avec Java Discussion :
probleme code java
avec Java
    Avril 2009
    Par défaut probleme code java
    salut j ai ecrit ce bou de code
    119
    120
    121
    122
    123
    124
    125
    126
    127
    128
    129
    130
    131
    132
    133
    134
    135
    136
    137
    138
    139
    140
    141
    package com.iris;
    import javax.jws.WebMethod;
    import javax.jws.WebParam;
    import javax.jws.WebService;
    import java.sql.*;
    /*import java.lang.*;
     * @author hedi
    @WebService()
    public class NewWebService {
        private String etatfact;
       static int distcode ;
        int tournee ;
        int ordre ;
        int categcode ;
        int rolecode ;
        int reference ;
        int montant ;
         * Web service operation
        public void setetatfact(String v) {
            this.etatfact = v;
        public String getetatfact() {
            return this.etatfact;
     /*   @WebMethod(operationName = "cosult_imp")
        public String cosult_imp(integer distcode, integer tournee, integer ordre, integer categcode, integer rolecode, integer reference, numeric montant)
            ResultSet res=null;
            try {
            	String sql = "select  etat from facture where idfac=" + idfacture + " and reference=" + reference;
    if(SQLManager.ConnectBase()==true)  {
                    Statement statement = SQLManager.connection.createStatement();
                    res=statement.executeQuery(sql);
    		if (res.next()){
                        Boolean bb = res.getBoolean("etat");
                        System.out.println(bb.toString());
                        setetatfact(bb.toString());
    }else{
                System.out.println("ERREUR CONNEXTION");
            }catch(Exception e){
                System.out.println(e.toString());
                try
    Class.forName("org.postgresql.Driver");
    Connection connexion = DriverManager.getConnection("jdbc:postgresql://<127.0.0.1>:<5432>/<bddemosonede2>", "postgres", "admin");
     java.sql.Statement instruction=connexion.createStatement() ;
           ResultSet retour= instruction.executeQuery("select etat from facture where idfac="+idfacture+" and reference="+reference );
           System.out.println("select etat from facture where idfac="+idfacture+" and reference="+reference );
    if (retour.next()){
    //Envoyer une requete Deux Methode
    //Requete sans retour de donnée (INSERT, CREATE....)
    //boolean retour= instruction.execute("requete sql");
    //Requete avec retour de donnée (SELECT)
    boolean bb = retour.getBoolean("etat");
    System.out.println(bb);
    setetatfact("tttt");
    connexion.close();
            catch
                     (Exception sql_erreur) {
    //Gestion de l'exception d'erreur de connection à la base ou erreur de requete sql
                System.err.print("Erreur SQL ") ;
                //TODO write your implementation code here:
              /*  return getetatfact();
        @WebMethod(operationName = "consulter_imp")
        public String consulter_imp(@WebParam(name = "distcode")
        int distcode, @WebParam(name = "tournee")
        int tournee, @WebParam(name = "ordre")
        int ordre, @WebParam(name = "categcode")
        int categcode, @WebParam(name = "rolecode")
        int rolecode, @WebParam(name = "reference")
        int reference, @WebParam(name = "montant")
        int montant) {
             ResultSet res=null;
            try {
            	String sql = "select  etat from facture where distcode=" + distcode + " and tournee=" + tournee + "and ordre="+ordre+"and categcode="+categcode+"and rolecode="+rolecode+"and reference="+reference+"and montant="+montant;
                   		if (res.next())
                                distcode=res.getInt("distcode");
                                tournee=res.getInt("tournee");
                                ordre=res.getInt("ordre");
                                categcode=res.getInt("categcode");
                                rolecode=res.getInt("rolecode");
                                reference=res.getInt("reference");
                                montant=res.getInt("montant");
                            else
               setetatfact("Pas de facture; parametres : faux ou inexistants");
            catch(Exception e)
    je veut utiliser les valeur des variables
    Dans une nouvelle classe du meme package
    package com.iris;
     * @author hedi
    @WebService()
    public class reglement_facture  {
        @WebMethod(operationName = "modifier_etat")
        public String modifier_etat() {
            return null;
    et plus precisement dans la methode "modifier_etat "
    que dois-je faire merci
    Juin 2009
    une solution consiste à écrire ta méthode modifier_etat en static et après tu fais un appel de l'autre fonction.
    ou alors tu créer une variable static dans ta classe newwebservice dans laquelle tu mets tes variables.
    Ce sont deux façons différentes et il en existe surement des meilleurs
  1. Probleme de ping dans dans le code java
    Par Bangura dans le forum API standards et tierces
    Dernier message: 01/10/2014, 10h52
  2. [andromda]Infos sur andromda, générateur de code JAVA
    Par ugos dans le forum EDI et Outils pour Java
    Dernier message: 08/09/2009, 16h30
  3. Probleme d'execution du code java
    Par betacrack dans le forum Langage
    Dernier message: 07/09/2006, 12h40
  4. Problème de génération du code java...
    Par nikalkal dans le forum Rational
    Dernier message: 21/04/2006, 15h32
