[INTERFACE GRAPHIQUE] Bouton et CheckBox
    Membre éclairé Avatar de Hoegaarden
    Avril 2004
    Par défaut [INTERFACE GRAPHIQUE] Bouton et CheckBox
    J'ai créé une JFrame avec 2 JPanel à l'intérieur.
    Un JPanel contenant un bouton:
    class GenButton extends JPanel implements ActionListener{
    	GenButton()	{
    		JPanel buttonPanel = new JPanel();
    		JButton genButton = new JButton("Generate File");
    		genButton.addActionListener(this);
    		buttonPanel.add(genButton);
    		add(buttonPanel);
    	public void actionPerformed(ActionEvent e){
    et un JPanel contenant des CheckBoxes que j'incrémente dynamiquement:
    class CheckBoxes extends JPanel	{
    	int nbFiles;
    	JCheckBox checkBox = new JCheckBox();
    	CheckBoxes()	{
    		CountFiles();
    		JPanel checkboxPanel =  new JPanel();
    		checkboxPanel.setLayout(new GridLayout(nbFiles, 1));
    		for (int j=0; j<SearchFiles().length; j++)	{
    			checkBox = new JCheckBox(SearchFiles()[j], false);
    			checkboxPanel.add(checkBox);
    		add(checkboxPanel);
    	public void CountFiles()	{
    		FileFilter fileFilter = new FileFilter() {
                public boolean accept(File file) {
                	String nameFile = file.getName();
                	return nameFile.endsWith(".txt");
    		File source = new File("C:\Work");
    		File[] dirContent = source.listFiles(fileFilter);	//browse the source folder
    		nbFiles = dirContent.length;
    	public String[] SearchFiles()	{
    		String modele = "^(\\w{3}).*";
    		Pattern pattern = Pattern.compile(modele);
    		File f = null;
    		String[] result = new String[dirContent.length];
    		for (int i=0; i<dirContent.length; i++) {
    			f = dirContent[i];
    			Matcher matcher = pattern.matcher(f.getName());
    			if (matcher.matches()){
    				result[i] = matcher.group(1);
    		return result;
    et voilà le main:
    public static void main(String[] argv)	{
    		JFrame frame = new JFrame("Test");
    		JPanel buttonPanel = new GenButton();
    		JScrollPane scrollPane = new JScrollPane(new CheckBoxes());
    		JPanel mainPanel = new JPanel();
    		mainPanel.setLayout(new GridLayout());
    		mainPanel.add(buttonPanel);
    	    mainPanel.add(scrollPane);
    	    frame.getContentPane().add(mainPanel);
    	    frame.setSize(200,500);
    	    frame.setLocationRelativeTo(frame.getParent());
    	    frame.setVisible(true);
    	    frame.addWindowListener(new WindowAdapter()
    			    	public void windowClosing(WindowEvent evt)
    			    		System.exit(0);
    Ce que je veux faire maintenant c'est de sélectionner des checkbox et que lorsque je clique sur le bouton il écrive dans un fichier les checkbox sélectionnées. Mais à part l'écriture dasn le fichier je ne sais pas comment récupérer les Checkbox cochées.
    Quelqu'un aurait une idée.
    Merci par avance.
    Membre émérite Avatar de Pollux
    Avril 2005
    Tu peux utiliser la méthode isSelected pour savoir si une combo est sélectionnée...
    Tu testes tes combos et ainsi tu sais lesquelles sont sélectionnées...
    Consultant informatique
    Janvier 2004
    Hello,
    if(myCheckBox.isSelected())
      write(myCheckBox);
    [Edit] grilled de 21 secondes
    Avril 2004
    Le problème dans la solution que vous prposez et que si vous regardez mon code toutes les checkbox générées ont le même nom.
    Donc votre solution ne marchera à priori que pour la dernière checkbox.
    Avatar de natha
    Janvier 2006
    Fait un tableau de JCheckBox pour garder une référence sur chaque.
    Membre émérite Avatar de Spoutnik
    Octobre 2003
    ou alors tu récupère la liste des checkbox avec un
    checkboxPanel.getComponents()
    (qui vient de 'Container')[/code]
    Avril 2004
    J'ai fait un truc comme ça sur les conseils de Spoutnik:
    	public void actionPerformed(ActionEvent e)	{
    		try	{
    		CheckBoxes checkbox = new CheckBoxes();
    		Component[] CheckBoxRecup = checkbox.checkboxPanel.getComponents();
    		PrintWriter output = new PrintWriter(new FileWriter("C:\\Work\\test.txt")); //Output file
    		for (int i=0; i<CheckBoxRecup.getComponentCount(); i++)	{
    			if (CheckBoxRecup[i].)	{
    				output.println("ok");
    		output.close();
    		}	catch (IOException q)	{
    			q.getMessage();
    Mais dans mon if je ne sais pas comment faire pour lui dire de vérifier si ma checkbox est cochée ou pas.
    Janvier 2004
    if ( (CheckBoxRecup[i] instanceof JCheckBox) &&
        ((JCheckBox) CheckBoxRecup[i]).isSelected() ) ...
    Avatar de natha
    Janvier 2006
    J'préfère quand même le tableau de JCheckBox moi...
    Avril 2004
    Ca ne marche pas pour lui rien n'est sélectionné.
    voici mon code:
    		try	{
    		for (int i=0; i<CheckBoxRecup.length; i++)	{
    			if ((CheckBoxRecup[i] instanceof JCheckBox) && ((JCheckBox) CheckBoxRecup[i]).isSelected())	{
    		output.close();
    			q.getMessage();
    Janvier 2004
    Citation Envoyé par natha
    moi je préfère une variable par check box (si y'en a pas 1'000'000)
    comment identifier facilement de quelle check box il s'agit sinon ? je trouve la notation
    checkBoxes[i].isSelected()
    vraiment pas claire...
    c'est beaucoup mieux avec
    maCheckBoxQuiSertAActiverLeDoubleBufferingDeMonAppli.isSelected();
    (bon évidemment c'est un peu exagéré là...)
    EDIT: à quoi te sert cette ligne ??
    c'est là que ça bug d'après moi
    Avatar de natha
    Janvier 2006
    Citation Envoyé par Pill_S
    Tout à fait. En fait j'ai jamais fait de tableaux de composants comme ça, faut voir le cas, si c'est dynamique c'est mieux un tableau Et là en l'occurence, ça m'a tout l'air dynamique !
    Avril 2004
    Je n'ai pas de problème particulier pour faire cela avec un tableau ou bien en donnant un nom différent à chaque variable.
    Mais si tu regardes mon code dansle premier post comment veux tu que je donne un nom différents à chaque checkbox alors que je les génère dynamiquement ?
    En même temps je suis un peu limité en java
    sinon
    sert à aller chercher le Jpanel qui contient toutes les checkBox.
    Avatar de natha
    Janvier 2006
    Citation Envoyé par Hoegaarden
    sinon
    Oula d'accord... tu risques pas de les voir, tes JCheckBox cochées si tu crée une nouvelle instance de ton panel...
    Avril 2004
    ok d'accord comment faire alors ?
    Janvier 2004
    en même temps, je l'ai pas lu ton code, beaucoup trop gros pour la question qui en découlait..... c'était un principe général que j'expliquais
    mais bon, après lecture, je peux déjà dire qu'il faut que tu garde une référence sur l'instance de CheckBoxes que tu met dans le scrollPane, puisque c'est cette instance là qui te permet de récupérer les check box
    private CheckBoxes checkBoxes = new CheckBoxes();
    JScrollPane scrollPane = new JScrollPane(checkBoxes );
    Component[] CheckBoxRecup = checkBoxes.checkboxPanel.getComponents();
    Octobre 2003
    Par défaut Re: [INTERFACE GRAPHIQUE] Bouton et CheckBox
    	int nbFiles;
    	CheckBoxes()	{
    		CountFiles();
    		add(checkboxPanel);
    Tu crée une classe qui dérive de JPanel, puis dans le constructeur, tu y ajoute un panel ( add(checkboxPanel); ) et dans ce panel, tu as la checkbox . Ca fait au moins un panel en trop (a priori en ts cas).
    	int nbFiles;
    	CheckBoxes()	{
    		CountFiles();
                    super().setLayout(new GridLayout(nbFiles, 1));
    			this.add(new JCheckBox(SearchFiles()[j], false));
    idem dans le main, le "mainPanel" me semble inutile.
                    CheckBoxes checkBoxesPanel = new CheckBoxes();
    		JScrollPane scrollPane = new JScrollPane(checkBoxesPanel);
    		frame.getContentPane().setLayout(new GridLayout());
    	        frame.getContentPane().add(buttonPanel);
                    frame.getContentPane().add(scrollPane);
    			    		System.exit(0);
    Code non compilé
  1. [Débutant] Paramétrer une interface graphique avec des checkboxs
    Par Invité dans le forum Interfaces Graphiques
    Dernier message: 03/07/2014, 13h17
  2. [Débutant] Création interface graphique, bouton poussoir
    Par celtic29 dans le forum Interfaces Graphiques
    Dernier message: 20/04/2012, 11h19
  3. Interface graphique et clic de bouton
    Par Tsukaasa dans le forum EDT/SwingWorker
    Dernier message: 12/09/2008, 17h13
  4. Bouton d'interface graphique bloqué
    Par levalp dans le forum Windows Forms
    Réponses: 26
    Dernier message: 07/02/2008, 10h43
  5. interface graphique avec bouton parcourir
    Par Wael Maaoui dans le forum Tkinter
    Dernier message: 26/03/2007, 13h00
