1 mars 2013 10:49:17 com.google.appengine.tools.info.RemoteVersionFactory getVersion
INFO: Unable to access https://appengine.google.com/api/updatecheck?runtime=java&release=1.7.4×tamp=1355226091&api_versions=['1.0']
java.net.UnknownHostException: appengine.google.com
    at java.net.PlainSocketImpl.connect(Unknown Source)
    at java.net.Socket.connect(Unknown Source)
    at sun.net.NetworkClient.doConnect(Unknown Source)
    at sun.net.www.http.HttpClient.openServer(Unknown Source)
    at sun.net.www.protocol.https.HttpsClient.<init>(Unknown Source)
    at sun.net.www.protocol.https.HttpsClient.New(Unknown Source)
    at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.getNewHttpClient(Unknown Source)
    at sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source)
    at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(Unknown Source)
    at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
    at sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputStream(Unknown Source)
    at java.net.URL.openStream(Unknown Source)
    at com.google.appengine.tools.info.RemoteVersionFactory.getVersion(RemoteVersionFactory.java:76)
    at com.google.appengine.tools.info.UpdateCheck.checkForUpdates(UpdateCheck.java:99)
    at com.google.appengine.tools.info.UpdateCheck.doNagScreen(UpdateCheck.java:174)
    at com.google.appengine.tools.info.UpdateCheck.maybePrintNagScreen(UpdateCheck.java:142)
    at com.google.appengine.tools.development.DevAppServerMain$StartAction.apply(DevAppServerMain.java:311)
    at com.google.appengine.tools.util.Parser$ParseResult.applyArgs(Parser.java:48)
    at com.google.appengine.tools.development.DevAppServerMain.<init>(DevAppServerMain.java:269)
    at com.google.appengine.tools.development.DevAppServerMain.main(DevAppServerMain.java:245)
1 mars 2013 10:49:18 com.google.apphosting.utils.jetty.JettyLogger info
INFO: Logging to JettyLogger(null) via com.google.apphosting.utils.jetty.JettyLogger
1 mars 2013 10:49:19 com.google.apphosting.utils.config.AppEngineWebXmlReader readAppEngineWebXml
INFO: Successfully processed C:\Users\Curlar\workspace\a\war\WEB-INF/appengine-web.xml
1 mars 2013 10:49:19 com.google.apphosting.utils.config.AbstractConfigXmlReader readConfigXml
INFO: Successfully processed C:\Users\Curlar\workspace\a\war\WEB-INF/web.xml
1 mars 2013 10:49:19 com.google.appengine.tools.development.SystemPropertiesManager setSystemProperties
INFO: Overwriting system property key 'java.util.logging.config.file', value 'C:\Users\Curlar\Desktop\eclipse\plugins\com.google.appengine.eclipse.sdkbundle_1.7.4\appengine-java-sdk-1.7.4\config\sdk\logging.properties' with value 'WEB-INF/logging.properties' from 'C:\Users\Curlar\workspace\a\war\WEB-INF\appengine-web.xml'
1 mars 2013 09:49:20 com.google.apphosting.utils.jetty.JettyLogger info
INFO: jetty-6.1.x
1 mars 2013 09:49:24 com.google.apphosting.utils.jetty.JettyLogger info
INFO: Started SelectChannelConnector@127.0.0.1:8888
1 mars 2013 09:49:24 com.google.appengine.tools.development.DevAppServerImpl start
INFO: The server is running at http://localhost:8888/
INFO: The admin console is running at http://localhost:8888/_ah/admin
started
com.microsoft.sqlserver.jdbc.SQLServerException: Échec de la connexion TCP/IP à l'hôte mail.picosoft.biz, port 1433. Erreur : « Permission denied: Not allowed to issue a socket connect: permission denied.. Vérifiez les propriétés de connexion, assurez-vous qu'une instance de SQL Server est en cours d'exécution sur l'hôte et accepte les connexions TCP/IP au port, et vérifiez qu'aucun pare-feu ne bloque les connexions TCP au port. ».
    at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDriverError(SQLServerException.java:171)
    at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectHelper(SQLServerConnection.java:1033)
    at com.microsoft.sqlserver.jdbc.SQLServerConnection.login(SQLServerConnection.java:817)
    at com.microsoft.sqlserver.jdbc.SQLServerConnection.connect(SQLServerConnection.java:700)
    at com.microsoft.sqlserver.jdbc.SQLServerDriver.connect(SQLServerDriver.java:842)
    at java.sql.DriverManager.getConnection(Unknown Source)
    at a.Formulaire.getConnection(Formulaire.java:24)
    at a.Formulaire.requete(Formulaire.java:36)
    at a.Formulaire.doPost(Formulaire.java:49)
    at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
    at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
    at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:511)
    at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1166)
    at com.google.appengine.api.socket.dev.DevSocketFilter.doFilter(DevSocketFilter.java:74)
    at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1157)
    at com.google.appengine.tools.development.ResponseRewriterFilter.doFilter(ResponseRewriterFilter.java:123)
    at com.google.appengine.tools.development.HeaderVerificationFilter.doFilter(HeaderVerificationFilter.java:34)
    at com.google.appengine.api.blobstore.dev.ServeBlobFilter.doFilter(ServeBlobFilter.java:61)
    at com.google.apphosting.utils.servlet.TransactionCleanupFilter.doFilter(TransactionCleanupFilter.java:43)
    at com.google.appengine.tools.development.StaticFileFilter.doFilter(StaticFileFilter.java:125)
    at com.google.appengine.tools.development.BackendServersFilter.doFilter(BackendServersFilter.java:97)
    at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:388)
    at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
    at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:182)
    at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:765)
    at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:418)
    at com.google.appengine.tools.development.DevAppEngineWebAppContext.handle(DevAppEngineWebAppContext.java:94)
    at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
    at com.google.appengine.tools.development.JettyContainerService$ApiProxyHandler.handle(JettyContainerService.java:383)
    at org.mortbay.jetty.Server.handle(Server.java:326)
    at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:542)
    at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:938)
    at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:755)
    at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:218)
    at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:404)
    at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:409)
    at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThreadPool.java:582)
java.lang.NullPointerException
    at a.Formulaire.requete(Formulaire.java:41)
