Hello j'essaye d'utiliser java pour filtrer une requete sql sous talend mais la base de donnée oracle me retourne ORA-01861: literal does not match format string
Voici mon code java :
Et voici ma requete oracle sous talend :
19 Date supply_date_last_filter = new Date(); Date supply_date_start_filter; supply_date_last_filter = TalendDate.parseDate("ddMMyyyy",TalendDate.formatDate("ddMMyyyy", new Date())); if (context.work_METI_last_date != null && !"".equals(context.work_METI_last_date)) { supply_date_last_filter = TalendDate.parseDate("ddMMyyyy",context.work_METI_last_date); } supply_date_start_filter = TalendDate.addDate(supply_date_last_filter, - Integer.parseInt(context.work_METIstore_last_days), "dd"); String supply_date_start_filter_str = TalendDate.formatDate("ddMMyyyy",supply_date_start_filter); String supply_date_last_filter_str = TalendDate.formatDate("ddMMyyyy",supply_date_last_filter); globalMap.put("supply_date_start_filter", supply_date_start_filter_str); globalMap.put("supply_date_last_filter", supply_date_last_filter_str);
Je suis un peu perdu là car je donne bien un string de la bonne longeur à la fonction to_date...
19 "SELECT substr(fld_znvaleur, 5, 3) store_code, substr(fld_znvaleur, 8, 8) order_number, substr(fld_znvaleur, 16, 8) order_date, std_cdsitu, std_lbsitu, wcd_tydemand, tyd_lbtypdem FROM " + context.link_METIsupply_DB_schema + ".mgfld INNER JOIN " + context.link_METIsupply_DB_schema + ".mgfle ON (fle_cdflux = fld_cdflux AND fle_notrait = fld_notrait) LEFT JOIN " + context.link_METIsupply_DB_schema + ".mgwcd ON (wcd_nocdemag = to_number(substr(fld_znvaleur, 8, 8)) AND wcd_noclcash = to_number(substr(fld_znvaleur, 5, 3))) LEFT JOIN " + context.link_METIsupply_DB_schema + ".mgstd ON (wcd_tydemand = std_tydemand and wcd_cdetat = std_cdsitu) LEFT JOIN " + context.link_METIsupply_DB_schema + ".mgtyd ON (tyd_tydemand = wcd_tydemand) WHERE fld_cdflux = 'DDE' AND fld_cdfichier = 'DDE_E' AND substr(fld_znvaleur, 16, 8) BETWEEN to_date('" + ((String) globalMap.get("supply_date_start_filter")) + "','DDMMYYYY') AND to_date('" + ((String) globalMap.get("supply_date_last_filter")) + "','DDMMYYYY') and substr(fld_znvaleur, 16, 8) <> ' ' AND substr(fld_znvaleur, 5, 3) in " + context.work_METIstore_list
ps les quote au début et à la fin sont obligatoire sous talend.
N'oubliez pas le bouton
et pensez aux balises [code]
