Probleme d'utilisation du generator "for"
    Septembre 2004
    Par défaut Probleme d'utilisation du generator "for"
    Quelle différence(s) entre mes classes obj et Coord empêche(nt) d'utiliser le generator "for" comme il se doit?
    119
    120
    121
    122
    123
    124
    125
    126
    127
    128
    129
    130
    131
    132
    133
    134
    135
    136
    137
    138
    139
    140
    141
    142
    143
    144
    145
    146
    147
    148
    149
    150
    151
    152
    153
    154
    155
    156
    157
    158
    159
    160
    161
    162
    163
    164
    165
    166
    167
    168
    169
    170
    171
    172
    173
    174
    175
    176
    177
    178
    179
    #!/usr/bin/python
    # *-* coding:UTF-8 *-*
    class Coord(tuple):
    	def __new__(cls,*arg):
    		r=tuple.__new__(cls,arg[0]) if len(arg)==1 else tuple.__new__(cls,arg)
    		return r
    	def __init__(self,*arg):
    		self.__coord=arg[0] if len(arg)==1 else list(arg)
    		self.__dim=len(self.coord)
            @property
    	def coord(self):
    		return self.__coord
            @property
    	def dim(self):
    		return self.__dim
            @coord.setter
    	def coord(self,add):
    		print "Erreur!!"
            @coord.deleter
    	def coord(self):
    		print "Erreur!!"
    	#Surcharges
    	def __str__(self):
    		return 'Coord'+str(tuple(self.coord))
    	def __hash__(self):
    		v=0
    		pw=self.dim-1
    		for c in self.__coord:
    			v+=c*10**pw
    			pw-=1
    		return v
    	def __add__(self,other):
    		if not isinstance(other,Coord):
    			print "Erreur!!"
    		else:
    			gt=self if self.dim >= other.dim else other
    			lt=other if other.dim <= self.dim else self
    #			print ("gt=%s, lt=%s" % (gt,lt))
    			ad=gt.dim-lt.dim
    			val=()
    			resized=lt.coord
    			if ad!=0:
    				for c in xrange(ad):
    					resized+=0,
    			for v1,v2 in zip(gt.coord,resized):
    				val+=v1+v2,
    			return Coord(val)
    	def __sub__(self,other):
    			print "Erreur!!"
    		else:
    			fct=-1 if other.dim>self.dim else 1
    			ad=gt.dim-lt.dim
    			val=()
    			resized=lt.coord
    			if ad!=0:
    					resized+=0,
    				val+=(v1-v2)*fct,
    			return Coord(val)
    	def __mul__(self,other):
    			print "Erreur!!"
    		else:
    			ad=gt.dim-lt.dim
    			val=()
    			resized=lt.coord
    			if ad!=0:
    					resized+=0,
    				val+=v1*v2,
    			return Coord(val)
    	def __eq__(self,other):
    			print "Erreur!"
    		else:
    			return self.coord==other.coord
    	def __ne__(self,other):
    			print "Erreur!"
    		else:
    			return self.coord!=other.coord
    	def __gt__(self,other):
    			print "Erreur!!"
    		else:
    			return self.__hash__()>other.__hash__()
    	def __ge__(self,other):
    			print "Erreur!!"
    		else:
    			return self.__hash__()>=other.__hash__()
    	def __lt__(self,other):
    			print "Erreur!!"
    		else:
    			return self.__hash__()<other.__hash__()
    	def __le__(self,other):
    			print "Erreur!!"
    		else:
    			return self.__hash__()<=other.__hash__()
    def step(c_min,c_max):
    	#TODO test de validite des arguments
    	t_min,t_max=list(c_min.coord),list(c_max.coord)
    	l_min,l_max,ret_list,mods=[],[],[],[]
    	for v1,v2 in zip(t_min,t_max):
    		l_min.append(min([v1,v2]))
    		ret_list.append(min([v1,v2]))
    		l_max.append(max([v1,v2]))
    #	print "l_min-->",l_min,"\nl_max-->",l_max,"\nret_list-->",ret_list
    	max_click,count=1,1
    	for mn,mx in zip(l_min,l_max):
    		mods.append(abs(max_click))
    		max_click*=abs(mx-mn)+1
    #	print "max_click-->",max_click,"\nmods-->",mods
    	while count<=max_click:
    		for i in xrange(len(l_min)):
    			if not count%mods[i]:
    				#print ("not %d%%%d = %s" % (count,mods[i],not count%mods[i]))
    				ret_list[i]=ret_list[i]+1 if ret_list[i]<l_max[i] else l_min[i]
    				#print ("ret_list[%d]<l_max[%d] = %s  l_min[%d] = %s" % (i,i,ret_list[i]<l_max[i],i,l_min[i]))
    				#print ("ret_list[%d] = %s" % (i,ret_list[i]))
    		yield Coord(ret_list)
    		count+=1
    class obj(object):
    	oid=1
    	def __init__(self):
    		self.oid=obj.oid
    		obj.oid+=1
    	def __str__(self):
    		return ("obj.%d" % self.oid)
    	def __repr__(self):
    	def __hash__(self):
    		return self.oid
    def robj(mx):
    	count=1
    	while count<=mx:
    		yield obj()
    		count+=1
    class mini_field():
    	def __init__(self):
    		self.__d={}
    		for c in step(Coord(1,1),Coord(1,4)):
    			self.__d[c]=c
    		for o in robj(4):
    			self.__d[o]=o
            @property
    	def d(self):
    		return self.__d
    if __name__=='__main__':
    	f=mini_field()
    	for k in f.d:
    		print k,f.d[k]
    	print f.d.keys()
    Voici ce que j'obtiens en sortie:
    obj.1 obj.1
    obj.2 obj.2
    obj.3 obj.3
    obj.4 obj.4
    Coord(1, 1) Coord(1, 1)
    [obj.1, obj.2, obj.3, obj.4, (1, 1), (1, 2), (1, 3), (1, 4)]
    Je ne retrouve plus les clés de type Coord en passant par un generator...
    Architecte technique retraité
    Juin 2008
    Lorsque vous faites print f.d.keys() çà affiche la liste f.d.keys()...
    Normal: on applique str sur la liste.
    Vous souhaiteriez que le str s'applique aux éléments de la liste...
    Ca ne fonctionne pas comme çà, snif?
    Pour vous en convaincre:
    >>class A:
    >>    def __str__(self): return 'A'
    >> li = [ 1, 2, 3, A() ]
    >> print li
    [1, 2, 3, <__main__.A instance at 0x28c8c8>]
    >>> print ', '.join(str(e) for e in li)
    1, 2, 3, A
    -W
    Architectures post-modernes.
    Septembre 2004
    Les problèmes de mise en forme ne me dérange guère. Ce que je trouve beaucoup plus gênant c'est:
    qui a pour réponse:
    File "./Coord_beta.py", line 180, in <module>
    print f.d[Coord(1,2)]
    KeyError: (1, 2)
    Alors même que la clé est présente dans la liste f.d.keys()!!
    Juin 2008
    Re...
    Citation Envoyé par Krishna Voir le message
    N'étaient-ils pas la raison du premier post?
    qui a pour réponse:
    Heu... comme vous ne dites pas pourquoi çà vous gêne, vous laissez penser que vous considérez "Coord(1,2)" comme une chaine de caractère et non comme une nouvelle, à priori, instance de Coord(1,2)...
    Qu'avez vous fait pour que çà puisse fonctionner?
    Bon d'accord en prenant le temps de fouiller le code on trouve une fonction __hash__ qui pourrait, si complétée par __cmp__, le faire...
    Mais c'est beurk: retournez l'instance précédemment créé via __new__ plutôt que de multiplier des objets identiques mais pas vraiement pareil...
    Vous vous entrainez à coder toxique ou quoi?
    - W
    PS: A quoi sert d'avoir sous classé tuple si c'est pour stocker les valeurs 'ailleurs' et avoir une fonction de hash en plus???
    class Coord(tuple):
        _instances_ = {}
        def __new__(cls, *args):
            if args not in cls._instances_:
                cls._instances_[args] = tuple.__new__(cls, args)
            return cls._instances_[args]
    t = Coord(1, 1)
    v = Coord(1, 1)
    print 't == v: %s' % (t == v) # t et v sont égaux
    print 'id(t) = %s' % id(t) # mais aussi identiques
    print 'id(v) = %s' % id(v)
    dd = {}                         # si nous mettons cela dans un dict..
    for x in range(4):
        c = Coord(1, x)
        dd[c] = c
    if t in dd: print 'known'  # pas besoin de __cmp__ ou de __hash__
    print dd[Coord(1,1)]
    Septembre 2004
    Bonsoir, re...bonsoir...
    L'utilisation du generator "for" me permettrait avant tout d'accéder au contenu du dictionnaire.
    Certes, le manque de clarté dans ma question permet toutes les interprétations...
    Je n'ai rien lu jusqu'ici sur __cmp__ dans mon livre de référence python. Je vais m'y employer de ce pas et corriger le code en conséquence.
    Alors là j'aurais vraiment besoin de précision. Est-ce une question d'espace mémoire? Comment fait-on pour retourner l'instance précédemment créée via __new__?
    Qu'est-ce que du code toxique?
    Décembre 2007
    bonsoir,
    c'est le code qu'a mis wiztricks dans son dernier message
    Mars 2007
    Ce qui m'a toujours dérangé avec cette technique est que la méthode __init__ est quand-même appelée, même si on retourne un objet déjà construit...
    Janvier 2007
    Mon code était idiot. Je ne sais pas ce qui m’est passé dans l’esprit.
    Je crois que c’est parce que j’ai dérivé de façon fausse à partir de ce qu’a écrit dividee:
    Citation Envoyé par dividee Voir le message
    Je suis parti dans l’idée que __init__() était exécutée dans tous les cas parce qu’appelée par la fonction __new__() qui se trouve dans la ligne
    Une __init__() par défaut et occulte en quelque sorte.
    J’ai donc pensé qu’il fallait éviter de passer par cette ligne. Et j’ai fait n’importe quoi.
    Je dois dire que je ne me débrouille pas bien avec l’approche objet.
    Je vois donc maintenant que mon code était idiot.
    Et que mon souhait de mettre une instruction print ’coucou’ dans une __init__() qui n’existe pas était en effet simplet.
    Mais d’ailleurs, me dis-je, si __init__() ne se trouve pas dans le code de wiztricks, c’est parce qu’il n’en a pas besoin et parce qu’il a tout à fait le droit de s’en passer. Car __init__() n’est pas obligatoire dans une définition de classe. Alors que signifie ? :
    Je crois comprendre que ceci répond à cette question:
    En cas d'héritage, c'est le __init__ de la classe parente qui sera appelé (dans le cas présent, tuple.__init__).
    Mais __init__() est une méthode initialisatrice. Qu’est ce que tuple.__init__() peut bien initialiser ? Autrement dit, ça existe __init__() dans le type tuple ??
    D’autre part, le code suivant:
    class Coord(tuple):
        _instances_ = {}
        def __init__(cap,*x):
            print '_instances_',Coord._instances_
    t = Coord(1, 1)
    a = Coord(2,6)
    v = Coord(1, 1)
    donne:
    _instances_ {(1, 1): (1, 1)}
    _instances_ {(2, 6): (2, 6), (1, 1): (1, 1)}
    t == v: True
    id(t) = 17505040
    id(v) = 17505040
    ce qui montre, me semble-t-il, que la création d’une instance a déjà eu lieu quand __init__() est exécutée. C’est bien ça ?
    Est-ce que je suis autorisé à conclure que def __new__(cls, *args) est exécutée avant def __init__(cap,*x) ? Et que donc __new__() n’appelle pas __init__() ?
  1. Réponses: 2
    Dernier message: 30/08/2004, 14h48
