Spring Java Discussion :
Problème à partir mon JUnit
Spring Java
    Mai 2002
    Par défaut Problème à partir mon JUnit
    bonjour a tous voici mon code
    package ractifs;
    import java.util.Locale;
    import javax.servlet.http.HttpServletRequest;
    import javax.servlet.http.HttpServletResponse;
    import junit.framework.TestCase;
    import org.junit.Before;
    import org.junit.runner.RunWith;
    import org.springframework.beans.factory.annotation.Autowired;
    import org.springframework.test.context.ContextConfiguration;
    import org.springframework.test.context.TestContext;
    import org.springframework.test.context.junit4.SpringJUnit4ClassRunner;
    import org.springframework.test.context.web.WebAppConfiguration;
    @RunWith(SpringJUnit4ClassRunner.class)
    @ContextConfiguration(locations = {"classpath:lel-servlet.xml", "classpath:lel-servlet.xml"})
    @WebAppConfiguration
    public class ctifsTest extends TestCase
        @Autowired
        private TickerCache tickerCache;
        private Form form;
        Locale locale;
        HttpServletRequest request;
        HttpServletResponse response;
        @Before
        public void setUp() throws Exception
            form = new Form();
            // modele = new Model();
            locale = new Locale("fr", "CA");
            // request = new HttpServletRequest();
            // response = new HttpServletResponse();
        public void testTest() throws Exception
            try
                ctifs controller = new ctifs();
                tickerCache = tickerCache;
                // ModelAndView modelAndView = controller. .handleRequest(null,
                // null);
                String test = controller.jeu(form, null, locale, null, "demo", "BmonJeton", null);
            catch (Exception e)
                e.printStackTrace();
    Deja , j'ai une erreur niveau du package
    Description Resource Path Location Type
    The project was not built since its build path is incomplete. Cannot find the class file for org.springframework.context.ApplicationContextInitializer. Fix the build path then try building this projec Unknown Java Problem
    The type org.springframework.context.ApplicationContextInitializer cannot be resolved. It is indirectly referenced from required .class files ctifsTest .java jeu line 1 Java Problem
    et quand je lance le junit j ai un
    java.lang.NoSuchFieldError: NULL
    at org.junit.runners.ParentRunner.<init>(ParentRunner.java:54)
    at org.junit.runners.BlockJUnit4ClassRunner.<init>(BlockJUnit4ClassRunner.java:55)
    at org.springframework.test.context.junit4.SpringJUnit4ClassRunner.<init>(SpringJUnit4ClassRunner.java:104)
    at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
    at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
    at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
    at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
    at org.junit.internal.requests.ClassRequest.buildRunner(ClassRequest.java:33)
    at org.junit.internal.requests.ClassRequest.getRunner(ClassRequest.java:28)
    at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.<init>(JUnit4TestReference.java:33)
    at org.eclipse.jdt.internal.junit4.runner.JUnit4TestClassReference.<init>(JUnit4TestClassReference.java:25)
    at org.eclipse.jdt.internal.junit4.runner.JUnit4TestLoader.createTest(JUnit4TestLoader.java:48)
    at org.eclipse.jdt.internal.junit4.runner.JUnit4TestLoader.loadTests(JUnit4TestLoader.java:38)
    at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:452)
    at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683)
    at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390)
    at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:197)
    je pense bien avoir un genre de conflit. Endirait qu'il trouve pas ApplicationContextInitializer pour mettre mon DispatcherServlet
    voici mon pom
    <dependency>
    <groupId>org.jmock</groupId>
    <artifactId>jmock-junit4</artifactId>
    <version>2.6.0</version>
    </dependency>
    <dependency>
    <groupId>org.springframework</groupId>
    <artifactId>spring-test</artifactId>
    <version>3.2.3.RELEASE</version>
    <scope>test</scope>
    </dependency>
    <dependency>
    <groupId>junit</groupId>
    <artifactId>junit</artifactId>
    <scope>test</scope>
    </dependency>
    pour une version 4.4 de junit
    puis-je avoir de l'aide svp pour savoir ce qui se passe merci
    Mai 2002
    Par défaut RESOLU
    tout est beau, c'etait un mauvais problème. Juste que ressource n'est pas donc mon classPath.
  1. problème sur mon ordi
    Par loveflower dans le forum Sécurité
    Dernier message: 29/11/2005, 17h18
  2. [MySQL] Problème dans mon script de pagination
    Par speedylol dans le forum PHP & Base de données
    Dernier message: 03/11/2005, 20h37
  3. Problème avec mon service mysql et PhpMyAdmin
    Par Fixazo dans le forum Outils
    Dernier message: 28/08/2005, 19h02
  4. problème avec mon lecteur CD
    Par leo13 dans le forum Périphériques
    Dernier message: 16/08/2005, 12h21
  5. Problème avec mon firewall ...
    Par Wis dans le forum Tomcat et TomEE
    Réponses: 15
    Dernier message: 06/04/2004, 09h46
