SWT/JFace Java Discussion :
[SWT] Shell problem
SWT/JFace Java
    Janvier 2009
    Par défaut [SWT] Shell problem
    je vais centrer un shell dans l'ecran ,j'éssaye avec SWT.CENTER mais j'ai pas reussie.Qui peut m'aider
    merci d'avant
    voilà le code
    public class ReviewerDialog extends Dialog {
        String name, mail;
         * @param parent
        public ReviewerDialog(Shell parent) {
            super(parent);
         * @param parent
         * @param style
        public ReviewerDialog(Shell parent, int style) {
            super(parent, style);
         * Makes the dialog visible.
         * @return
        public String open() {
        Shell parent = getParent();
            final Shell shell = new Shell(parent, SWT.TITLE | SWT.BORDER
                | SWT.APPLICATION_MODAL);
            shell.setText("Add reviewers");
            shell.setLayout(new GridLayout(2, true));
            Label label = new Label(shell, SWT.NULL);
            label.setText("Please enter a name:");
            final Text text = new Text(shell, SWT.SINGLE | SWT.BORDER);
            Label label2 = new Label(shell, SWT.NULL);
            label2.setText("please enter a mail:");
            final Text text2 = new Text(shell, SWT.SINGLE | SWT.BORDER);
            final Button buttonOK = new Button(shell, SWT.PUSH);
            buttonOK.setText("Ok");
            buttonOK.setLayoutData(new GridData(GridData.HORIZONTAL_ALIGN_END));
            Button buttonCancel = new Button(shell, SWT.PUSH);
            buttonCancel.setText("Cancel");
            text.addListener(SWT.Modify, new Listener() {
                public void handleEvent(Event event) {
                    try {
                        name = new String(text.getText());
                        mail = new String(text2.getText());
                        buttonOK.setEnabled(true);
                    } catch (Exception e) {
                        buttonOK.setEnabled(false);
            buttonOK.addListener(SWT.Selection, new Listener() {
                    shell.dispose();
            buttonCancel.addListener(SWT.Selection, new Listener() {
                    shell.dispose();
            shell.addListener(SWT.Traverse, new Listener() {
                    if (event.detail == SWT.TRAVERSE_ESCAPE)
                        event.doit = false;
            text.setText("");
            shell.pack();
            shell.open();
            Display display = parent.getDisplay();
            while (!shell.isDisposed()) {
                if (!display.readAndDispatch())
                    display.sleep();
            return name;
         public static void main(String[] args) { Shell shell = new Shell();
         ReviewerDialog dialog = new ReviewerDialog(shell);
         System.out.println(dialog.open()); }
    Chef de projet MOA
    Juin 2008
    Activité : Chef de projet MOA
    Si tu cherches a centrer un shell il faut récupérer la taille de l'écran et diviser par 2 pour centrer ton shell :
    Monitor primary = display.getPrimaryMonitor();
    Rectangle bounds = primary.getBounds();
    Rectangle rect = shell.getBounds();
    int x = bounds.x + (bounds.width - rect.width) / 2;
    int y = bounds.y + (bounds.height - rect.height) / 2;
    shell.setLocation(x, y);
    J'espère avoir répondu a ta question.
  1. [SWT] Shell sans boutons
    Par FranT dans le forum SWT/JFace
    Dernier message: 02/08/2006, 15h27
  2. [SWT] SWT shell et composite
    Par Rocket dans le forum SWT/JFace
    Dernier message: 26/03/2006, 13h08
  3. [SWT][IHM]Probleme d'affichage des icones
    Par barbu0055 dans le forum SWT/JFace
    Dernier message: 03/03/2006, 13h05
  4. Shell - Problème pour gérer les majuscules et minuscules
    Par claralavraie dans le forum Linux
    Dernier message: 11/01/2006, 18h17
  5. [SWT][Editeur] Probleme avec V4All
    Par hanane_iaai dans le forum Eclipse Java
    Dernier message: 06/02/2005, 10h17
