Salut
en exécutant mon projet j'ai l'erreur suivante
5324 oct. 2011 19:28:36 org.apache.catalina.core.AprLifecycleListener init INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: .:/Library/Java/Extensions:/System/Library/Java/Extensions:/usr/lib/java 24 oct. 2011 19:28:36 org.apache.tomcat.util.digester.SetPropertiesRule begin ATTENTION: [SetPropertiesRule]{Server/Service/Engine/Host/Context} Setting property 'source' to 'org.eclipse.jst.jee.server:Hib1' did not find a matching property. 24 oct. 2011 19:28:36 org.apache.tomcat.util.digester.SetPropertiesRule begin ATTENTION: [SetPropertiesRule]{Server/Service/Engine/Host/Context} Setting property 'source' to 'org.eclipse.jst.jee.server:Atelier1STRUTS' did not find a matching property. 24 oct. 2011 19:28:36 org.apache.coyote.AbstractProtocol init INFO: Initializing ProtocolHandler ["http-bio-8080"] 24 oct. 2011 19:28:36 org.apache.coyote.AbstractProtocol init INFO: Initializing ProtocolHandler ["ajp-bio-8009"] 24 oct. 2011 19:28:36 org.apache.catalina.startup.Catalina load INFO: Initialization processed in 536 ms 24 oct. 2011 19:28:36 org.apache.catalina.core.StandardService startInternal INFO: Démarrage du service Catalina 24 oct. 2011 19:28:36 org.apache.catalina.core.StandardEngine startInternal INFO: Starting Servlet Engine: Apache Tomcat/7.0.21 24 oct. 2011 19:28:37 org.apache.coyote.AbstractProtocol start INFO: Starting ProtocolHandler ["http-bio-8080"] 24 oct. 2011 19:28:37 org.apache.coyote.AbstractProtocol start INFO: Starting ProtocolHandler ["ajp-bio-8009"] 24 oct. 2011 19:28:37 org.apache.catalina.startup.Catalina start INFO: Server startup in 402 ms 24 oct. 2011 19:28:49 org.apache.catalina.core.ApplicationContext log INFO: La servlet PersonneServlet est marqué comme indisponible 24 oct. 2011 19:28:49 org.apache.catalina.core.StandardWrapperValve invoke GRAVE: Exception lors de l'allocation pour la servlet PersonneServlet java.lang.ClassNotFoundException: mpkg.presentation.PersonneServlet.java at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1678) at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1523) at org.apache.catalina.core.DefaultInstanceManager.loadClass(DefaultInstanceManager.java:415) at org.apache.catalina.core.DefaultInstanceManager.loadClassMaybePrivileged(DefaultInstanceManager.java:397) at org.apache.catalina.core.DefaultInstanceManager.newInstance(DefaultInstanceManager.java:118) at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:1099) at org.apache.catalina.core.StandardWrapper.allocate(StandardWrapper.java:836) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:135) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:185) at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:151) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:100) at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:929) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:405) at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:269) at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:515) at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:302) at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908) at java.lang.Thread.run(Thread.java:680) 24 oct. 2011 19:30:17 org.apache.catalina.core.StandardContext reload INFO: Le rechargement du contexte [/Hib1] a démarré 24 oct. 2011 19:30:17 org.apache.catalina.core.StandardContext reload INFO: Le rechargement de ce contexte est terminé
Mon web.xml est
16 <welcome-file-list> <welcome-file>Index.html</welcome-file> </welcome-file-list> <servlet> <servlet-name>PersonneServlet</servlet-name> <servlet-class>mpkg.presentation.PersonneServlet.java</servlet-class> </servlet> <servlet-mapping> <servlet-name>PersonneServlet</servlet-name> <!-- Li drna f jsp --> <url-pattern>/AjouterUnePersonne</url-pattern> </servlet-mapping>
la librairie Tamcat 7 est inclus dans javabuildpath je comprend pas ce qui cloche
