1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
%demodulation
function x = FMdemod(y,beta)
[r, c] = size(y);
if r*c == 0
y = [];
return;
end;
if (r == 1)
y = y(:);
len = c;
else
len = r;
end;
Fc = 40000;
Fs = 8000*20;
pi2 = 2*pi;
[num, den] = butter(5, Fc * 2 / Fs);
sen = 2*pi*beta*100;
%pre-process the filter.
if abs(den(1)) < eps
error('First denominator filter coefficient must be non-zero.');
else
num = num/den(1);
if (length(den) > 1)
den = - den(2:length(den)) / den(1);
else
den = 0;
end;
num = num(:)';
den = den(:)';
end;
len_den = length(den);
len_num = length(num);
x = y;
y = 2 * y;
ini_phase = pi/2;
for ii = 1 : size(y, 2)
z1 = zeros(length(den), 1);
s1 = zeros(len_num, 1);
intgl = 0;
memo = 0;
for i = 1:size(y, 1)
%start with the zero-initial condition integer.
vco_out = cos(pi2 * intgl+ini_phase);
if len_num > 1
s1 = [y(i, ii) * vco_out; s1(1:len_num-1)];
else
s1 = y(i, ii);
end
tmp = num * s1 + den * z1;
if len_den > 1
z1 = [tmp; z1(1:len_den-1)];
else
z1 = tmp;
end;
intgl = rem(((tmp*sen + Fc)/ Fs + intgl), 1);
x(i, ii) = tmp;
end;
end;
x = x;
x = decimate(x,20); |
