Convertir requête PostgreSQL en Oracle
    Juin 2005
    Par défaut Convertir requête PostgreSQL en Oracle
    Bonjour je veux creer traduire cette requéte creer en postgres en oracle
    CREATE OR REPLACE VIEW rm_documents_view AS
    SELECT
        rm_documents.*,
        rm_items.archival_agency_it_ident,
        rm_items.description_language,
        rm_items.name,
        rm_items.item_type,
        rm_items.originating_agency_it_ident,
        rm_items.service_level,
        rm_items.transferring_agency_it_ident,
        rm_items.schedule_id,
        rm_content_descriptions.description as content_description,
        rm_content_descriptions.description_level,
        rm_content_descriptions.file_plan_position,
        rm_content_descriptions.language,
        rm_content_descriptions.latest_date,
        rm_content_descriptions.oldest_date,
        rm_content_descriptions.other_descriptive_data,
        rm_custodial_history.custodial_history_item,
        doctypes.description as type_label,
        doctypes_first_level.doctypes_first_level_id,
        doctypes_first_level.doctypes_first_level_label,
        doctypes_first_level.css_style as doctype_first_level_style,
        doctypes_second_level.doctypes_second_level_id,
        doctypes_second_level.doctypes_second_level_label,
        doctypes_second_level.css_style as doctype_second_level_style,
        file_plan_position.folders_system_id,
    	schedule.folder_id as schedule_name,
        originating_agency.identification as originating_ag_ident,
        originating_agency.entity_id as originating_ag_entity_id,
        originating_agency.name as originating_ag_name,
        rm_contacts.department_name as dest_user,
        rm_appraisal_rules.code as appraisal_code,
        rm_appraisal_rules.duration as appraisal_duration,
        rm_appraisal_rules.start_date as appraisal_start_date,
        rm_access_restriction_rules.code as access_restriction_code,
        rm_access_restriction_rules.start_date as access_restrict_start_date
    FROM rm_documents
        LEFT JOIN rm_items on rm_items.item_id = rm_documents.item_id
        LEFT JOIN rm_content_descriptions on rm_items.item_id = rm_content_descriptions.item_id
        LEFT JOIN rm_custodial_history on rm_items.item_id = rm_custodial_history.item_id
        LEFT JOIN doctypes on rm_documents.type_id = doctypes.type_id
        LEFT JOIN doctypes_first_level ON doctypes.doctypes_first_level_id = doctypes_first_level.doctypes_first_level_id
        LEFT JOIN doctypes_second_level ON doctypes.doctypes_second_level_id = doctypes_second_level.doctypes_second_level_id
        LEFT JOIN rm_organizations AS originating_agency ON originating_agency.organization_id =
            SELECT organization_id
            FROM rm_organizations
            WHERE rm_organizations.parent_id = rm_items.item_id AND rm_organizations.role = 'OriginatingAgency'
            ORDER BY organization_id
            LIMIT 1
        LEFT JOIN rm_contacts on originating_agency.organization_id = rm_contacts.organization_id and contact_id =
            SELECT contact_id
            FROM rm_contacts
            WHERE rm_contacts.organization_id = originating_agency.organization_id
            ORDER BY contact_id
            LIMIT 1
        LEFT JOIN rm_appraisal_rules ON rm_appraisal_rules.parent_id = rm_items.item_id
        LEFT JOIN rm_access_restriction_rules ON rm_access_restriction_rules.parent_id = rm_items.item_id
        LEFT JOIN folders file_plan_position ON rm_content_descriptions.file_plan_position = file_plan_position.folder_id AND foldertype_id = '101'
        LEFT JOIN folders schedule ON rm_items.schedule_id = schedule.folders_system_id
    WHERE item_type = 'ArchiveObject';
    et j'ai cette erreur
    Erreur à la ligne de commande : 63, colonne : 8
    Rapport d'erreur :
    Erreur SQL : ORA-00907: parenthèse de droite absente
    00907. 00000 - "missing right parenthesis"
    *Cause:
    *Action:
    Membre Expert Avatar de ojo77
    Architecte de base de données
    Décembre 2010
    Activité : Architecte de base de données
    Remplacez les Select ... From ... where ... order by .... limit 1 sur le modèle suivant :
    LIMIT 1
    Select min(organization_id)
    Avatar de al1_24
    Retraité
    Mai 2002
    Activité : Retraité
    C'est la forme des sous-requête qui n'est pas adaptée.
    il faudrait remplacer
    LIMIT 1
    par
    SELECT  MIN(organization_id)
    Modérateur Langage SQL
    [code]
    Juin 2005
    maintenant voila ce que j'ai comme erreur:
    CREATE OR REPLACE VIEW drs.rm_documents_view AS
    SELECT
        rm_documents.*,
        drs.rm_items.archival_agency_it_ident,
        drs.rm_items.description_language,
        drs.rm_items.name,
        drs.rm_items.item_type,
        drs.rm_items.originating_agency_it_ident,
        drs.rm_items.service_level,
        drs.rm_items.transferring_agency_it_ident,
        drs.rm_items.schedule_id,
        drs.rm_content_descriptions.description as content_description,
        drs.rm_content_descriptions.description_level,
        drs.rm_content_descriptions.file_plan_position,
        drs.rm_content_descriptions.language,
        drs.rm_content_descriptions.latest_date,
        drs.rm_content_descriptions.oldest_date,
        drs.rm_content_descriptions.other_descriptive_data,
        drs.rm_custodial_history.custodial_history_item,
        drs.doctypes.description as type_label,
        drs.doctypes_first_level.doctypes_first_level_id,
        drs.doctypes_first_level.doctypes_first_level_label,
        drs.doctypes_first_level.css_style as doctype_first_level_style,
        drs.doctypes_second_level.doctypes_second_level_id,
        drs.doctypes_second_level.doctypes_second_level_label,
        drs.doctypes_second_level.css_style as doctype_second_level_style,
        drs.file_plan_position.folders_system_id,
    	drs.schedule.folder_id as schedule_name,
        drs.originating_agency.identification as originating_ag_ident,
        drs.originating_agency.entity_id as originating_ag_entity_id,
        drs.originating_agency.name as originating_ag_name,
        drs.rm_contacts.department_name as dest_user,
        drs.rm_appraisal_rules.code as appraisal_code,
        drs.rm_appraisal_rules.duration as appraisal_duration,
        drs.rm_appraisal_rules.start_date as appraisal_start_date,
        drs.rm_access_restriction_rules.code as access_restriction_code,
        drs.rm_access_restriction_rules.start_date as access_restrict_start_date
    FROM drs.rm_documents
        LEFT JOIN drs.rm_items on drs.rm_items.item_id = drs.rm_documents.item_id
        LEFT JOIN drs.rm_content_descriptions on drs.rm_items.item_id = drs.rm_content_descriptions.item_id
        LEFT JOIN drs.rm_custodial_history on drs.rm_items.item_id = drs.rm_custodial_history.item_id
        LEFT JOIN drs.doctypes on drs.rm_documents.type_id = drs.doctypes.type_id
        LEFT JOIN drs.doctypes_first_level ON drs.doctypes.doctypes_first_level_id = drs.doctypes_first_level.doctypes_first_level_id
        LEFT JOIN drs.doctypes_second_level ON drs.doctypes.doctypes_second_level_id = drs.doctypes_second_level.doctypes_second_level_id
        LEFT JOIN drs.rm_organizations  originating_agency ON drs.originating_agency.organization_id =
          FROM    drs.rm_organizations
          WHERE   drs.rm_organizations.parent_id = drs.rm_items.item_id
          AND drs.rm_organizations.role = 'OriginatingAgency'
        LEFT JOIN drs.rm_contacts on drs.originating_agency.organization_id = drs.rm_contacts.organization_id and contact_id =
            SELECT MIN(contact_id)
            FROM drs.rm_contacts
            WHERE drs.rm_contacts.organization_id = drs.originating_agency.organization_id
        LEFT JOIN drs.rm_appraisal_rules ON drs.rm_appraisal_rules.parent_id = rm_items.item_id
        LEFT JOIN drs.rm_access_restriction_rules ON drs.rm_access_restriction_rules.parent_id = drs.rm_items.item_id
        LEFT JOIN drs.folders file_plan_position ON drs.rm_content_descriptions.file_plan_position = drs.file_plan_position.folder_id AND foldertype_id = '101'
        LEFT JOIN drs.folders schedule ON drs.rm_items.schedule_id = drs.schedule.folders_system_id
    Erreur à la ligne de commande : 1, colonne : 0
    Rapport d'erreur :
    Erreur SQL : ORA-01799: une colonne ne peut pas être jointe extérieurement à une sous-interrogation
    01799. 00000 - "a column may not be outer-joined to a subquery"
    *Cause: <expression>(+) <relop> (<subquery>) is not allowed.
    *Action: Either remove the (+) or make a view out of the subquery.
    In V6 and before, the (+) was just ignored in this case.
    Octobre 2007
    Votre jointure avec la sous-requête d'origine
            LIMIT 1
    doit être réecrite de la façon
    Left Join
            Select t.*
              From (
                      SELECT organization_id,
                             parent_id,
                             role,
                             identification,
                             name,
                             entity_id
                             row_number() over (partition by parent_id order by organization_id) rn
                      WHERE rm_organizations.role = 'OriginatingAgency'
                   )  t
             Where t.rn = 1
            ) originating_agency
        On originating_agency.organization_id = rm_items.item_id
    Juin 2005
    je ne comprend pas vraiment que represente le select t*?
    Octobre 2007
    Vous sélectionnez toutes les colonnes de la table qui vous intéresse, vous les attribuées un rang en les ordonnant de la manière souhaité et vous gardez le premier enregistrement (top N).
  1. Construction d'une requête "imbriquée" avec Oracle
    Par kyra78 dans le forum Langage SQL
    Dernier message: 05/02/2008, 15h29
  2. requêtes Perl sur oracle et sybae (serveurs Linux)
    Par super_dz dans le forum Langage
    Dernier message: 28/04/2007, 13h41
  3. Date+delai dans une requête PostGresql
    Par bobic dans le forum PostgreSQL
    Dernier message: 12/03/2007, 13h11
  4. Problème de requête récursive sous Oracle 10
    Par boulgom12 dans le forum Oracle
    Dernier message: 13/12/2006, 10h54
  5. Réponses: 7
    Dernier message: 24/08/2006, 09h28
