Problème d'union
    Janvier 2006
    Par défaut Problème d'union
    j' ai crée une requete basée sur plusieur requetes et liées par instruction union
    mais ne marche pas le compilateur comme ne reconnait pas l'instruction UNION
    voila mon code :
    alors que chaque requete marche toute seule.
    create or replace view v_opendailyresult as
      select (b.risk ||' '||b.libelle_a) as riskcenter,sum(a.mtm_pl) as cash,0 as future,0 as inventorie,0 as freit,0 as forex
        from dpl_posit a,risk b
        where a.risk=b.risk
        group by b.risk,b.libelle_a
        order by b.risk,b.libelle_a
    UNION
      select (b.risk ||' '||b.libelle_a) as riskcenter,0 as cash,sum(c.mkt_price)as future,0 as inventorie,0 as freit,0 as forex
        from dpl_futures c,risk b
        where c.risk=b.risk
    union
       select (b.risk ||' '||b.libelle_a) as riskcenter,0 as cash,0 as future,sum(d.mkt_prime) as options,0 as inventorie,0 as freit,0 as forex
        from dpl_options d,risk b
        where d.risk=b.risk
    union
       select (b.risk ||' '||b.libelle_a) as riskcenter,0 as cash,0 as future,0 as options,sum(e.mkt_price)as inventorie,0 as freit,0 as forex
        from dpl_stock e,risk b
        where e.risk=b.risk
    union
       select (b.risk ||' '||b.libelle_a) as riskcenter,0 as cash,0 as future,0 as options,0 as inventorie,sum(f.mkt_price) as freit,0 as forex
        from dpl_fret f,risk b
        where f.risk=b.risk
    union
       select (b.risk ||' '||b.libelle_a) as riskcenter,0 as cash,0 as future,0 as options,0 as inventorie,0 as freit,sum(g.mkt_price)as forex
        from dpl_forex g,risk b
        where g.risk=b.risk
        order by b.risk,b.libelle_a ;
    merci
    Membre expérimenté Avatar de DAB.cz
    Octobre 2006
    Une fois "order by":
    non:
    select ...
      from ...
      order by ...
    union
    select ...
      from ...
      order by ...
    oui:
    select ...
      from ...
    union
    select ...
      from ...
    order by ...
    Avatar de Antoun
    Architecte décisionnel
    Octobre 2006
    Activité : Architecte décisionnel
    Comme ce n'est pas forcément top explicite... DAB.cz veut dire que dans une UNION, on a droit à une seule clause ORDER BY pour l'ensemble des SELECT unionés ; cette clause ORDER BY doit obligatoirement s'écrire dans le dernier SELECT.
    Citation Envoyé par Antoun Voir le message
    Néologisme osé !
    Pourquoi ne pas essayer simplement avec l'ensemble des SELECT unis ?
    Octobre 2006
    Merci pour l'explication; plus précisément: pas dans le dernier SELECT, mais après.
    (select 1 a
      from dual)
    union
    (select 2 a
      from dual)
    order by a;
    Avatar de Antoun
    Octobre 2006
    Citation Envoyé par DAB.cz Voir le message
    Tu as raison, mais c'est plus facile à expliquer comme ça...
  1. Problème de UNION
    Par zooffy dans le forum Langage SQL
    Dernier message: 22/08/2006, 13h00
  2. Problème d'Union de chaïne
    Par Oberown dans le forum Requêtes
    Dernier message: 13/01/2006, 15h20
  3. Problème d'UNION et de chaine
    Dernier message: 07/01/2006, 14h43
  4. petit problème d'union
    Par poussinphp dans le forum Langage
    Dernier message: 17/08/2005, 11h39
  5. Problème avec UNION et WHERE
    Par portu dans le forum Langage SQL
    Réponses: 13
    Dernier message: 20/04/2005, 12h29
