Probleme lors d' execution
    Novembre 2005
    Par défaut Probleme lors d' execution
    salut
    j ai un probleme quand j' execute mon application
    voici le message
    Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
    at Utilisateur.Mission.FrmMission.getTextAdresse(FrmMission.java:423)
    at Utilisateur.Mission.FrmMission.getJPanelwestl(FrmMission.java:263)
    at Utilisateur.Mission.FrmMission.getJContentPane(FrmMission.java:174)
    at Utilisateur.Mission.FrmMission.initialize(FrmMission.java:140)
    at Utilisateur.Mission.FrmMission.<init>(FrmMission.java:129)
    at Utilisateur.Menu.MenuUtilisateur.actionPerformed(MenuUtilisateur.java:231)
    at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
    at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
    at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
    at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
    at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
    at java.awt.Component.processMouseEvent(Unknown Source)
    at javax.swing.JComponent.processMouseEvent(Unknown Source)
    at java.awt.Component.processEvent(Unknown Source)
    at java.awt.Container.processEvent(Unknown Source)
    at java.awt.Component.dispatchEventImpl(Unknown Source)
    at java.awt.Container.dispatchEventImpl(Unknown Source)
    at java.awt.Component.dispatchEvent(Unknown Source)
    at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
    at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
    at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
    at java.awt.Window.dispatchEventImpl(Unknown Source)
    at java.awt.EventQueue.dispatchEvent(Unknown Source)
    at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
    at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
    at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
    at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
    at java.awt.EventDispatchThread.run(Unknown Source)
    merci
    Avatar de CheryBen
    Mai 2005
    Bonjour, comme l'indique l'erreur, tu tentes d'accéder à un pointeur null à la ligne 423 de la classe Utilisateur.Mission.FrmMission, dans la méthode getTextAdresse.
    Sans ton code, nous ne pourrons pas te donner plus d'informations.
  1. SSE:problem lors de l execution d'1 procedure
    Par wodel dans le forum MS SQL Server
    Dernier message: 14/05/2008, 13h29
  2. probleme lors de l execution sous eclipse
    Par fAdoua123 dans le forum Eclipse Java
    Dernier message: 12/06/2007, 13h51
  3. Probleme lors de l'execution
    Par elfiestador dans le forum Langage
    Dernier message: 04/01/2007, 17h06
  4. Problème lors de l'exécution d'un exe
    Par mbibim63 dans le forum JBuilder
    Dernier message: 04/01/2006, 14h13
  5. [ADO] Probleme lors de l'execution d'une requete...
    Par NoisetteProd dans le forum Bases de données
    Dernier message: 04/06/2004, 13h43
