Different comportement analyseur 11g
    Membre émérite Avatar de jkofr
    Senior Consultant DBA (Trivadis SA)
    Octobre 2006
    Activité : Senior Consultant DBA (Trivadis SA)
    Par défaut Different comportement analyseur 11g
    Voici un test case intéressant:
    La Table de test:
    drop table ZZ_TAB1;
    create TABLE ZZ_TAB1
      DV_ID  INTEGER  NOT NULL,
      JE_ID  INTEGER  NOT NULL,
      PS_ID  INTEGER  NOT NULL,
      P_ID   INTEGER  NOT NULL,
      SP_ID  INTEGER  NOT NULL,
      JET_ID INTEGER  NOT NULL,
      JE_NUM INTEGER,
      Rev_Num  INTEGER)
    TABLESPACE users
    PARTITION BY LIST (DV_ID)
      PARTITION P002 VALUES (2)
        NOLOGGING
        NOCOMPRESS
      PARTITION P032 VALUES (32)
        NOLOGGING
        NOCOMPRESS
      PARTITION P035 VALUES (35)
        NOLOGGING
        NOCOMPRESS
    NOCOMPRESS
    NOCACHE
    NOPARALLEL
    MONITORING;
    Insert into ZZ_Tab1 Values (32,2590376,1,5,1,2,138,0);
    Insert into ZZ_Tab1 Values (32,2590540,1,5,1,2,138,1);
    Insert into ZZ_Tab1 Values (32,2590542,1,5,1,2,138,2);
    Insert into ZZ_Tab1 Values (32,2590544,1,5,1,2,138,3);
    Insert into ZZ_Tab1 Values (2,2590376,1,5,1,2,138,0);
    Insert into ZZ_Tab1 Values (2,2590540,1,5,1,2,138,1);
    Insert into ZZ_Tab1 Values (2,2590542,1,5,1,2,138,2);
    Insert into ZZ_Tab1 Values (2,2590544,1,5,1,2,138,3);
    Insert into ZZ_Tab1 Values (35,2590376,1,5,1,2,138,0);
    Insert into ZZ_Tab1 Values (35,2590540,1,5,1,2,138,1);
    Insert into ZZ_Tab1 Values (35,2590542,1,5,1,2,138,2);
    Insert into ZZ_Tab1 Values (35,2590544,1,5,1,2,138,3);
    Le phénomène ne se produit pas si la table n'est pas partitionée.
    Voici la requête:
          SELECT aa.JE_ID, aa.Rev_Num
                    FROM ZZ_TAB1 aa
                    WHERE aa.DV_ID = 32
                      AND aa.JE_NUM = 138
                      AND aa.PS_ID = 1
                      AND aa.P_ID = 5
                      AND aa.SP_ID = 1
                      AND aa.Rev_Num =
                             (SELECT MAX (je.Rev_Num)
                                FROM ZZ_TAB1 je
                               WHERE je.DV_ID = aa.DV_ID
                                 AND je.JE_NUM =aa.JE_NUM
                                 AND je.P_ID = aa.P_ID
                                 AND je.SP_ID = aa.SP_ID
                                 AND je.PS_ID = aa.PS_ID);
    Le résultat en 11g 11.1.0.7 retourne 0 lignes.
    En 9i, la ligne avec Rev_Num = 3 est renvoyée.
    Je suis partagé entre le fait de considérer le comportement comme normal ou comme un bug.
    1) Normal car la sous requête utilise dans sa clause where des colonnes qui n'ont pas été sélectionnées par la requête parente.
    Le truc étrange est que ceci fonctionne en 11g
                    FROM ZZ_TAB1 aa
                    WHERE aa.DV_ID = 32
                      AND aa.JE_NUM = 138
                      AND aa.PS_ID = 1
                      AND aa.P_ID = 5
                      AND aa.SP_ID = 1
                      AND aa.Rev_Num =
                                FROM ZZ_TAB1 je
                               WHERE je.DV_ID = 32
    2) Pas normal car si il a besoin d'une colonne pour satisfaire une sous requête, le plus simple est que l'optimiseur nous le signale.
    Par exemple l'erreur "ORA-01785: ORDER BY item must be the number of a SELECT-list expression"
    Quel est votre avis?
    Jko
    Avatar de Waldar
    Je n'arrive pas à le reproduire :
    select * from sys.v_$version;
    BANNER
    Oracle Database 11g Enterprise Edition Release 11.1.0.7.0 - 64bit Production
    PL/SQL Release 11.1.0.7.0 - Production
    CORE	11.1.0.7.0	Production
    TNS for 64-bit Windows: Version 11.1.0.7.0 - Production
    NLSRTL Version 11.1.0.7.0 - Production
    select aa.je_id, aa.rev_num
      from zz_tab1 aa
     where aa.dv_id   = 32
       and aa.je_num  = 138
       and aa.ps_id   = 1
       and aa.p_id    = 5
       and aa.sp_id   = 1
       and aa.rev_num =
             (select max(je.rev_num)
                from zz_tab1 je
               where je.dv_id  = aa.dv_id
                 and je.je_num = aa.je_num
                 and je.p_id   = aa.p_id
                 and je.sp_id  = aa.sp_id
                 and je.ps_id  = aa.ps_id);
    JE_ID	REV_NUM
    2590544	3
    Octobre 2006
    J'ai 2 instances sous AIX.
    Sur l'une d'entre elle, je reproduis l'erreur mais pas sur l'autre.
    A noter que ces 2 instances on été migrées a partir d'une 9.2.0.8.
    J'ai aussi une instance sous Windows 2008 R2 et ca fonctionne aussi.
    Un paramètre?
    jko
    Membre expérimenté
    Mars 2010
    Peut-on avoir le plan d'exécution (le vrai, le row source operation) dans les deux cas ?
    Octobre 2006
    Instance qui pose problème
    		Operation				Optimizer     Cost   Card     Bytes   Part Start   Part Stop Part ID		Filter
    SELECT STATEMENT					ALL_ROWS	4	1	173
     NESTED LOOPS								4	1	173
      PARTITION LIST(SINGLE)						2	1	104	2		2	2
       TABLE ACCESS(FULL) ZZ_TAB1						2	1	104	2		2	3		"AA"."JE_NUM"=138 AND "AA"."PS_ID"=1 AND "AA"."P_ID"=5 AND "AA"."SP_ID"=1
      VIEW PUSHED PREDICATE SYS.VW_SQ_1					2	1	69						"AA"."REV_NUM"="MAX(JE.REV_NUM)"
       SORT(GROUP BY)							2	1	143
        PARTITION LIST(SINGLE)						2	1	143	KEY	KEY	6
         TABLE ACCESS(FULL) ZZ_TAB1						2	1	143	KEY	KEY	6			"JE"."JE_NUM"=138 AND "JE"."PS_ID"=1 AND "JE"."P_ID"=5 AND "JE"."SP_ID"=1
    Instance qui fonctionne
    SELECT STATEMENT					ALL_ROWS	4	1	248
     NESTED LOOPS								4	1	248
      PARTITION LIST(SINGLE)						2	1	169	2		2	2
       TABLE ACCESS(FULL) ZZ_TAB1						2	1	169	2		2	3		"AA"."JE_NUM"=138 AND "AA"."PS_ID"=1 AND "AA"."P_ID"=5 AND "AA"."SP_ID"=1
      VIEW PUSHED PREDICATE SYS.VW_SQ_1					2	1	79						"AA"."REV_NUM"="MAX(JE.REV_NUM)"
        FILTER																32="AA"."DV_ID"
         PARTITION LIST(SINGLE)						2	1	143	2		2	7
          TABLE ACCESS(FULL) ZZ_TAB1					2	1	143	2		2	8		"JE"."JE_NUM"=138 AND "JE"."PS_ID"=1 AND "JE"."P_ID"=5 AND "JE"."SP_ID"=1
    Membre expérimenté
    Mars 2010
    Ca ressemble fortement à un bug, j'en ai déjà rencontré de ce genre en utilisant à la fois les tables partitionnées et les index bitmap, mais ici on passe dans les deux cas par le même chemin pour accéder aux données.
    Je ne peux que te conseiller de contacter le support Oracle.
  1. [Débutant] Different comportement entre OleDb et SqlClient
    Par jloois dans le forum VB.NET
    Réponses: 13
    Dernier message: 04/09/2011, 21h00
  2. Comportement different pour une requete
    Par usf70 dans le forum MS SQL Server
    Dernier message: 29/11/2006, 11h40
  3. Réponses: 3
    Dernier message: 16/10/2006, 12h16
  4. [struts] [EL] [oc4j] comportement different que sur tomcat
    Par emeline dans le forum Tomcat et TomEE
    Dernier message: 24/04/2006, 21h21
  5. Réponses: 3
    Dernier message: 08/10/2004, 01h12
