Salut
J'ai un petit soucis de dialogue entre l'arduino et python3
Le script python surveille mqtt a chaque message il active un switch controler par un MCP23017
En premier le prog arduino
27 #include "Adafruit_MCP23017.h" #include "Wire.h" Adafruit_MCP23017 mcp; void setup() { mcp.begin(); for (int pin = 0; pin < 16; pin ++) { mcp.pinMode(pin, OUTPUT); } for (int pin = 0; pin < 16; pin++) { mcp.digitalWrite(pin, HIGH); } Serial.begin(9600); } void loop() { if(Serial.available()) { String pinstr = Serial.readStringUntil(','); String commandestr = Serial.readStringUntil('\n'); int pin = pinstr.toInt(); Serial.print(pin); int commande = commandestr.toInt(); Serial.print(commande); mcp.digitalWrite(pin, commande);
avec ce programme en ligne de commande ca marche nikel
par contre quand je lance le script seul le pin 0 est activé ....
3 >>> ser=serial.Serial('/dev/ttyUSB0', 9600, timeout=1, writeTimeout=1) >>> ser.write(b'1,1') 3
62 import sys import queue import serial import time import threading from threading import * import paho.mqtt.client as mqtt import paho.mqtt.publish as publish class arduinocommande(threading.Thread): def __init__(self, commande,fin): threading.Thread.__init__(self) self.commande=commande self.terminated = fin def run(self): while self.terminated: try: ser = serial.Serial('/dev/tty-arduino', 9600, timeout=1, writeTimeout=1) time.sleep(6) print("connection ok") while ser.isOpen(): if not self.commande.empty(): com=str(self.commande.get())+"\n" print ("commande "+str(com)) com=bytes(com,'utf-8') ser.write(com) print (ser.readline()) print (ser.readline()) time.sleep(0.5) except: try:ser.close() except:pass print(sys.exc_info()) time.sleep(3) commande=queue.Queue() fin=True arduinocommande(commande,fin).start() def on_connect(client, userdata, flags, rc): print ("Connected with result code "+str(rc)) client.subscribe("filpilote") def on_message(client, userdata, msg): print(msg.payload) commande.put(str(msg.payload)) while True: try: client = mqtt.Client() client.on_connect = on_connect client.on_message = on_message client.connect("127.0.0.1", 1883, 60) client.loop_forever() except: print(sys.exc_info()) print ("Exception handled, reconnecting...\nDetail:\n%s") time.sleep(5) fin=False
Je lance la commande mqtt avec ce script
13 import sys import paho.mqtt.publish as publish import urllib2 print sys.argv channel=sys.argv[1] command=sys.argv[2] host=sys.argv[3] publish.single(channel,command, hostname=host)Un peu aide ?
Code : Sélectionner tout - Visualiser dans une fenêtre à part python mqttc.py filpilote 9,0 10.0.0.22
