[Swing] Dessin progressif d'un cercle : améliorations de mon code
    Avatar de tails
    Novembre 2003
    Par défaut [Swing] Dessin progressif d'un cercle : améliorations de mon code
    Bonjour, j'ai écrit une classe JFrame permettant, lorsque l'on appuie sur un bouton, d'animer le dessin d'un cercle plein rose sur fond jaune. Toutefois, j'ai besoin de votre aide sur quelques points.
    package org.isgreat.loloof64.j2se.oval_progressive;
    import java.awt.BorderLayout;
    import java.awt.Color;
    import java.awt.Component;
    import java.awt.Graphics;
    import java.awt.event.ActionEvent;
    import java.awt.event.ActionListener;
    import javax.swing.JButton;
    import javax.swing.JFrame;
    import javax.swing.JPanel;
    public class OvalProgressive extends JFrame {
    		new OvalProgressive().setVisible(true);
    	public OvalProgressive() {
    		super("Oval Progressive application");
    		setSize(WIDTH, HEIGHT);
    		setLocationRelativeTo(CENTER_RELATIVE);
    		setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
    		JPanel southPanel = new JPanel();
    		southPanel.add(startButton);
    		add(southPanel, BorderLayout.SOUTH);
    		startButton.addActionListener(new ActionListener() {
    			@Override
    			public void actionPerformed(ActionEvent actionEvent) {
    				new TimeSimulator().start();
    		computeOvalOffsets();
    	@Override
    	public void paint(Graphics graphics) {
    		super.paint(graphics);
    		graphics.setColor(BACKGROUND);
    		graphics.fillRect(0, 0, WIDTH, HEIGHT);
    		graphics.setColor(OVAL_COLOR);
    		graphics.fillArc(ovalOffsetX, ovalOffsetY, OVAL_DIAMETER, OVAL_DIAMETER,
    				START_ANGLE, (int) (-timePart*360) );
    	private void computeOvalOffsets(){
    		ovalOffsetX = ( getWidth() - OVAL_DIAMETER ) / 2;
    		ovalOffsetY = ( getHeight() - OVAL_DIAMETER ) / 2;
    	private void buttonStateBecomeStart() {
    		startButton.setText("Start");
    		startButton.setEnabled(true);
    	private void buttonStateBecomeWaiting() {
    		startButton.setText("Please Wait...");
    		startButton.setEnabled(false);
    	private class TimeSimulator extends Thread {
    		@Override
    		public void run() {
    			buttonStateBecomeWaiting();
    			while(timePart < 1.0f){
    				try {
    					Thread.sleep(DELAY_MILLIS);
    				} catch (InterruptedException e) {
    					e.printStackTrace();
    				timePart += TIME_ATOMIC_INCREMENT;
    				repaint();
    			buttonStateBecomeStart();
    	private static final int WIDTH = 200;
    	private static final int HEIGHT = 230;
    	private static final int OVAL_DIAMETER = 130;
    	private static final int START_ANGLE = 0;
    	private static int ovalOffsetX;
    	private static int ovalOffsetY;
    	private static float timePart = 0;
    	private static final Component CENTER_RELATIVE = null;
    	private static final Color BACKGROUND = Color.YELLOW;
    	private static final Color OVAL_COLOR = Color.PINK;
    	private JButton startButton = new JButton("Start");
    	private static final long DELAY_MILLIS = 100;
    	private static final float TIME_ATOMIC_INCREMENT = 0.025f;
    	private static final long serialVersionUID = 1L;
    Je voudrais hériter de vos conseils sur les points suivants :
    1) Le bouton disparait pendant l'animation du cercle
    2) Le flickering omniprésent
    3) Le bouton se situe dans un rectangle blanc à la fin de l'animation
    4) Pas moyen d'effacer le cercle affiché, à la fin de l'animation. La seule solution à laquelle j'ai pensée était buggué. Elle consistait à ajouter la section suivante à la fin de la méthode run() de la classe privée TimeSimulator, juste avant l'appel buttonStateBecomeStart(); :
    Graphics graphics = getGraphics();
    OvalProgressive.super.paint(graphics);
    Avatar de slim_java
    Enseignant
    Activité : Enseignant
    je préfére ne pas faire le dessin du rectangle
    dans la méthode paint qui peut ralentir le dessin d’après ce que j'ai compris de tes questions.
    Avatar de tails
    Novembre 2003
    Par défaut J'ai du mal à trouver les bonnes méthodes
    Bonjour et merci beaucoup de m'avoir répondu
    Etant donné que je faisais dans le dessin personnalisé d'un composant, je me trompe toujours dans le choix des méthodes où je définis mes codes.
    J'ai en effet hésité entre paint(Graphics) et paintComponent(Graphics) : mais je je suis pas encore sûr que paintComponent(Graphics) changera grand chose.
    Je pense que j'aurais carrément dû utiliser un JPanel et rédéfinir la méthode paint(Graphics) (ce m'est venu à l'esprit au moment d'écrire ce message) : je pense qu'à force de programmer pour Android, je perds me repères en J2SE.
    En tous cas merci beaucoup
    Avatar de tails
    Novembre 2003
    Par défaut Ca y est :)
    Je confirme que pour obtenir le résultat attendu, il fallait bien utiliser un JPanel.
    Voici le code final, un peu tiré par les cheveux, je le reconnais :
    		centerPanel = new OvalPanel();
    		add(centerPanel, BorderLayout.CENTER);
    			@Override
    	private void resetOval() {
    		timePart = 0;
    		ovalOffsetX = ( centerPanel.getWidth() - OVAL_DIAMETER ) / 2;
    		ovalOffsetY = ( centerPanel.getHeight() - OVAL_DIAMETER ) / 2;
    		@Override
    		public void run() {
    				try {
    				centerPanel.repaint();
    			resetOval();
    	private class OvalPanel extends JPanel
    		@Override
    			graphics.fillRect(0, 0, getWidth(), getHeight());
    					OVAL_DIAMETER, START_ANGLE, (int) (-timePart * 360));
    	private OvalPanel centerPanel;
  1. [SWING]Dessiner sur un composant
    Par Tarteens dans le forum AWT/Swing
    Réponses: 22
    Dernier message: 02/07/2007, 11h50
  2. Dessiner un arc de cercle autour d'une picturebox
    Par WindowsVista dans le forum VB.NET
    Dernier message: 11/06/2007, 12h48
  3. [SWING][Dessin] Effet de répétition non désiré
    Par Invité dans le forum AWT/Swing
    Réponses: 18
    Dernier message: 11/12/2006, 11h23
  4. Réponses: 1
    Dernier message: 21/11/2006, 18h00
  5. [swing] Dessiner contour d'un composant
    Par issou dans le forum AWT/Swing
    Dernier message: 01/03/2006, 12h57
