| 12
 119
 120
 121
 122
 123
 124
 125
 126
 127
 128
 129
 130
 131
 132
 133
 134
 135
 136
 137
 138
 139
 140
 141
 142
 143
 144
 145
 146
 147
 148
package videobd;
import java.util.List;
import org.hibernate.LockMode;
import org.hibernate.Query;
import org.hibernate.criterion.Example;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
 * A data access object (DAO) providing persistence and search support for
 * Realisateurs entities. Transaction control of the save(), update() and
 * delete() operations can directly support Spring container-managed
 * transactions or they can be augmented to handle user-managed Spring
 * transactions. Each of these methods provides additional information for how
 * to configure it for the desired type of transaction control.
 * @see videobd.Realisateurs
 * @author MyEclipse Persistence Tools
public class RealisateursDAO extends BaseHibernateDAO {
	private static final Logger log = LoggerFactory
			.getLogger(RealisateursDAO.class);
	// property constants
	public static final String NOM_REALISATEUR = "nomRealisateur";
	public static final String PRENOM_REALISATEUR = "prenomRealisateur";
	public void save(Realisateurs transientInstance) {
		log.debug("saving Realisateurs instance");
		try {
			getSession().save(transientInstance);
			log.debug("save successful");
		} catch (RuntimeException re) {
			log.error("save failed", re);
			throw re;
	public void delete(Realisateurs persistentInstance) {
		log.debug("deleting Realisateurs instance");
		try {
			getSession().delete(persistentInstance);
			log.debug("delete successful");
			log.error("delete failed", re);
			throw re;
	public Realisateurs findById(java.lang.Integer id) {
		log.debug("getting Realisateurs instance with id: " + id);
		try {
			Realisateurs instance = (Realisateurs) getSession().get(
					"videobd.Realisateurs", id);
			return instance;
			log.error("get failed", re);
			throw re;
	public List findByExample(Realisateurs instance) {
		log.debug("finding Realisateurs instance by example");
		try {
			List results = getSession().createCriteria("videobd.Realisateurs")
					.add(Example.create(instance)).list();
			log.debug("find by example successful, result size: "
					+ results.size());
			return results;
			log.error("find by example failed", re);
			throw re;
	public List findByProperty(String propertyName, Object value) {
		log.debug("finding Realisateurs instance with property: "
				+ propertyName + ", value: " + value);
		try {
			String queryString = "from Realisateurs as model where model."
					+ propertyName + "= ?";
			Query queryObject = getSession().createQuery(queryString);
			queryObject.setParameter(0, value);
			return queryObject.list();
			log.error("find by property name failed", re);
			throw re;
	public List findByNomRealisateur(Object nomRealisateur) {
		return findByProperty(NOM_REALISATEUR, nomRealisateur);
	public List findByPrenomRealisateur(Object prenomRealisateur) {
		return findByProperty(PRENOM_REALISATEUR, prenomRealisateur);
	public List findAll() {
		log.debug("finding all Realisateurs instances");
		try {
			String queryString = "from Realisateurs";
			log.error("find all failed", re);
			throw re;
	public Realisateurs merge(Realisateurs detachedInstance) {
		log.debug("merging Realisateurs instance");
		try {
			Realisateurs result = (Realisateurs) getSession().merge(
					detachedInstance);
			log.debug("merge successful");
			return result;
			log.error("merge failed", re);
			throw re;
	public void attachDirty(Realisateurs instance) {
		log.debug("attaching dirty Realisateurs instance");
		try {
			getSession().saveOrUpdate(instance);
			log.debug("attach successful");
			log.error("attach failed", re);
			throw re;
	public void attachClean(Realisateurs instance) {
		log.debug("attaching clean Realisateurs instance");
		try {
			getSession().lock(instance, LockMode.NONE);
			throw re;
