Tchat Python - stockage des messages
    Membre habitué
    Responsable des études
    Août 2022
    Activité : Responsable des études
    Par défaut Tchat Python - stockage des messages
    Je cogite sur un service de tchat pour une assoc, j'ai choisi Simplechat https://github.com/KetanSingh11/SimpleChatApp , et comme je ne suis pas très bon en Python, je bloque sur le moment où je voudrais stocker les messages échangés sur le Tchat, dans un ficher txt
    Le code du script :
    """ Script for Tkinter GUI chat client. """
    # Based on https://github.com/KetanSingh11/SimpleChatApp
    import tkinter
    from socket import AF_INET, socket, SOCK_STREAM, IPPROTO_TCP, TCP_NODELAY
    from threading import Thread
    def receive():
        """ Handles receiving of messages. """
        while True:
            try:
                msg = sock.recv(BUFSIZ).decode("utf8")
                if not msg:
                    print("Received empty data - closing connection\n")
                    break
                msg_list.insert(tkinter.END, msg)
                print("Received: ", msg)
            except Exception as e:  # Possibly client has left the chat.
                print("receive error\n", e)
                break
    def send(event=None):
        """ Handles sending of messages. """
        msg = my_msg.get()
        my_msg.set("")  # Clears input field.
        msg += "\n"
        sock.send(bytes(msg, "utf8"))
    def on_closing(event=None):
        """ This function is to be called when the window is closed. """
        sock.close()
        top.quit()
    top = tkinter.Tk()
    top.title("Simple Chat Client v1.0")
    messages_frame = tkinter.Frame(top)
    my_msg = tkinter.StringVar()  # For the messages to be sent.
    my_msg.set("")
    scrollbar = tkinter.Scrollbar(messages_frame)  # To navigate through past messages.
    msg_list = tkinter.Listbox(messages_frame, height=15, width=70, yscrollcommand=scrollbar.set)
    scrollbar.pack(side=tkinter.RIGHT, fill=tkinter.Y)
    msg_list.pack(side=tkinter.LEFT, fill=tkinter.BOTH)
    msg_list.pack()
    messages_frame.pack()
    button_label = tkinter.Label(top, text="Enter Message:")
    button_label.pack()
    entry_field = tkinter.Entry(top, textvariable=my_msg, foreground="Red")
    entry_field.bind("<Return>", send)
    entry_field.pack()
    send_button = tkinter.Button(top, text="Send", command=send)
    send_button.pack()
    quit_button = tkinter.Button(top, text="Quit", command=on_closing)
    quit_button.pack()
    top.protocol("WM_DELETE_WINDOW", on_closing)
    HOST = "127.0.0.1"
    PORT = 8878
    BUFSIZ = 1024
    ADDR = (HOST, PORT)
    sock = socket(AF_INET, SOCK_STREAM)
    sock.setsockopt(IPPROTO_TCP, TCP_NODELAY, 1)
    sock.connect(ADDR)
    receive_thread = Thread(target=receive)
    receive_thread.start()
    tkinter.mainloop()  # Starts GUI execution.
    Et ce que j'ai rajouté (#modif) dans def receive, mais lorsque je lance le script, il n'y a que le dernier message qui est écrit dans le TXT :
    def receive():
        while True:
            try:
                if not msg:
                    break
                with open('C:\\Users\\test-script.txt', mode='w') as file_object:   # modif
                 print(msg, file=file_object)                                                       # modif
                break
    j'ai du loupé quelque chose si vous aviez une idée pour m'aider à avancer merci !
    Nico
    Expert confirmé Avatar de papajoker
    Septembre 2013
    bonjour
    lire la doc de la fonction "open()" et en particulier son option "mode"
    Membre habitué
    Août 2022
    Merci papajoker, je vais regarder
    Membre habitué
    Août 2022
    mode='a'
    C'était tout simple .... mais quand on sait pas, bah on sait pas !
    Merci papajoker !
  1. [Python 3.X] Affichage des messages dans fenêtre cmd lors d'un éxecutable Python
    Par nivk-539 dans le forum Général Python
    Dernier message: 20/10/2020, 12h23
  2. [CKEditor] Stockage des messages
    Par Perceuse-Killer dans le forum Bibliothèques & Frameworks
    Dernier message: 25/05/2009, 12h35
  3. stockage des messages avec thunderbird
    Par jackk dans le forum Thunderbird
    Dernier message: 08/03/2009, 12h15
  4. Faites des messages corrects !!!
    Par Alacazam dans le forum C++
    Dernier message: 23/03/2006, 16h56
  5. Réponses: 3
    Dernier message: 11/06/2003, 01h18
