Lorsque j'essaye de lancer le serveur Tomcat.6 pour mon projet sur eclipse ça se bloque et affiche le message suivant:
'Starting Tomcat v6.0 server at localhost has encountered a problem'
'Server Tomcat v6.0 Server at localhost failed to start.'
Voici le console
J'ai reinstallé Tomcat mais le problème persiste
441 sept. 2011 01:20:41 org.apache.catalina.core.AprLifecycleListener init INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\Sun\SDK\jdk\bin;.;C:\Windows\system32;C:\Windows;C:/Program Files/Java/jre6/bin/client;C:/Program Files/Java/jre6/bin;C:/Program Files/Java/jre6/lib/i386;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\MySQL\MySQL Server 5.5\bin;C:\Program Files\Java\jdk1.6.0_23\bin;C:\Sun\SDK\bin 1 sept. 2011 01:20:41 org.apache.tomcat.util.digester.SetPropertiesRule begin ATTENTION: [SetPropertiesRule]{Server/Service/Engine/Host/Context} Setting property 'source' to 'org.eclipse.jst.jee.server:sotetel' did not find a matching property. 1 sept. 2011 01:20:41 org.apache.tomcat.util.digester.SetPropertiesRule begin ATTENTION: [SetPropertiesRule]{Server/Service/Engine/Host/Context} Setting property 'source' to 'org.eclipse.jst.jee.server:Test' did not find a matching property. 1 sept. 2011 01:20:41 org.apache.coyote.http11.Http11Protocol init INFO: Initialisation de Coyote HTTP/1.1 sur http-1191 1 sept. 2011 01:20:41 org.apache.catalina.startup.Catalina load INFO: Initialization processed in 658 ms 1 sept. 2011 01:20:42 org.apache.catalina.core.StandardService start INFO: Démarrage du service Catalina 1 sept. 2011 01:20:42 org.apache.catalina.core.StandardEngine start INFO: Starting Servlet Engine: Apache Tomcat/6.0.33 1 sept. 2011 01:20:42 org.apache.tomcat.util.modeler.Registry registerComponent GRAVE: Null component Catalina:type=JspMonitor,name=jsp,WebModule=//localhost/sotetel,J2EEApplication=none,J2EEServer=none java.lang.reflect.InvocationTargetException at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:585) at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:289) at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:414) Caused by: java.lang.UnsupportedClassVersionError: Bad version number in .class file (unable to load class servlettes.AjouterStation) at org.apache.catalina.loader.WebappClassLoader.findClassInternal(WebappClassLoader.java:2822) at org.apache.catalina.loader.WebappClassLoader.findClass(WebappClassLoader.java:1159) at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1647) at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1526) at org.apache.catalina.startup.WebAnnotationSet.loadApplicationServletAnnotations(WebAnnotationSet.java:108) at org.apache.catalina.startup.WebAnnotationSet.loadApplicationAnnotations(WebAnnotationSet.java:58) at org.apache.catalina.startup.ContextConfig.applicationAnnotationsConfig(ContextConfig.java:297) at org.apache.catalina.startup.ContextConfig.start(ContextConfig.java:1078) at org.apache.catalina.startup.ContextConfig.lifecycleEvent(ContextConfig.java:261) at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:142) at org.apache.catalina.core.StandardContext.start(StandardContext.java:4612) at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1057) at org.apache.catalina.core.StandardHost.start(StandardHost.java:840) at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1057) at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:463) at org.apache.catalina.core.StandardService.start(StandardService.java:525) at org.apache.catalina.core.StandardServer.start(StandardServer.java:754) at org.apache.catalina.startup.Catalina.start(Catalina.java:595) ... 6 more
J'attend votre aide et je vous remercie
 Problème d'exécution de Tomcat
