Algorithme Min-Max en C appliqué au jeu de Morpion (Tic-Tac-Toe)
    Candidat au Club
    Décembre 2011
    Par défaut Algorithme Min-Max en C appliqué au jeu de Morpion (Tic-Tac-Toe)
    Bonjour à tous, je dois appliquer l'algorithme Minmax en C à un Morpion (ou Tic Tac Toe)... Le problème est que je ne sais pas du tout comment faire...
    voici une partie de mon programme :
    #include "tictactoe.h"
    #include <iostream>
    #include <stdlib.h>
    #include <time.h>
    #include <math.h>
    // Ask for the user to enter its move using the keyboard
    void HumanPlayer(TicTacToe *Game);
    // Random selection of the move
    void RandomPlayer(TicTacToe *Game);
    void AIPlayer(TicTacToe *Game);
    int MinMax(TicTacToe *Game,char Mark, int *ptBest_Move);
    int main(int argc, char *argv[])
    TicTacToe *Game=new TicTacToe; // Create a po inter on a TicTacToe object
    srand ( time(NULL) ); // Initialyze pseudo random generaor using current time
    // ::: Game core :::
    Game->DrawGame(); // Show the game
    while (Game->GameOver()==0) { // Play until the game is over
    if (Game->CurrentPlayer()==CROSS) { // Current player is player one
    cout << "\n ::: Player 1 (Crosses) :::\n";
    HumanPlayer(Game); // Player 1 is the human player
    Game->DrawGame(); // Draw the game after the move
    else {
    cout << "\n::: Player 2 (Circles) :::\n";
    RandomPlayer(Game); // Player 2 is a random player
    // ::: End of the game :::
    std::cout << "\n ::: Game Over ::: \n\n";
    Game->DrawGame();
    switch (Game->GameOver()) { // Print the result of the game
    case CROSS : cout << "\nPlayer 1 wins (CROSSES)\n"; break; // Player 1 is winning
    case CIRCLE : cout << "\nPlayer 2 wins (CIRCLES)\n"; break; // Player 2 is winning
    case DRAW : cout << "\nDraw !\n"; // Draw game
    // ::: Play randomly a move :::
    int Cell=random()%9+1; // Randomly select a move
    while (Game->Play(Cell)==0) // while the move is not possible...
    Cell=random()%9+1; // ... select a new one
    // ::: Human player :::
    int Cell;
    do
    cout << "Dans quelle case jouez-vous : "; // Print a message for the user
    cin >> Cell; // Read the move to the keyboard
    while (Game->Play(Cell)==0); // Until the move is possible
    int Move;
    MinMax(Game,Game->CurrentPlayer(),&Move);
    Game->Play(Move);
    //je dois compléter mais par quoi????
    Merci d'avance pour votre aide...
    Avatar de Franck Dernoncourt
    PhD student in AI @ MIT
    Avril 2010
    Activité : PhD student in AI @ MIT
    1. http://fearyourself.developpez.com/t...morpion/part6/
    2. Ajoute les balises CODE à ton message précédent
    Avatar de Kirilenko
    Décembre 2011
    Je vois du code C++ en plein milieu de ton code C, c'est normal ?
    Récursivité en C : épidémie ou hérésie ?
    "Pour être un saint dans l'Église de l'Emacs, il faut vivre une vie pure. Il faut se passer de tout logiciel propriétaire. Heureusement, être célibataire n'est pas obligé. C'est donc bien mieux que les autres églises" - Richard Stallman
  1. Algorithme Min-Max appliqué au jeu Puissance 4 en C .
    Par hebmaster dans le forum Intelligence artificielle
    Réponses: 17
    Dernier message: 29/10/2012, 08h33
  2. Jeu de grattage / Tic-tac-toe
    Par freegreg dans le forum Téléchargez
    Dernier message: 03/10/2011, 09h38
  3. Parallélisation de l'algorithme Min Max
    Par on2101 dans le forum Intelligence artificielle
    Dernier message: 08/02/2011, 22h08
  4. Algorithme d'élagage alpha-beta en java appliqué au jeu du morpion 3*3
    Par sampaiX dans le forum Intelligence artificielle
    Dernier message: 06/05/2010, 14h38
  5. algorithmes pour morpion/tic tac toe
    Par shirya dans le forum Algorithmes et structures de données
    Dernier message: 17/01/2008, 03h35
