J'ai un petit probleme,que je pense est lié a swing.
Le but,est de creer une fentre principal,avec a gauche,des ongletsqui sont en fait des jpanel,et ceux ci contiennent des Jcheckbox.
A droite(de la fenetre),je cree un jpanel,qui contient un bouton reset,
qui est sensé decoché tous les checkbox.
Mon idée etait de passer en parametre les references des differents onglets a l'objet panelstart ,et a partir de cet objet je decoche
tous les checkbox
Mais,j'obtient cela comme erreur:
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
at panelstart$ifield1.actionPerformed(panelstart.java:52)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
 probleme dans swing
 probleme dans swing
			 Envoyé par kalmless21
				 , alors regarde bien l'exception qui est levée :
