Débutant java sql
    Avril 2008
    Par défaut Débutant java sql
    je doit créer les méthodes d'une DAO et les tester.
    la création de la méthode update est faite mais le teste me renvoi l'erreur suivante ORA-00907:parenthèse de droite absente
    ligneTicket.updateLigneTicketOTC("Lt1",1,"A",50,"Tar2","Tp","null",15,30,10,"A","commentaireConfi",
    "SF",Date.valueOf("07-07-07"),10,"envoye","trainId","numeroOrdre","courtage",
    "messageAllouant",3,"o",0,"Pd2","D2","T2","SL1","tS","ok","ST1","A","lg_LT",3,
    "TypeEcheance",15,"quotite","EA","NotionalValueN","NotionalValueM","delta",
    "FuturesIndexCrossed",Date.valueOf("07-07-07"),"Settlement","Exercise","Terms","GlobalPremium",
    Timestamp.valueOf("2022-12-05 16:29:50.1456484"),"statutVersion","executiveBroker","modificateur");
    sachant que je travail sur oracle XE, merci de m'apporter de l'aide
    Membre chevronné Avatar de miloux32
    Juillet 2003
    Citation Envoyé par mmanas Voir le message
    Poste ca sur le forum java plutot ....
    Avril 2008
    je vais le faire mais si vous préférez, vous pouvez le voir sous une requette sql:
    update LigneTicket set ("Lt1",'1',"A",'50',"Tar2","Tp","null",'15','30','10',"A","commentaireConfi",
    "messageAllouant",'3',"o",'0',"Pd2","D2","T2","SL1","tS","ok","ST1","A","lg_LT",'3',
    Timestamp.valueOf("2022-12-05 16:29:50.1456484"), "statutVersion","executiveBroker","modificateur")
    et voici les types des données:
    String ligneTicketId, int numSplit, String sens, int quantite, String tarification, String Type, String echeanceManuelle, double prix, double prixRef, double brokerage, String franco, String commentaireConfi, String statutFacturation, Date dateValeur, double commission, String envoye, String trainId, String numeroOrdre, String courtage, String messageAllouant, int niveau,
    String statut, int couverture, String produitId, String deviseId, String ticketId, String statutLigneId, String typeSplitId, String statutFacturationId, String sousTicketId, String critereFacturationId, String lg_LigneTicketId, int lg_NumSplit, String TypeEcheance, double Strike, String quotite, String EA,
    Timestamp timeStamp, String statutVersion, String executiveBroker, String modificateur .
  1. Débutant java sql
    Par mmanas dans le forum JDBC
    Dernier message: 08/07/2008, 21h01
  2. [java.sql.Date] format compatible tout sgbd ?
    Par djskyz dans le forum JDBC
    Dernier message: 15/09/2004, 12h28
  3. [JDBC] java.sql.SQLException: Closed Statement
    Par cmoulin dans le forum JDBC
    Dernier message: 03/09/2004, 18h22
  4. [Débutant] java.lang.object
    Par bonnefr dans le forum Eclipse Java
    Dernier message: 27/05/2004, 15h54
  5. [débutante][java]connection internet PPC\PC de bureau
    Par Emma20 dans le forum Développement
    Dernier message: 19/05/2004, 15h01
