Simplification de requête [10g]
    Cadre
    Septembre 2013
    Activité : Cadre
    Par défaut Simplification de requête
    peut_on dans la requête suivante supprimer les cases vides entre les valeurs?
    Peut importe le nombre de valeurs dans chaque lignes, je souhaiterai les rammener dans les premières colonnes.
    SELECT phof_orfa_numero
       , MAX(DECODE (phof_numero_phase,'2',phof_post_code)) AS "1"
       , MAX(DECODE(phof_numero_phase,'9',phof_post_code)) AS "2"
       , MAX(DECODE(phof_numero_phase,'10',phof_post_code)) AS "3"
       , MAX(DECODE(phof_numero_phase,'20',phof_post_code)) AS "4"
       , MAX(DECODE(phof_numero_phase,'25',phof_post_code)) AS "5"
       , MAX(DECODE(phof_numero_phase,'30',phof_post_code)) AS "6"
       , MAX(DECODE(phof_numero_phase,'35',phof_post_code)) AS "7"
       , MAX(DECODE(phof_numero_phase,'40',phof_post_code)) AS "8"
       , MAX(DECODE(phof_numero_phase,'50',phof_post_code)) AS "9"
       , MAX(DECODE(phof_numero_phase,'60',phof_post_code)) AS "10"
       , MAX(DECODE(phof_numero_phase,'70',phof_post_code)) AS "11"
       , MAX(DECODE(phof_numero_phase,'80',phof_post_code)) AS "12"
       , MAX(DECODE(phof_numero_phase,'90',phof_post_code)) AS "13"
       , MAX(DECODE(phof_numero_phase,'100',phof_post_code)) AS "14"
       , MAX(DECODE(phof_numero_phase,'110',phof_post_code)) AS "15"
       , MAX(DECODE(phof_numero_phase,'120',phof_post_code)) AS "16"
       , MAX(DECODE(phof_numero_phase,'130',phof_post_code)) AS "17"
       , MAX(DECODE(phof_numero_phase,'140',phof_post_code)) AS "18"
       , MAX(DECODE(phof_numero_phase,'150',phof_post_code)) AS "19"
       , MAX(DECODE(phof_numero_phase,'160',phof_post_code)) AS "20"
       , MAX(DECODE(phof_numero_phase,'170',phof_post_code)) AS "21"
       , MAX(DECODE(phof_numero_phase,'180',phof_post_code)) AS "22"
       , MAX(DECODE(phof_numero_phase,'190',phof_post_code)) AS "23"
       , MAX(DECODE(phof_numero_phase,'200',phof_post_code)) AS "24"
       , MAX(DECODE(phof_numero_phase,'210',phof_post_code)) AS "25"
       , MAX(DECODE(phof_numero_phase,'220',phof_post_code)) AS "26"
       , MAX(DECODE(phof_numero_phase,'230',phof_post_code)) AS "27"
       , MAX(DECODE(phof_numero_phase,'240',phof_post_code)) AS "28"
       , MAX(DECODE(phof_numero_phase,'250',phof_post_code)) AS "29"
       , MAX(DECODE(phof_numero_phase,'260',phof_post_code)) AS "30"
       , MAX(DECODE(phof_numero_phase,'270',phof_post_code)) AS "31"
       , MAX(DECODE(phof_numero_phase,'280',phof_post_code)) AS "32"
       , MAX(DECODE(phof_numero_phase,'290',phof_post_code)) AS "33"
       , MAX(DECODE(phof_numero_phase,'300',phof_post_code)) AS "34"
       , MAX(DECODE(phof_numero_phase,'310',phof_post_code)) AS "35"
       , MAX(DECODE(phof_numero_phase,'400',phof_post_code)) AS "36"
       , MAX(DECODE(phof_numero_phase,'450',phof_post_code)) AS "37"
       , MAX(DECODE(phof_numero_phase,'490',phof_post_code)) AS "38"
       , MAX(DECODE(phof_numero_phase,'491',phof_post_code)) AS "39"
       , MAX(DECODE(phof_numero_phase,'492',phof_post_code)) AS "40"
       , MAX(DECODE(phof_numero_phase,'493',phof_post_code)) AS "41"
       , MAX(DECODE(phof_numero_phase,'494',phof_post_code)) AS "42"
       , MAX(DECODE(phof_numero_phase,'495',phof_post_code)) AS "43"
       , MAX(DECODE(phof_numero_phase,'496',phof_post_code)) AS "44"
       , MAX(DECODE(phof_numero_phase,'497',phof_post_code)) AS "45"
       , MAX(DECODE(phof_numero_phase,'498',phof_post_code)) AS "46"
       , MAX(DECODE(phof_numero_phase,'499',phof_post_code)) AS "47"
       , MAX(DECODE(phof_numero_phase,'500',phof_post_code)) AS "48"
       , MAX(DECODE(phof_numero_phase,'510',phof_post_code)) AS "49"
        FROM phase_of
        WHERE phof_statut = 'L'
        AND phof_orfa_numero = '201'
        GROUP BY phof_orfa_numero
    Merci d'avance.
    Août 2010
    Cf ma réponse dans : http://www.developpez.net/forums/d13...onnees-select/
    Cdlt,
    OD
    Cadre
    Septembre 2013
    Activité : Cadre
    Bonjour et merci pour votre réponse.
    facts est un identificateur non valide quand je l'exécute dans Toad.
    AT
    Août 2010
    Re-bonjour,
    Il ne faut pas reprendre ma réponse telle que, mais l'adapter à votre cas ...
    Cdlt,
    OD
    Cadre
    Septembre 2013
    Activité : Cadre
    Oui effectivement, j'avais commis des erreurs dans la transposition.
    Voici ci_dessous la requête définitive qui marche.
    SELECT orfa_arti_code "art"
         , phof_orfa_numero "of"
         , orfa_dt_besoin "Besoin"
         , orfa_designation "Désign"
         , orfa_qte_lance "Qté"
         , max(case when r=1 then poste_ end) AS OP1
         , max(case when r=2 then poste_ end) AS OP2
         , max(case when r=3 then poste_ end) AS OP3
         , max(case when r=4 then poste_ end) AS OP4
         , max(case when r=5 then poste_ end) AS OP5
         , max(case when r=6 then poste_ end) AS OP6
         , max(case when r=7 then poste_ end) AS OP7
         , max(case when r=8 then poste_ end) AS OP8
         , max(case when r=9 then poste_ end) AS OP9
         , max(case when r=10 then poste_ end) AS OP10
         , max(case when r=11 then poste_ end) AS OP11
         , max(case when r=12 then poste_ end) AS OP12
         , max(case when r=13 then poste_ end) AS OP13
         , max(case when r=14 then poste_ end) AS OP14
         , max(case when r=15 then poste_ end) AS OP15
         , max(case when r=16 then poste_ end) AS OP16
         , max(case when r=17 then poste_ end) AS OP17
         , max(case when r=18 then poste_ end) AS OP18
         , max(case when r=19 then poste_ end) AS OP19
         , max(case when r=20 then poste_ end) AS OP20
         , max(case when r=21 then poste_ end) AS OP21
         , max(case when r=22 then poste_ end) AS OP22
         , max(case when r=23 then poste_ end) AS OP23
         , max(case when r=24 then poste_ end) AS OP24
    FROM (SELECT phof_orfa_numero, orfa_arti_code, orfa_dt_besoin, orfa_designation, orfa_qte_lance
               , rank() OVER (PARTITION BY  phof_orfa_numero ORDER BY phof_numero_phase ) AS r
               , phof_post_code AS poste_
            FROM phase_of, ordre_fabrication
                AND phof_orfa_numero = orfa_numero
                AND phof_orfa_numero not in ( '203','207','210','213','218','221','238','249','263',
                '272','8771','8808','8931','10918','11156','11223','17469','17470','17471')--of impro
    GROUP BY phof_orfa_numero, orfa_arti_code, orfa_dt_besoin, orfa_designation, orfa_qte_lance
    ORDER BY 1,2
    Merci encore,
    AT
  1. Simplification de requête
    Par Ludix_ dans le forum Langage SQL
    Réponses: 12
    Dernier message: 13/04/2012, 15h26
  2. Simplification de requêtes SQL
    Par XGuarden dans le forum VB.NET
    Dernier message: 30/12/2010, 12h31
  3. Simplification de requête
    Par Louis-Guillaume Morand dans le forum SQL
    Réponses: 21
    Dernier message: 03/03/2008, 13h26
  4. simplification de requête
    Par GMI3 dans le forum Oracle
    Dernier message: 03/05/2006, 15h47
  5. [Access] simplification de requètes.
    Par pmboutteau dans le forum Langage SQL
    Réponses: 14
    Dernier message: 02/02/2006, 10h04
