1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26
| --------------------Configuration: plate_Forme - JDK version 1.3.1 <Default> - <Default>--------------------
Usage: java [-options] class [args...]
(to execute a class)
or java -jar [-options] jarfile [args...]
(to execute a jar file)
where options include:
-hotspot to select the "hotspot" VM
-server to select the "server" VM
-classic to select the "classic" VM
If present, the option to select the VM must be first.
The default VM is -hotspot.
-cp -classpath <directories and zip/jar files separated by ;>
set search path for application classes and resources
-D<name>=<value>
set a system property
-verbose[:class|gc|jni]
enable verbose output
-version print product version and exit
-showversion print product version and continue
-? -help print this help message
-X print help on non-standard options
Process completed.
