Services Web Java Discussion :
[CXF / SOAP] Petit problème de configuration ?
Services Web Java
    Juin 2004
    Par défaut [CXF / SOAP] Petit problème de configuration ?
    J'essai de créé un web service soap en depuis un WSDL en utilsant maven et CXF 3.
    Mon POM est le suivant
    <project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
    	xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
    	<modelVersion>4.0.0</modelVersion>
    	<groupId>com.ocpp</groupId>
    	<artifactId>OCPP2RC2SupervisionSimulator</artifactId>
    	<version>0.0.1-SNAPSHOT</version>
    	<name>Supervision</name>
    	<packaging>jar</packaging>
    	<description>Simulated OCPP 2.0 RC2 Supervision</description>
    	<properties>
    		<jdk.version>1.7</jdk.version>
    		<cxf.version>3.0.4</cxf.version>
    		<jar.version>LATEST</jar.version>
    		<maven.version>3.2</maven.version>
    		<spring.version>LATEST</spring.version>
    	</properties>
    	<dependencies>
    		<dependency>
    			<groupId>org.apache.cxf</groupId>
    			<artifactId>cxf-rt-frontend-jaxws</artifactId>
    			<version>${cxf.version}</version>
    		</dependency>
    		<dependency>
    			<artifactId>cxf-rt-transports-http</artifactId>
    		</dependency>
    		<dependency>
    			<artifactId>cxf-rt-transports-http-jetty</artifactId>
    		</dependency>
    		<dependency>
    			<groupId>org.springframework</groupId>
    			<artifactId>spring-context</artifactId>
    			<version>${spring.version}</version>
    		</dependency>
    	</dependencies>
    	<build>
    		<plugins>
    			<plugin>
    				<groupId>org.apache.maven.plugins</groupId>
    				<artifactId>maven-compiler-plugin</artifactId>
    				<version>${maven.version}</version>
    				<configuration>
    					<source>${jdk.version}</source>
    					<target>${jdk.version}</target>
    				</configuration>
    			</plugin>
    			<plugin>
    				<artifactId>cxf-codegen-plugin</artifactId>
    				<executions>
    					<execution>
    						<id>generate-sources</id>
    						<phase>generate-sources</phase>
    						<configuration>
    							<wsdlRoot>${basedir}/src/main/resources/wsdl</wsdlRoot>
    							<wsdlOptions>
    								<wsdlOption>
    									<wsdl>${basedir}/src/main/resources/wsdl/OCPP_CentralSystemService_2.0.0.98.wsdl</wsdl>
    								</wsdlOption>
    							</wsdlOptions>
    						</configuration>
    						<goals>
    							<goal>wsdl2java</goal>
    						</goals>
    					</execution>
    				</executions>
    			</plugin>
    			<plugin>
    				<artifactId>maven-assembly-plugin</artifactId>
    				<executions>
    					<execution>
    						<phase>package</phase>
    						<goals>
    							<goal>single</goal>
    						</goals>
    					</execution>
    				</executions>
    				<configuration>
    					<descriptorRefs>
    						<descriptorRef>jar-with-dependencies</descriptorRef>
    					</descriptorRefs>
    					<archive>
    						<manifest>
    							<addClasspath>true</addClasspath>
    							<mainClass>com.ocpp.Supervision</mainClass>
    						</manifest>
    					</archive>
    				</configuration>
    			</plugin>
    		</plugins>
    	</build>
    </project>
    La compile et le packaging se passent bien, si je lance le serveur depuis eclipse je n'ai pas de problème, par contre si je lance mon serveur depuis le shell...
    INFO: Loading XML bean definitions from class path resource [cxf.xml]
    Mar 13, 2015 10:52:52 AM org.apache.cxf.bus.spring.ControlledValidationXmlBeanDefinitionReader warning
    WARNING: Ignored XML validation warning
    org.xml.sax.SAXParseException; lineNumber: 3; columnNumber: 134; schema_reference.4: Failed to read schema document 'http://www.springframework.org/schema/beans/spring-beans.xsd', because 1) could not find the document; 2) the document could not be read; 3) the root element of the document is not <xsd:schema>.
    	at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(ErrorHandlerWrapper.java:198)
    Du coup j'ai deux questions :
    1. Pourquoi CXF essai de télécharger le xsd, j'avas cru comprendre que ces fichiers étaient embarqués dans les jar en dépendance ?
    2. Comment faire fonctionner mon serveur et en stan alone,qu'il n'ai pas besoin de télécharger des choses sur le réseau pour démarrer ?
    Juin 2004
    Par défaut Re : [CXF] [SOAP] Petit problème de configuration
    J'ai changé d'angl d'approche, je suis repartit sur l'exemple fourni avec CXF et je me retrouve avec un nouveau roblème.
    Le serveur se lance correctement, mais malgré le fait que tout le WSDL soit écrit avec uniquement des balises sopa12, je me retrouve avec des messages soap 1.1
    Quelq'un sait il comment, en passanr par le pom.xml dire à CXF de faire su soap 1.2 et pas du 1.1 ?
  1. [Tcomport] et un petit problème de configuration
    Par SergioMaster dans le forum Composants VCL
    Dernier message: 26/02/2012, 09h33
  2. [Dual boot] petit problême de configuration
    Par Muesko dans le forum Administration système
    Dernier message: 16/11/2008, 12h17
  3. [Configuration] petit problème avec php.ini pour la fonction mail()
    Par momoh dans le forum EDI, CMS, Outils, Scripts et API
    Dernier message: 06/04/2007, 02h39
  4. [Log4j]petit problème de configuration
    Par mikey_ufc dans le forum Eclipse Java
    Dernier message: 10/01/2005, 00h32
  5. Problème de configuration
    Par lsdInside dans le forum PostgreSQL
    Dernier message: 09/10/2003, 13h34
