Problème d'encodage entre C# et servlet tomcat
Servlets/JSP Java
    Décembre 2005
    Par défaut Problème d'encodage entre C# et servlet tomcat
    J'ai une appli écrite en C# (Compact framework 2.0). Elle concatène des paramètres dans l'URL de cette façon (un envoi de fichier est fait plus loin dans le code :
    string url = "http://192.168.20.74:8080/SynchroServer_4/servlet/monservlet");
    string param = "";
    string mimetype = "application/gzip";
    int isize = 0;
    HttpWebRequest request = null;
    Stream SendStream = null;
    byte []receivedbuffer = new byte[512];
    param += "&" + Globals.COMMENT_PARAMETER + "=" + HttpUtility.UrlEncode(m_comment);
    url += "?" + param;
    request = HttpTransmission.CreateRequest(url, mimetype, isize, "POST");
    SendStream = request.GetRequestStream();
    La méthode HTTPTransmission.CreateRequest :
     public static HttpWebRequest CreateRequest(string url, string contenttype, int contentlength, string method)
                HttpWebRequest req = (HttpWebRequest)WebRequest.Create(url);
                req.ContentLength = contentlength;
                req.ContentType = contenttype;
                req.Method = method;
                req.AllowAutoRedirect = true;
                req.Proxy = new WebProxy();
                req.Timeout = TIMEOUT;
                return (req);
    La classe HttpUtility :
    private static Encoding inputEncoding = Encoding.Default;
    private static Encoding outputEncoding = Encoding.UTF8;
    public static string UrlEncode(string input)
                string result = null;
                byte[] buffer = null;
                byte[] input = null;
                if (input_string != null)
                    input = inputEncoding.GetBytes(input_string);
                    if (input != null)
                        buffer = UrlEncodeToBytes(input, 0, input.Length);
                        if (buffer != null)
                            result = outputEncoding.GetString(buffer, 0, buffer.Length);
                return (result);
     /// <summary>
            /// Encode the input and protects needed characters
            /// return the result to a byte array
            /// </summary>
            /// <param name="bytes"></param>
            /// <param name="offset"></param>
            /// <param name="count"></param>
            /// <returns></returns>
            public static byte[] UrlEncodeToBytes(byte[] bytes, int offset, int count)
                byte[] result = null;
                List<byte> buffer = null;
                int lastIndex = 0;
                int i = 0;
                int index = 0;
                char current_char = '\0';
                if (bytes != null && bytes.Length > 0)
                    if (offset < 0 || offset >= bytes.Length)
                    { throw new ArgumentOutOfRangeException("offset"); }
                    if (count < 0 || offset < (bytes.Length - count))
                    { throw new ArgumentOutOfRangeException("count"); }
                    buffer = new List<byte>();
                    for (i = offset, lastIndex = offset + count; i < lastIndex; i++)
                        current_char = Convert.ToChar(bytes[i]);
                        //According to the documentation I've found, we only need to encode characters when:
                        //  --> the character is a control char
                        //  --> the character is a non-ascii character (byte value is between [0x80 and 0xFF])
                        //  --> the character is a white space
                        //  --> the character is a reserved char or unsafe char
                        if (char.IsControl(current_char)
                            (current_char >= 0x80 && current_char <= 0xFF)
                            char.IsWhiteSpace(current_char)
                            (System.Array.IndexOf<char>(g_ReservedCharacters, current_char) != -1))
                            if (current_char == ' ')
                                //Special case to for space char : we transform it as a plus
                                //Allow us to generate smaller url than using the hexadecimal notation '%20'
                                buffer.Add(Convert.ToByte('+'));
                            else
                                //We add the hexadecimal value
                                //We take the 4 highest bits to retrieve its hexa value
                                //For example : if current_char == '+'
                                //Its integer value is 0x0000002B
                                //and its integer value applied to operator >> 4 equals 2. So we take the character which is
                                //at index 2 in the g_HexadecimalCharacters array (for us : '2').
                                //Then we apply the mask 0x0000000F on the integer value of the char : 0x000000B
                                //Finally we take the character which is at index 0xB (== 11 dec) in the g_HexadecimalCharacters array (for us : 'B')
                                index = Convert.ToInt32(current_char) >> 4; //We process the high order bits...
                                buffer.Add(Convert.ToByte('%')); buffer.Add(Convert.ToByte(g_HexadecimalCharacters[index]));
                                index = Convert.ToInt32(current_char) & 0x0000000F; //We keep the last 4 bits
                        else
                            //We simply add the value...
                            buffer.Add(Convert.ToByte(current_char));
                    if (buffer.Count > 0)
                        result = buffer.ToArray();
                return (result);
    Coté Tomcat :
    protected void doPost(HttpServletRequest arg0, HttpServletResponse arg1) throws ServletException, IOException {
    		processRequest(arg0,arg1);
    protected void processRequest(HttpServletRequest request, HttpServletResponse response)
            request.setCharacterEncoding("UTF8");
    	string Comment = request.getParameter(Globals.COMMENT_PARAMETER);
    System.out.println("Setting comments : " + Comments);
    J'obtiens (les caractères étranges étants des "é" et "è")
    Setting comments to order 110563867 : xghjuhuffdèéèéèéèéè
    Merci d'avance !
    Décembre 2005
    C'est réparé.
    Le problème venait de URLEncode et des encodage d'entrées/sorties.
    J'ai modifié le code du précédent post avec les bons paramètres.
  1. Problème d'encodage entre C++ et C#
    Par Olivier_helin dans le forum SQLite
    Dernier message: 14/03/2012, 12h12
  2. Servlet Tomcat problème chargement librairie
    Par Vlacar dans le forum Servlets/JSP
    Dernier message: 05/05/2010, 14h23
  3. Réponses: 14
    Dernier message: 22/07/2007, 19h02
  4. problème avec encodage caractère Servlets
    Par dialloma dans le forum Servlets/JSP
    Dernier message: 06/07/2007, 10h09
  5. Problème de communication entre php et Laszlo(Tomcat)
    Par YUN59 dans le forum Autres langages pour le Web
    Dernier message: 21/07/2006, 14h45
