Voila je dois afficher les résultat de ma requête dans un dbgrid relier a un datacontrole mais rien ne s'affiche !!!!
12 Public Sub PROCEDURE_AFFICHE_DATE_COURS_ABSENCE(int_num_eleve As Integer) 'affiche les cours et dates des absences Dim str_req_sql_absence As String 'str_req_sql_absence = "SELECT Detail_absence_tbl.Date_absence, Absence_cours_tbl.Denomination_FROM Absence_cours_tbl INNER JOIN (Eleves_tbl INNER JOIN Detail_absence_tbl ON Eleves_tbl.Id_eleve = Detail_absence_tbl.Num_eleve) ON Absence_cours_tbl.Id_module = Detail_absence_tbl.Cours WHERE (((Detail_absence_tbl.Num_eleve) =" & str_num_eleve & "))" 'str_req_sql_absence = "SELECT Detail_absence_tbl.Date_absence, Absence_cours_tbl.Denomination_FROM Absence_cours_tbl INNER JOIN (Eleves_tbl INNER JOIN Detail_absence_tbl ON Eleves_tbl.Id_eleve = Detail_absence_tbl.Num_eleve) ON Absence_cours_tbl.Id_module = Detail_absence_tbl.Cours WHERE (((Detail_absence_tbl.Num_eleve) =" & "7" & "))" str_req_sql_absence = "SELECT Detail_absence_tbl.Date_absence, Absence_cours_tbl.Denomination FROM Absence_cours_tbl INNER JOIN (Eleves_tbl INNER JOIN Detail_absence_tbl ON Eleves_tbl.Id_eleve = Detail_absence_tbl.Num_eleve) ON Absence_cours_tbl.Id_module = Detail_absence_tbl.Cours WHERE (((Detail_absence_tbl.Num_eleve)=7))" MsgBox str_req_sql_absence data_sql_absence.RecordSource = str_req_sql_absence data_sql_absence.Refresh End Sub
Merci d'avance de votre aide
