xsd"/> </schema> </wsdl:types> <wsdl:message name="enf_dmp_creationInput"> <wsdl:part element="enf_dmp_creation" name="body"/> </wsdl:message> <wsdl:message name="enf_dmp_creationOutput"> <wsdl:part element="enf_dmp_creation" name="body"/> </wsdl:message> <wsdl:portType name="enf_creation_dmpPortType"> <wsdl:operation name="enf_creation_dmp"> <wsdl:input message="enf_dmp_creationInput"/> <wsdl:output message="enf_dmp_creationOutput"/> </wsdl:operation> </wsdl:portType> <wsdl:binding name="enf_creation_dmpBinding" type="enf_creation_dmpPortType"> <soap:binding style="document" transport="http://schemas.xmlsoap.org/soap/http"/> <wsdl:operation name="enf_creation_dmp"> <soap:operation soapAction="enf_creation_dmp"/> <wsdl:input> <soap:body use="literal" /> </wsdl:input> <wsdl:output> <soap:body use="literal"/> </wsdl:output> </wsdl:operation> </wsdl:binding> <wsdl:service name="enf_creation_dmp"> <wsdl:documentation>IB Soap service</wsdl:documentation> <wsdl:port binding="enf_creation_dmpBinding" name="enf_creation_dmpPort"> <soap:address location="http://..."/> <http-conf:client ReceiveTimeout="300000" /> </wsdl:port> </wsdl:service> </wsdl:definitions>
Classe JAXB:
14 ... try { // Serialization xmlMapper.writeObjectToXml(dmpCreation, filename); //Création de l'objet que l'on va envoyer au webservice EnfDmpCreation enfDmpCreation = new EnfDmpCreation(); enfDmpCreation = (EnfDmpCreation) xmlMapper.readObjectFromXml(filename); //Appel du webservice Holder<EnfDmpCreation> holderEnfDmpCreation = new Holder<EnfDmpCreation>(enfDmpCreation); wsCreationDMP.enfCreationDmp(holderEnfDmpCreation); ...
Et voici mes logs:
44 public void writeObjectToXml(Object object, String filename) throws IOException { FileOutputStream fos = null; try { //On change l'encoding par défaut pour les accents Map<String, String> marshallerProperties = new HashMap<String, String>(); marshallerProperties.put(Marshaller.JAXB_ENCODING, "ISO-8859-1"); jaxbMarshaller.setMarshallerProperties(marshallerProperties); fos = new FileOutputStream(filename); jaxbMarshaller.marshal(object, new StreamResult(fos)); fos.close(); } catch (XmlMappingException e) { log.error("Xml-Serialization failed due to an XmlMappingException.", e); } catch (IOException e) { log.error("Xml-Serialization failed due to an IOException.", e); } finally { if (fos != null) { fos.close(); } } } public Object readObjectFromXml(String filename) throws IOException { FileInputStream fis = null; try { //On change l'encoding par défaut pour les accents Map<String, String> marshallerProperties = new HashMap<String, String>(); marshallerProperties.put(Marshaller.JAXB_ENCODING, "ISO-8859-1"); jaxbMarshaller.setMarshallerProperties(marshallerProperties); fis = new FileInputStream(filename); Object obj = jaxbMarshaller.unmarshal(new StreamSource(fis)); fis.close(); return obj; } catch (IOException e) { log.error("Xml-Deserialization failed due to an IOException.", e); } finally { if (fis != null) { fis.close(); } } return null; }
Donc comment faire pour être en ISO-8859-1 et ainsi avoir mes accents?Infos: Outbound Message
Address: http://192.168.1.24:20210/IB/servlet...d=HELLODMP_XML
Encoding: UTF-8
Content-Type: text/xml
Headers: {Accept=[*/*], Accept-Encoding=[ISO-8859-1], Accept-Language=[ISO-8859-1], Connection=[Keep-Alive], SOAPAction=["enf_creation_dmp"]}
Payload: <soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/"><soap:Body><ns2:enf_dmp_creation xmlns:ns2="http://cxf/" type="creation">...</ns2:enf_dmp_creation></soap:Body></soap:Envelope>
nov. 09, 2011 12:07:02 PM org.apache.cxf.interceptor.AbstractLoggingInterceptor log
Infos: Inbound Message
Response-Code: 200
Encoding: UTF-8
Content-Type: text/xml;charset=utf-8
Headers: {Accept=[text/xml, text/html, image/gif, image/jpeg, *; q=.2, */*; q=.2], Content-Length=[798], content-type=[text/xml;charset=utf-8], Date=[Wed, 09 Nov 2011 11:06:57 GMT], Root.Content-Type=[text/xml], Server=[Apache-Coyote/1.1]}
Payload: <SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/"><SOAP-ENV:Body><ns2:enf_dmp_creation xmlns:ns2="http://cxf/" type="creation">...</ns2:enf_dmp_creation></SOAP-ENV:Body></SOAP-ENV:Envelope>
