je veux faire un script pour générer un fichier xml.
declare
  doc dbms_xmldom.domdocument;
  nodedoc dbms_xmldom.domnode;
  var xmltype;
  old_critere varchar2(100) := 'a';
  crit dbms_xmldom.domelement;
  val dbms_xmldom.domelement;
  root dbms_xmldom.domelement;
  text dbms_xmldom.domtext;
  buf varchar2(3000);
  i number;
  dir varchar2(200);
  cpt number;
begin
  var := xmltype('<root></root>');
  doc := dbms_xmldom.newdomdocument(var);
  nodedoc := dbms_xmldom.makenode(doc);
  i := 1;
  cpt := 0;
  for j in 1..200 loop
    for rec in (select ref, critere, valeur from xref where ref = 'PR0VAR2' order by critere)
    loop
      begin
        root := dbms_xmldom.getDocumentElement(doc);
        if (rec.critere != old_critere or rec.critere is null or old_critere is null) and not (rec.critere is null and old_critere is null) then
          crit := dbms_xmldom.createelement(doc, 'crit');
          crit := dbms_xmldom.makeelement(dbms_xmldom.appendchild(dbms_xmldom.makenode(root), dbms_xmldom.makenode(crit)));
          dbms_xmldom.setAttribute(crit, 'nom', rec.critere);
          dbms_xmldom.setAttribute(crit, 'idDebut', i);
          dbms_xmldom.freenode(dbms_xmldom.makenode(crit));
        end if;
        val := dbms_xmldom.createelement(doc, 'valeur');
        val := dbms_xmldom.makeelement(dbms_xmldom.appendchild(dbms_xmldom.makenode(crit), dbms_xmldom.makenode(val)));
        text := dbms_xmldom.createtextnode(doc, rec.valeur);
        text := dbms_xmldom.maketext(dbms_xmldom.appendchild(dbms_xmldom.makenode(val), dbms_xmldom.makenode(text)));
        dbms_xmldom.freenode(dbms_xmldom.makenode(text));
        dbms_xmldom.freenode(dbms_xmldom.makenode(val));
        old_critere := rec.critere;
        dbms_xmldom.setAttribute(crit, 'idFin', i);
        dbms_xmldom.setAttribute(val, 'id', i);
        i := i + 1;
        dbms_xmldom.freenode(dbms_xmldom.makenode(root));
      exception
        when others then
          dbms_output.put_line(sqlerrm);
          goto fin;
      end;
    end loop;
  end loop;
  dbms_output.put_line(cpt);
  <<fin>>
  select value into dir from v$parameter where name = 'utl_file_dir';
  dbms_xmldom.writetofile(doc, dir||'/test.xml');
end;
la boucle for j in 1..200 ne sera pas dans la procedure finale, elle n'est là que pour tester les limites de taille de fichier
quand je lance ce script, je récupère l'erreur ora-31182 : Too many PL/SQL DOM handles specified. J'ai pourtant essayé de libérer les node. Est-ce que je m'y prends mal pour les libérer ? est-ce qu'il y a un moyen de contourner ce problème (sans upgrader en 9.2.0.5) ?
merci d'avance
