probleme JSplitpane et dimension
    Membre éclairé Avatar de L4BiN
    Juin 2006
    Par défaut probleme JSplitpane et dimension
    bonjour,
    J'ai une JInternalFrame qui contient une JSplitpane qui sépare avec une bar vertical, deux parties.
    Mais quand je redimensionne la fenetre, la split vertical ne reste pas à la position donnée (2/3 de la JinternalFrame).
    comme faire cela?
    			// Creation of the Sequence internal frame
    			JInternalFrame sequenceFrame = new JInternalFrame(
    					PasserelleIHMMessages.getString(
    							PasserelleIHMMessages.SEQUENCE_FRAME_NAME,
    							PasserelleIHMMessages.BUNDLE_NAME), false, false,
    					false, false);
    			sequenceFrame.setVisible(true);
    			JDesktopPane sequenceDesktopPane = new JDesktopPane();
    			sequenceDesktopPane.add(sequenceFrame);
    			try {
    				sequenceFrame.setMaximum(true);
    			} catch (PropertyVetoException e) {
    				e.printStackTrace();
    			// Add a tabbed pane to the sequence frame
    			sequenceFrame.setContentPane(getSequenceFrameTabbedPane());
    			// Creation of the trace frame
    			JInternalFrame traceFrame = new JInternalFrame(
    							PasserelleIHMMessages.TRACE_FRAME_NAME,
    					false, false);
    			traceFrame.setVisible(true);
    			JDesktopPane traceDesktopPane = new JDesktopPane();
    			traceDesktopPane.add(traceFrame);
    			try {
    				traceFrame.setMaximum(true);
    			traceFrame.setContentPane(getTracePanel());
    			JSplitPane splitPane = new JSplitPane(JSplitPane.HORIZONTAL_SPLIT,
    					sequenceDesktopPane, traceDesktopPane);
    			splitPane.setDividerLocation(Toolkit.getDefaultToolkit()
    					.getScreenSize().width * 2 / 3);
    			splitPane.setOneTouchExpandable(true);
    			mainInternalFrame = new JInternalFrame(PasserelleIHMMessages
    					.getString(PasserelleIHMMessages.MAIN_FRAME_NAME,
    					false, false);
    			mainInternalFrame.getContentPane().setLayout(new BorderLayout());
    			mainInternalFrame.setContentPane(splitPane);
    			mainInternalFrame.setJMenuBar(getMenuBar());
    			mainInternalFrame.setSize(Toolkit.getDefaultToolkit()
    					.getScreenSize().width, Toolkit.getDefaultToolkit()
    					.getScreenSize().height - 30);
    			mainInternalFrame.setVisible(true);
    			mainInternalFrame.validate();
    Directeur technique
    Janvier 2007
    Activité : Directeur technique
    Tu as essayé en relatif ?
    splitPane.setDividerLocation(0.66);
    Si ça ne fonctionne pas, c'est à priori que l'information donnée (2/3) n'est pas persistente, et qu'il faut mettre un listener sur ta fenetre qui au moment du redimensionnement refait l'operation setDividerLocation.
    P.S. : essai d'explication je n'ai jamais utilisé de SplitPane
    Juin 2006
    ca marche sauf que je suis obligé de cliqué sur la fenetre apres l'avoir redimensioné. Je voudrai que au fur et a mesure que je redimensionne la fenetre se redimensionne....
    Directeur technique
    Janvier 2007
    Hum ... La je sèche faudrait que je fasse des essais. Mais vu que je viens de changer de boulot et que j'ai même pas une jvm installée, ça risque d'être compliqué
    Juin 2006
    le tout est de savoir comment faire pour récupérer, au fur et a mesure que l'on modifie la taille de la fenetre, les dimension.
    Juin 2006
    en fait il faut utiliser sur le JSplitPane cette commande:
    splitPane.setResizeWeight(double value);
  1. [Langage] Probleme tableau 3 dimensions
    Par galadorn dans le forum Langage
    Dernier message: 16/11/2008, 12h09
  2. probleme avec les dimensions images dans ie
    Par cuisto44000 dans le forum Balisage (X)HTML et validation W3C
    Dernier message: 01/09/2008, 16h05
  3. probleme pour récupérer dimension de JPanel
    Par L4BiN dans le forum AWT/Swing
    Dernier message: 11/01/2007, 13h39
  4. Probleme tableau 2 dimensions
    Par EmilyRose dans le forum C++
    Dernier message: 09/10/2006, 19h20
  5. [Conception] problème tableau 2 dimensions
    Par Tootsi dans le forum Collection et Stream
    Dernier message: 24/01/2006, 19h55
