Installation, Déploiement et Sécurité VB Discussion :
error -2147217406 (Automation Error)
    Décembre 2005
    Par défaut error -2147217406 (Automation Error)
    J'ai un programme qui utilise ocx msdxm.ocx sur mon ordinateur
    qui a cette version d'XP edition familialle 2002 service Pack 1
    55639-OEM-0011903-00101
    Tout marche, j'ai fait un programme d'installe avec inno setup:
    [Setup]
    AppName=MonProgram 2.0 Lite
    AppVerName=MonProgram 2.0 Lite
    AppPublisherURL=http://www.MonProgram.fr/
    AppSupportURL=http://www.MonProgram.fr/
    AppUpdatesURL=http://www.MonProgram.fr/
    DefaultDirName={pf}\MonProgram 2.0 Lite
    DefaultGroupName=MonProgram 2.0 Lite
    LicenseFile=C:\save\Kproduction\licences.rtf
    OutputDir=C:\save\Output
    OutputBaseFilename=setup 2.0 Lite
    Compression=lzma
    SolidCompression=yes
    [Languages]
    Name: "english"; MessagesFile: "compiler:Default.isl"
    Name: "french"; MessagesFile: "compiler:Languages\French.isl"
    [Tasks]
    Name: "desktopicon"; Description: "{cm:CreateDesktopIcon}"; GroupDescription: "{cm:AdditionalIcons}"; Flags: unchecked
    [Files]
    Source: "C:\save\Projet V26 Public\MonProgram Lite.exe"; DestDir: "{app}"; Flags: ignoreversion
    Source: "C:\save\Projet V26 Public\config.ini"; DestDir: "{app}"; Flags: ignoreversion
    Source: "C:\save\Projet V26 Public\Images\*"; DestDir: "{app}\\Images"; Flags: ignoreversion recursesubdirs createallsubdirs
    Source: "C:\save\Projet V26 Public\playlist\*"; DestDir: "{app}\\playlist"; Flags: ignoreversion recursesubdirs createallsubdirs
    Source: C:\save\VB 6 Run Time\COMDLG32.OCX; DestDir: {sys}; Flags: regserver sharedfile noregerror
    Source: C:\save\VB 6 Run Time\FONTCTL.OCX; DestDir: {sys}; Flags: regserver sharedfile noregerror
    Source: C:\save\VB 6 Run Time\ImageStudio.ocx; DestDir: {sys}; Flags: regserver sharedfile noregerror
    Source: C:\save\VB 6 Run Time\msdxm.ocx; DestDir: {sys}; Flags: regserver sharedfile noregerror
    Source: C:\save\VB 6 Run Time\ASYCFILT.DLL; DestDir: {sys}; Flags: regserver noregerror
    Source: C:\save\VB 6 Run Time\COMCAT.DLL; DestDir: {sys}; Flags: regserver noregerror
    Source: C:\save\VB 6 Run Time\MSSTDFMT.DLL; DestDir: {sys}; Flags: regserver sharedfile noregerror
    Source: C:\save\VB 6 Run Time\msvbvm60.dll; DestDir: {sys}; Flags: regserver noregerror
    Source: C:\save\VB 6 Run Time\OLEAUT32.DLL; DestDir: {sys}; Flags: regserver noregerror
    Source: C:\save\VB 6 Run Time\OLEPRO32.DLL; DestDir: {sys}; Flags: regserver noregerror
    Source: C:\save\VB 6 Run Time\VB6STKIT.DLL; DestDir: {sys}; Flags: regserver noregerror
    Source: C:\save\VB 6 Run Time\stdole2.tlb; DestDir: {sys}; Flags: regtypelib noregerror
    [Icons]
    Name: "{group}\MonProgram Lite"; Filename: "{app}\MonProgram Lite.exe"
    Name: "{commondesktop}\MonProgram Lite"; Filename: "{app}\MonProgram Lite.exe"; Tasks: desktopicon
    [Run]
    Filename: "{app}\MonProgram Lite.exe"; Description: "{cm:LaunchProgram,MonProgram 2.0 Lite}"; Flags: nowait postinstall skipifsilent
    tout marche bien sur mon ordi.
    Par contre sur d'autres XP il me fait ce problème d'atomation Error
    Est ce que l'ocx msdxm.ocx 6.4 de windows media player fonctionne sur XP SP2?
    Merci pour votre aide!
    Avatar de ThierryAIM
    Septembre 2002
    essaie déjà de supprimer les flags noregerror pour voir si un des composant provoque une erreur d'enregistrement
    Décembre 2005
    J'ai constaté que on OCX msdxm.ocx fonctionne a partir du moment que je n'installe pas directX 9.0c avec directX 8 il fonctionne plus.
    Décembre 2005
    Par défaut envoie des erreurs de registres
    je te joins les messages d'erreur en Jpg
    Septembre 2002
    asycfilt.dll ne s'enregistre pas. tu peux supprimer le Tag regserver
    VB6STKIT.dll n'est pas nécessaire pour une install avec Inno Setup (sert uniquement pour une install avec la package de VB6), tu peux la supprimer, et de toute façon, ne s'enregistre pas non plus
    par contre, pour msdxm.ocx, je ne sais pas trop
    Que se passe-t-il si tu ne l'enregistres pas, ou si tu ne le distribue pas ? (il y a peut-être des conflits de versions)
    Décembre 2005
    Si je ne l'enregistre pas j'ai des autmoations erreurS.
    Mais je ne crois pas qu'il soit compatible avec XP et SP2
    Car il marche tres bien avec XP SP1
    Si je fait manuellement rgsvr32 il s'enregistre.
  1. Réponses: 6
    Dernier message: 18/08/2014, 15h53
  2. [XL-2007] Ouverture Page Web - Automation Error
    Par Nelmech dans le forum Macros et VBA Excel
    Dernier message: 18/04/2014, 15h04
  3. [VB6/.NET] Run Time Error, Automation error
    Par scarlaty dans le forum VB 6 et antérieur
    Dernier message: 18/04/2012, 16h03
  4. [Intouch] OLE Automation Error
    Par alexandrallan dans le forum Autres EDI
    Dernier message: 09/04/2008, 17h57
  5. Réponses: 7
    Dernier message: 04/04/2006, 15h35
