avec Java Discussion :
Petit probleme de compilation
avec Java
    Octobre 2009
    Par défaut Petit probleme de compilation
    Bonjour à tous, je suis un débutant en développement java et j'ai une erreur que je ne comprends pas, sans plus tarder, voila l'erreur et le code où je pense qu'elle se situe :
    Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
    at Stone.draw(Stone.java:15)
    at Aquarium.paint(Aquarium.java:47)
    at javax.swing.JComponent.paintChildren(Unknown Source)
    at javax.swing.JComponent.paint(Unknown Source)
    at javax.swing.JLayeredPane.paint(Unknown Source)
    at javax.swing.JComponent.paintToOffscreen(Unknown Source)
    at javax.swing.RepaintManager$PaintManager.paintDoubleBuffered(Unknown Source)
    at javax.swing.RepaintManager$PaintManager.paint(Unknown Source)
    at javax.swing.RepaintManager.paint(Unknown Source)
    at java.awt.GraphicsCallback$PaintCallback.run(Unknown Source)
    at sun.awt.SunGraphicsCallback.runOneComponent(Unknown Source)
    at sun.awt.SunGraphicsCallback.runComponents(Unknown Source)
    at java.awt.Container.paint(Unknown Source)
    at javax.swing.RepaintManager.paintDirtyRegions(Unknown Source)
    at javax.swing.RepaintManager.seqPaintDirtyRegions(Unknown Source)
    at javax.swing.SystemEventQueueUtilities$ComponentWorkRequest.run(Unknown Source)
    at java.awt.event.InvocationEvent.dispatch(Unknown Source)
    at java.awt.EventQueue.dispatchEvent(Unknown Source)
    at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
    at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
    at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
    at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
    at java.awt.EventDispatchThread.run(Unknown Source)
    et le code :
    public class Stone extends AquariumItem
    	public Stone(int largeur) {
    		super(largeur);
    	public void draw(Graphics g)
    		g.setColor(Color.gray);
    		g.drawOval(position.x, position.y, width, height);
    Merci d'avance d'éclairer ma lanterne ^^
    Membre Expert Avatar de Djakisback
    Février 2005
    quelle est exactement la ligne Stone.java:15 ?
    Une des variables à cette ligne n'est pas initialisée.
  1. petit probleme de compilation
    Par Asmod_D dans le forum C
    Dernier message: 02/01/2007, 00h14
  2. Probleme de Compilation de la STL
    Par stoluup dans le forum MFC
    Dernier message: 05/05/2004, 18h25
  3. [TP]Probleme de compilation sous TP7
    Par yffick dans le forum Turbo Pascal
    Dernier message: 18/12/2003, 21h32
  4. Problemes de compilation avec g++ sous linux
    Par Selimmel dans le forum Autres éditeurs
    Dernier message: 19/09/2003, 14h43
  5. petit probleme dans une requte POSTGRE SQL
    Par ghis le fou dans le forum Requêtes
    Dernier message: 08/09/2003, 14h51
