Fusionner 2 requêtes en 1 [10g]
    Technicien maintenance
    Juillet 2006
    Par défaut Fusionner 2 requêtes en 1
    Je souhaite fusionner 2 requêtes, afin d'avoir le résultat en 1 fois. N'étant pas très doué en sql, est ce qu'une âme charitable pourrait me donner un petit coup de pouce.
    Je vous en remercie.
    Cordialement
    Laurent
    Requête 1:
    select
      B.cd_cost_center, substr(A.cd_box,1, 5) eqpts, substr(sum(C.pr_hour_cost * C.tm_occupation)/100000,1, 6) tot_PREV
        from
        WO A
        INNER JOIN WS B
        on A.cd_wo = B.cd_wo
       INNER JOIN OCCUPATION C
       on C.cd_wo = A.cd_wo
       and C.cd_ws = B.cd_ws
       where
              B.cd_action_type = 'PREV_N_PRO'
              or
              B.cd_action_type = 'INTERV_PRO'
              or
              B.cd_action_type = 'PREV'
       and B.dt_ws_begin >= to_date('01022015 00:00:01','DDMMYYYY HH24:MI:SS')
       and B.dt_ws_begin <= to_date('28022015 23:59:59','DDMMYYYY HH24:MI:SS')
    group by B.cd_cost_center, substr(A.cd_box,1, 5)
    order by 1, 2
    Résultat 1 obtenu:
    CD_COST_CENTER EQPTS TOT_PR
    valeur A valeur B Valeur C
    Requête 2:
    select
      B.cd_cost_center, substr(A.cd_box,1, 4) eqpts, substr(sum(C.pr_hour_cost * C.tm_occupation)/100000,1, 6) tot_Cur
        from
        WO A
        INNER JOIN WS B
       where B.cd_action_type = 'CUR'
    group by B.cd_cost_center, substr(A.cd_box,1, 4)
    order by 1, 2
    Résultat 2 obtenu:
    CD_COST_CENTER EQPTS TOT_CU
    valeur A valeur B Valeur D
    Résultat souhaité:
    CD_COST_CENTER EQPTS TOT_PR TOT_CU
    valeur A valeur B Valeur C Valeur D
    Membre émérite Avatar de bstevy
    Solutions Architect
    Mai 2009
    Activité : Solutions Architect
    De manière très bourrin, ca donne ca (mais c'est optimisable)
    select	 coalesce(A.cd_cost_center, B.cd_cost_center) as cd_cost_center
    		,coalesce(A.eqpts, B.eqpts) as eqpts
    		,tot_PREV
    		,tot_Cur
    FROM
    (select
        from
        WO A
        INNER JOIN WS B
       where
              or
              or
    ) A
    FULL OUTER JOIN
    select
        from
        WO A
        INNER JOIN WS B
    ) B ON A.cd_cost_center = B.cd_cost_center and A.eqpts = B.eqpts
    order by 1,2
    Avatar de Waldar
    Oui il y a mieux que le FULL JOIN :
    with cte_union (A, B, C, D) as
    select A, B, C, null
      from table
     union all
    select A, B, null, D
      from table
      select A, B, max(C) as C, max(D) as D
        from cte_union
    group by A, B;
    Mais dans ce cas de figure présent, on peut réécrire la requête complètement :
      select B.cd_cost_center
           , substr(A.cd_box, 1, 5) as eqpts
           , substr(sum(case when B.cd_action_type in ('PREV', 'PREV_N_PRO', 'INTERV_PRO') then C.pr_hour_cost * C.tm_occupation else 0 end) / 100000, 1, 6) as tot_PREV
           , substr(sum(case when B.cd_action_type = 'CUR'                                 then C.pr_hour_cost * C.tm_occupation else 0 end) / 100000, 1, 6) as tot_Cur
        from WO         A
        join WS         B  on B.cd_wo = A.cd_wo
        join OCCUPATION C  on C.cd_wo = A.cd_wo
       where B.dt_ws_begin >= to_date('01022015 00:00:01','DDMMYYYY HH24:MI:SS')
         and B.cd_action_type in ('CUR', 'PREV', 'PREV_N_PRO', 'INTERV_PRO')
    order by B.cd_cost_center       asc
           , substr(A.cd_box, 1, 5) asc;
    Juillet 2006
    Excellent, exactement ce que je souhaitais.
    Merci pour vos réponses.
    Cordialement
    Laurent
  1. fusionner des requêtes
    Par bourguignon21 dans le forum Requêtes et SQL.
    Dernier message: 11/07/2007, 11h54
  2. [Oracle 9i] Fusionner 2 requêtes
    Par supermarsu dans le forum Langage SQL
    Dernier message: 22/05/2007, 09h52
  3. [MySQL] Fusionner deux requêtes
    Par jpascal dans le forum PHP & Base de données
    Dernier message: 27/12/2006, 02h51
  4. Fusionner des requêtes
    Par SwiTz dans le forum Requêtes
    Dernier message: 08/11/2005, 23h00
  5. Fusionner 3 requêtes avec un SUM en une seule
    Par David Guillouet dans le forum Langage SQL
    Dernier message: 28/07/2004, 16h54
