j'ai créé mon loginmodule MyloginModule,
je l'ai declaré dans un fichier jaas.config :
Sample{
com.security.MyLoginModule required debug=true;
je lance la JVM avec cette ligne de commande sous eclipse :
-Dprogram.name=run.bat -Xms128m -Xmx512m -XX:MaxPermSize=256m
-Djava.security.auth.login.config=C:/jaas/jaas.config
et j'obtiens cette erreur lors du test d'authentification lc.login();
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
22:19:19,406 ERROR [org.jboss.security.auth.spi.UsersRolesLoginModule] Failed to load users/passwords/role files: java.io.IOException: No properties file: users.properties or defaults: defaultUsers.properties found
	at org.jboss.security.auth.spi.Util.loadProperties(Util.java:201)
	at org.jboss.security.auth.spi.UsersRolesLoginModule.loadUsers(UsersRolesLoginModule.java:186)
	at org.jboss.security.auth.spi.UsersRolesLoginModule.createUsers(UsersRolesLoginModule.java:200)
	at org.jboss.security.auth.spi.UsersRolesLoginModule.initialize(UsersRolesLoginModule.java:127)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
	at java.lang.reflect.Method.invoke(Method.java:597)
	at javax.security.auth.login.LoginContext.invoke(LoginContext.java:756)
	at javax.security.auth.login.LoginContext.access$000(LoginContext.java:186)
	at javax.security.auth.login.LoginContext$4.run(LoginContext.java:683)
	at java.security.AccessController.doPrivileged(Native Method)
	at javax.security.auth.login.LoginContext.invokePriv(LoginContext.java:680)
	at javax.security.auth.login.LoginContext.login(LoginContext.java:579)
	at com.ManagedBean.ConnectionManagedBean.doSignOn(ConnectionManagedBean.java:93)
	at org.apache.el.parser.AstValue.invoke(AstValue.java:196)
	at org.apache.el.MethodExpressionImpl.invoke(MethodExpressionImpl.java:276)
	at org.apache.jasper.el.JspMethodExpression.invoke(JspMethodExpression.java:68)
	at javax.faces.component.MethodBindingMethodExpressionAdapter.invoke(MethodBindingMethodExpressionAdapter.java:88)
	at com.sun.faces.application.ActionListenerImpl.processAction(ActionListenerImpl.java:102)
	at javax.faces.component.UICommand.broadcast(UICommand.java:315)
	at javax.faces.component.UIViewRoot.broadcastEvents(UIViewRoot.java:775)
	at javax.faces.component.UIViewRoot.processApplication(UIViewRoot.java:1267)
	at com.sun.faces.lifecycle.InvokeApplicationPhase.execute(InvokeApplicationPhase.java:82)
	at com.sun.faces.lifecycle.Phase.doPhase(Phase.java:101)
	at com.sun.faces.lifecycle.LifecycleImpl.execute(LifecycleImpl.java:118)
	at javax.faces.webapp.FacesServlet.service(FacesServlet.java:312)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:336)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:242)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:276)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
	at org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAssociationValve.java:183)
	at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:95)
	at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.process(SecurityContextEstablishmentValve.java:126)
	at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.invoke(SecurityContextEstablishmentValve.java:70)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
	at org.jboss.web.tomcat.service.jca.CachedConnectionValve.invoke(CachedConnectionValve.java:158)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:368)
	at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:872)
	at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:653)
	at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:951)
	at java.lang.Thread.run(Thread.java:619)
22:19:19,409 ERROR [STDERR] javax.security.auth.login.LoginException: Missing users.properties file.
22:19:19,409 ERROR [STDERR] 	at org.jboss.security.auth.spi.UsersRolesLoginModule.login(UsersRolesLoginModule.java:148)
22:19:19,409 ERROR [STDERR] 	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
22:19:19,409 ERROR [STDERR] 	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
22:19:19,409 ERROR [STDERR] 	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
22:19:19,409 ERROR [STDERR] 	at java.lang.reflect.Method.invoke(Method.java:597)
22:19:19,410 ERROR [STDERR] 	at javax.security.auth.login.LoginContext.invoke(LoginContext.java:769)
22:19:19,410 ERROR [STDERR] 	at javax.security.auth.login.LoginContext.access$000(LoginContext.java:186)
22:19:19,410 ERROR [STDERR] 	at javax.security.auth.login.LoginContext$4.run(LoginContext.java:683)
22:19:19,410 ERROR [STDERR] 	at java.security.AccessController.doPrivileged(Native Method)
22:19:19,410 ERROR [STDERR] 	at javax.security.auth.login.LoginContext.invokePriv(LoginContext.java:680)
22:19:19,410 ERROR [STDERR] 	at javax.security.auth.login.LoginContext.login(LoginContext.java:579)
22:19:19,410 ERROR [STDERR] 	at com.ManagedBean.ConnectionManagedBean.doSignOn(ConnectionManagedBean.java:93)
22:19:19,411 ERROR [STDERR] 	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
22:19:19,411 ERROR [STDERR] 	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
22:19:19,411 ERROR [STDERR] 	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
22:19:19,411 ERROR [STDERR] 	at java.lang.reflect.Method.invoke(Method.java:597)
22:19:19,411 ERROR [STDERR] 	at org.apache.el.parser.AstValue.invoke(AstValue.java:196)
22:19:19,411 ERROR [STDERR] 	at org.apache.el.MethodExpressionImpl.invoke(MethodExpressionImpl.java:276)
22:19:19,411 ERROR [STDERR] 	at org.apache.jasper.el.JspMethodExpression.invoke(JspMethodExpression.java:68)
22:19:19,412 ERROR [STDERR] 	at javax.faces.component.MethodBindingMethodExpressionAdapter.invoke(MethodBindingMethodExpressionAdapter.java:88)
22:19:19,412 ERROR [STDERR] 	at com.sun.faces.application.ActionListenerImpl.processAction(ActionListenerImpl.java:102)
22:19:19,412 ERROR [STDERR] 	at javax.faces.component.UICommand.broadcast(UICommand.java:315)
22:19:19,412 ERROR [STDERR] 	at javax.faces.component.UIViewRoot.broadcastEvents(UIViewRoot.java:775)
22:19:19,412 ERROR [STDERR] 	at javax.faces.component.UIViewRoot.processApplication(UIViewRoot.java:1267)
22:19:19,412 ERROR [STDERR] 	at com.sun.faces.lifecycle.InvokeApplicationPhase.execute(InvokeApplicationPhase.java:82)
22:19:19,412 ERROR [STDERR] 	at com.sun.faces.lifecycle.Phase.doPhase(Phase.java:101)
22:19:19,413 ERROR [STDERR] 	at com.sun.faces.lifecycle.LifecycleImpl.execute(LifecycleImpl.java:118)
22:19:19,413 ERROR [STDERR] 	at javax.faces.webapp.FacesServlet.service(FacesServlet.java:312)
22:19:19,413 ERROR [STDERR] 	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:336)
22:19:19,413 ERROR [STDERR] 	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:242)
22:19:19,413 ERROR [STDERR] 	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:276)
22:19:19,413 ERROR [STDERR] 	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
22:19:19,413 ERROR [STDERR] 	at org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAssociationValve.java:183)
22:19:19,414 ERROR [STDERR] 	at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:95)
22:19:19,414 ERROR [STDERR] 	at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.process(SecurityContextEstablishmentValve.java:126)
22:19:19,414 ERROR [STDERR] 	at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.invoke(SecurityContextEstablishmentValve.java:70)
22:19:19,414 ERROR [STDERR] 	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
22:19:19,414 ERROR [STDERR] 	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
22:19:19,415 ERROR [STDERR] 	at org.jboss.web.tomcat.service.jca.CachedConnectionValve.invoke(CachedConnectionValve.java:158)
22:19:19,415 ERROR [STDERR] 	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
22:19:19,415 ERROR [STDERR] 	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:368)
22:19:19,415 ERROR [STDERR] 	at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:872)
22:19:19,415 ERROR [STDERR] 	at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:653)
22:19:19,415 ERROR [STDERR] 	at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:951)
22:19:19,417 ERROR [STDERR] 	at java.lang.Thread.run(Thread.java:619)
J'ai rajouté des logs avant l'appel de l'authentification
22:54:41,823 INFO  [STDOUT] java.security.auth.login.config = C:/jaas/jaas.config
22:54:41,823 INFO  [STDOUT] Configuration.getConfiguration() = org.jboss.security.auth.login.XMLLoginConfigImpl@4b436982
22:54:41,823 INFO  [STDOUT] config.getAppConfigurationEntry("Sample")
22:54:41,823 INFO  [STDOUT] loginModuleEntries[i].getLoginModuleName() = org.jboss.security.auth.spi.UsersRolesLoginModule
le module de login utilisé par la mon appli est UsersRolesLoginModule a la place de Myloginmodule ... d'ou l'erreur
Je ne trouve pas ou est mon erreur svp si quelqu'un a la moindre piste j'apprecirai car cela fait 2 jours que je suis la dessus et je commence a craquer
