Je comprends très bien ce qu'est un retour sur trace chronologique.
Par exemple, toutes les solutions au problème du tour de cavalier sur un échiquier en backtracking :
Code pascal : Sélectionner tout - Visualiser dans une fenêtre à part
54 MODULE KnightTour; IMPORT StdLog; VAR board : ARRAY 8 OF ARRAY 8 OF INTEGER; PROCEDURE Bounded (x,y : INTEGER) : BOOLEAN; BEGIN IF (x < 0) OR (x > 7) THEN RETURN FALSE END; IF (y < 0) OR (y > 7) THEN RETURN FALSE END; RETURN TRUE END Bounded; PROCEDURE Print; VAR x, y : INTEGER; BEGIN FOR x := 0 TO 7 DO FOR y := 0 TO 7 DO StdLog.IntForm(board[x,y], StdLog.decimal, 2 , '0', StdLog.hideBase); StdLog.Char(' ') END; StdLog.Ln END; StdLog.Ln END Print; PROCEDURE Forward_chaining (n, x, y : INTEGER); BEGIN IF Bounded(x, y) & (board[x,y] = 0) THEN board[x,y] := n; IF n = 8 * 8 THEN Print ELSE n := n + 1; Forward_chaining(n, x + 1, y + 2); Forward_chaining(n, x + 2, y + 1); Forward_chaining(n, x + 2, y - 1); Forward_chaining(n, x + 1, y - 2); Forward_chaining(n, x - 1, y - 2); Forward_chaining(n, x - 2, y - 1); Forward_chaining(n, x - 2, y + 1); Forward_chaining(n, x - 1, y + 2); END; board[x,y] := 0; END END Forward_chaining; PROCEDURE Solve_all* ; BEGIN Forward_chaining(1, 0, 0); END Solve_all; END KnightTour.
Code ocaml : Sélectionner tout - Visualiser dans une fenêtre à part
33 let board = Array.make_matrix 8 8 0 let bounded x y = if x < 0 || x > 7 then false else if y < 0 || y > 7 then false else true let print_board () = Array.iter (fun a -> Array.iter (fun k -> if k < 10 then print_char '0'; print_int k; print_char ' ') a; print_newline ()) board let rec forward_chaining n x y = if bounded x y && board.(x).(y) = 0 then begin board.(x).(y) <- n; if n = 8 * 8 then (print_board (); print_newline ()) else begin forward_chaining (n + 1) (x + 1) (y + 2); forward_chaining (n + 1) (x + 2) (y + 1); forward_chaining (n + 1) (x + 2) (y - 1); forward_chaining (n + 1) (x + 1) (y - 2); forward_chaining (n + 1) (x - 1) (y - 2); forward_chaining (n + 1) (x - 2) (y - 1); forward_chaining (n + 1) (x - 2) (y + 1); forward_chaining (n + 1) (x - 1) (y + 2); end; board.(x).(y) <- 0; end let () = forward_chaining 1 0 0
Autre exemple, toutes les solutions au problème des 8 reines en backtracking :
90 MODULE Queens; IMPORT StdLog; TYPE PtrQueen = POINTER TO Queen; Queen = EXTENSIBLE RECORD row, column : INTEGER; neighbor : PtrQueen; END; PtrNullQueen = POINTER TO NullQueen; NullQueen = RECORD (Queen) END; PROCEDURE ^ (self : PtrQueen) Test () : BOOLEAN, NEW; PROCEDURE ^ (self : PtrQueen) First () : BOOLEAN, NEW, EXTENSIBLE; PROCEDURE ^ (self : PtrQueen) Next () : BOOLEAN, NEW, EXTENSIBLE; PROCEDURE ^ (self : PtrQueen) Advance () : BOOLEAN, NEW; PROCEDURE (self : PtrQueen) Check (r, c : INTEGER) : BOOLEAN, NEW, EXTENSIBLE; VAR diff : INTEGER; BEGIN diff := c - self.column; RETURN (self.row = r) OR (self.row + diff = r) OR (self.row - diff = r) OR self.neighbor.Check (r, c) END Check; PROCEDURE (self : PtrQueen) Test () : BOOLEAN, NEW; BEGIN WHILE self.neighbor.Check (self.row, self.column) DO IF ~ self.Advance () THEN RETURN FALSE END END; RETURN TRUE END Test; PROCEDURE (self : PtrQueen) First () : BOOLEAN, NEW, EXTENSIBLE; VAR ignore : BOOLEAN; BEGIN ignore := self.neighbor.First (); self.row := 1; RETURN self.Test () END First; PROCEDURE (self : PtrQueen) Next () : BOOLEAN, NEW, EXTENSIBLE; BEGIN RETURN self.Advance() & self.Test() END Next; PROCEDURE (self : PtrQueen) Advance () : BOOLEAN, NEW; BEGIN IF self.row = 8 THEN IF self.neighbor.Next () THEN self.row := 0 ELSE RETURN FALSE END END; INC (self.row); RETURN TRUE END Advance; PROCEDURE (self : PtrQueen) Print (), NEW, EXTENSIBLE; BEGIN StdLog.Int(self.row); StdLog.Char(' '); self.neighbor.Print () END Print; PROCEDURE NewQueen (c : INTEGER; n : PtrQueen) : PtrQueen; VAR q : PtrQueen; BEGIN NEW(q); q.column := c; q.neighbor := n; RETURN q END NewQueen; PROCEDURE (self : PtrNullQueen) Check (r, c : INTEGER) : BOOLEAN; BEGIN RETURN FALSE END Check; PROCEDURE (self : PtrNullQueen) First () : BOOLEAN; BEGIN RETURN FALSE END First; PROCEDURE (self : PtrNullQueen) Next () : BOOLEAN; BEGIN RETURN FALSE END Next; PROCEDURE (self : PtrNullQueen) Print () ; BEGIN StdLog.Ln END Print; PROCEDURE Solve_all* ; VAR last : PtrQueen; null : PtrNullQueen; i : INTEGER; BEGIN NEW (null); last := null; FOR i := 1 TO 8 DO last := NewQueen (i, last) END; IF ~ last.First () THEN StdLog.String("Zero solution."); StdLog.Ln; RETURN END; REPEAT last.Print() UNTIL ~ last.Next () END Solve_all; END NQueens.
50 let null_queen = object method first = false method next = false method check (x:int) (y:int) = false method print = print_newline () end class queen column (neighbor:queen) = object (self) val mutable row = 1 method check r c = let diff = c - column in (row = r) || (row + diff = r) || (row - diff = r) || neighbor#check r c method private test = try while neighbor#check row column do if not self#advance then raise Exit done; true with | Exit -> false method first = ignore(neighbor#first); row <- 1; self#test method next = self#advance && self#test method private advance = if row = 8 then (if neighbor#next then (row <- 1; true) else false) else (row <- row + 1; true) method print : unit = print_int row; print_char ' '; neighbor#print end let () = let last = (ref null_queen : queen ref) in for i = 1 to 8 do last := new queen i !last done; try if not !last#first then (print_string "Zero solution." ; raise Exit); while true do !last#print; if not !last#next then raise Exit done with Exit -> ()
Ce que je comprends plus mal c'est le retour sur trace non chronologique.
Ou plutôt, je comprends bien qu'il est plus avantageux de remonter plus loin dans les choix passés. Ce que je ne comprends pas c'est comment s'y prendre pour détecter ces opportunités de sauts arrières "longs".
Je manque d'une explication claire ou à défaut d'un exemple de code ou de pseudo-code de backjumping sur un problème simple ou bien connu. Et pourquoi pas sur un problème d'échecs comme les deux présentés ci-dessus et pour lesquels je n'arrive pas à trouver une version en backjumping.
