Bonjour à toutes et tous.
Je suis débutant sur VB6 et je souhaite faire tourner un programme qui refuse de démarrer alors que théoriquement tout devrait être OK...
Voici la partie du programme en question:
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
'Store some data types from draw module. If we moved them back to Draw module, VB reports a circular reference
Public Type drawPoint_t
    offset As vector_t
    projectedX As Double
    projectedY As Double
End Type
Public Type drawLine_t
    startPoint As Integer
    endPoint As Integer
    color As ColorConstants
End Type
' From here down we have the particle data types, constants, etc
Public Enum jointType_t
    gJointType_FrontLeft_c = 0
    gJointType_FrontRight_c = 1
    gJointType_Rear_c = 2
End Enum
Public Type particle_t
    posCenterMass As vector_t
    rotationAngle As vector_t
    velocity As vector_t
    acc As vector_t
    mass As Double
    sinRotAngle As vector_t
    cosRotAngle As vector_t
    ' Offsets of the front left, front right and rear joints
    flJointOffset As vector_t
    frJointOffset As vector_t
    ' Positions of the front left, front right and rear joints
    flJointPos As vector_t
    frJointPos As vector_t
    ' Information related to drawing
    drawPoints() As drawPoint_t
    drawLines() As drawLine_t
End Type
' Declare all parts of the truck
Public aParticleList(cTruckStructure_ParticleMax) As particle_t
Public Sub Particle_Init(P As particle_t)
    Vector_Reset P.posCenterMass
    Vector_Reset P.rotationAngle
    Vector_Reset P.velocity
    Vector_Reset P.acc
    P.sinRotAngle.X = 0
    P.cosRotAngle.X = 1
    P.sinRotAngle.Y = 0
    P.cosRotAngle.Y = 1
    P.sinRotAngle.Z = 0
    P.cosRotAngle.Z = 1
    'Resize array of drawable lines and points to 0
    ReDim P.drawLines(0)
    ReDim P.drawPoints(0)
End Sub
Public Sub Particle_SetJointOffsets(P As particle_t, frontJointsWidth As Double, frontJointsOffsetX As Double, rearJointOffsetX As Double, allJointsYOffset As Double)
    ' Set offsets for front left joint
    P.flJointOffset.X = frontJointsOffsetX
    P.flJointOffset.Y = allJointsYOffset
    P.flJointOffset.Z = -frontJointsWidth / 2
    ' Set offsets for front right joint
    P.frJointOffset.X = frontJointsOffsetX
    P.frJointOffset.Y = allJointsYOffset
    P.frJointOffset.Z = frontJointsWidth / 2
    ' Set offsets for rear joint
    P.rJointOffset.X = rearJointOffsetX
    P.rJointOffset.Y = allJointsYOffset
    P.rJointOffset.Z = 0
End Sub
Public Sub Particle_SetJointPosition(P As particle_t, joint As jointType_t, X As Double, Y As Double, Z As Double)
    Select Case joint
        Case gJointType_FrontLeft_c
            P.flJointPos.X = X
            P.flJointPos.Y = Y
            P.flJointPos.Z = Z
        Case gJointType_FrontRight_c
            P.frJointPos.X = X
            P.frJointPos.Y = Y
            P.frJointPos.Z = Z
        Case gJointType_Rear_c
            P.rJointPos.X = X
            P.rJointPos.Y = Y
            P.rJointPos.Z = Z
    End Select
End Sub
' Particle related private functions
Public Sub Particle_SetCenterMassPositionAndRotation(P As particle_t)
    Dim frontJointsY As Double
    Dim jointsLengthX As Double
    Dim frontJointsWidth As Double
    frontJointsY = (P.flJointPos.Y + P.frJointPos.Y) / 2
    frontJointsWidth = P.frJointOffset.Z - P.flJointOffset.Z
    jointsLengthX = P.rJointOffset.X - P.frJointOffset.X
    ' Compute rotation angle on z axis
    P.rotationAngle.Z = Atn((P.rJointPos.Y - frontJointsY) / jointsLengthX)
    ' Compute rotation angle on x axis
    P.rotationAngle.X = Atn((P.flJointPos.Y - P.frJointPos.Y) / frontJointsWidth)
    'store cos and sin
    P.sinRotAngle.X = Sin(P.rotationAngle.X)
    P.sinRotAngle.Z = Sin(P.rotationAngle.Z)
    P.cosRotAngle.X = Cos(P.rotationAngle.X)
    P.cosRotAngle.Z = Cos(P.rotationAngle.Z)
    ' compute position of center of mass
    P.posCenterMass.X = P.flJointPos.X - P.flJointOffset.X * P.cosRotAngle.Z + P.flJointOffset.Y * P.sinRotAngle.Z
    P.posCenterMass.Y = P.flJointPos.Y - P.flJointOffset.Y * P.cosRotAngle.Z - P.flJointOffset.X * P.sinRotAngle.Z + P.flJointOffset.Z * P.sinRotAngle.X
    P.posCenterMass.Z = P.flJointPos.Z - P.flJointOffset.Z * P.cosRotAngle.X - P.flJointOffset.Y * P.sinRotAngle.X
End Sub
Sub Particle_UpdateCabinPosition()
    On Error Resume Next
    Particle_SetJointPosition aParticleList(cTruckStructure_ParticleCabin), gJointType_FrontLeft_c, dampedSpringList(cDampedSpring_FlCabin).basePos.pos.X, dampedSpringList(cDampedSpring_FlCabin).basePos.pos.Y + dampedSpringList(cDampedSpring_FlCabin).length / CSng(frmConfigurator.txtSpringMaxLength) * 0.6 * 100, dampedSpringList(cDampedSpring_FlCabin).basePos.pos.Z
    Particle_SetJointPosition aParticleList(cTruckStructure_ParticleCabin), gJointType_FrontRight_c, dampedSpringList(cDampedSpring_FrCabin).basePos.pos.X, dampedSpringList(cDampedSpring_FrCabin).basePos.pos.Y + dampedSpringList(cDampedSpring_FrCabin).length / CSng(frmConfigurator.txtSpringMaxLength) * 0.6 * 100, dampedSpringList(cDampedSpring_FrCabin).basePos.pos.Z
    Particle_SetJointPosition aParticleList(cTruckStructure_ParticleCabin), gJointType_Rear_c, dampedSpringList(cDampedSpring_RCabin).basePos.pos.X, dampedSpringList(cDampedSpring_RCabin).basePos.pos.Y + dampedSpringList(cDampedSpring_RCabin).length / CSng(frmConfigurator.txtSpringMaxLength) * 0.6 * 100, dampedSpringList(cDampedSpring_RCabin).basePos.pos.Z
    Particle_SetCenterMassPositionAndRotation aParticleList(cTruckStructure_ParticleCabin)
End Sub
L'erreur "constant expression required " revient constamment pour la ligne:
Quelqu'un peut-il m'aider à comprendre ce qu'il se passe?
Merci d'avance.
