avec Java Discussion :
getValueAt(int, int) compilation problem
avec Java
    Juillet 2008
    Par défaut getValueAt(int, int) compilation problem
    bonjour
    En compilant mon prg,ce dernier m'annonce ce message
    Exception in thread "AWT-EventQueue-0" java.lang.Error: Unresolved compilation problem:
    The type Fenetre.ZModel must implement the inherited abstract method TableModel.getValueAt(int, int)
    pourriez vous m'aidez svp
    119
    120
    121
    122
    import java.awt.Component;
    import javax.swing.JButton;
    import javax.swing.JTable;
    import javax.swing.table.DefaultTableCellRenderer;
    public class TableCompnent extends DefaultTableCellRenderer
     public Component getTableCellRendererComponent(JTable table,Object value,boolean isSelected,boolean hasFocus,int row,int column)
    	 if(value instanceof JButton)
    		 return(JButton)value;
    	 else
    		 return this;
    import java.awt.BorderLayout;
    import javax.swing.JFrame;
    import javax.swing.JScrollPane;
    import javax.swing.table.AbstractTableModel;
    import javax.swing.table.TableModel;
    public class Fenetre extends JFrame
    	 private JTable tableau;
    	 private JButton change = new JButton("Changer la taille");
    	private Object[][] data;
    	 public Fenetre()
    	 this.setLocationRelativeTo(null);
    	 this.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
    	 this.setTitle("JTable");
    	 this.setSize(600, 140);
    	 Object[][] data =
    	  {"Cysboy", new JButton("6boy"),new Double(1.80),new Boolean(true)},
    	  {"BZHHydde",new JButton("BZH"),new Double(1.78),new Boolean(false)},
    	  {"IamBow",new JButton("Bon"),new Double(1.90),new Boolean(false)},
    	  {"FunMan", new JButton("Year"),new Double(1.85),new Boolean(true)}
    	 String  title[] = {"Pseudo", "Age", "Taille","OK?"};
    	 ZModel model=new ZModel(data,title);
    	 System.out.println("Nombre de colonne:"+model.getColumnCount());
    	 System.out.println("Nombre de ligne:"+model.getRowCount());
    	 this.tableau = new JTable((TableModel) model);
    	 this.getContentPane().add(new JScrollPane(tableau), BorderLayout.CENTER);
    	class ZModel extends AbstractTableModel
    	 private Object[][]data;
    	 private String[]title;
    	 /*Constructeur
    	 * @param data
    	 * @param title
    	 public ZModel(Object[][]data,String[]title)
    	  this.data=data;
    	  this.title=title;
    	 /*Retourne le nombre de colonnes */
    	 public int getColumnCount()
    	  return this.title.length;
    	 /* Retourne le nombre de lignes */
    	 public int getRowCount()
    	  return this.data.length;
    	 /* Retourne le titre de la colonne à l'indice spécifié */
    	 public String getColumnName(int col)
    	  return this.title[col];
    	/* Retourne la classe de la donnée de la colonne*/
    	public Class getColumnClass(int col)
    		return this.data[0][col].getClass();
    	/* Retourne vrai si la cellule éditable:celle-ci sera donc éditable
    	 * @return boolean
    	public boolean isCellEditable(int row,int col)
    		if(getValueAt(0,col)instanceof JButton)
    		return false;
    		return true;
    	 /* Retourne la valeur à l'emplacement spécifié*/
    	 public Object getValueAt(int row,int col)
    	  return this.data[row][col];
    	 public static void main(String[]args)
    	  Fenetre fen=new Fenetre();
    	  fen.setVisible(true);
    Septembre 2004
    Pourrais-tu nous expliquer, en français et avec tes mots à toi, ce que dit ce message d'erreur ?
    Juillet 2008
    je crois que j'ai trouvé mon erreur
    Septembre 2004
    C'est bien. Nous ne sommes pas tes valets. Réponds à ma question.
    Juillet 2008
    merci maitre,j'ai corrigé mon erreur,
    merci beaucoup
    Septembre 2004
    Ça suffit pas. Tu n'arrêtes pas de poser des questions de ce genre.
    Tu dois chercher à progresser pour apprendre de tes erreurs, donc :
    Juillet 2008
    voilà, pb est venu de mon import, je l'ai corrigé
    maintenant mon prg marche impeccable,
    excusez moi pour le dérangement;
    merci beaucoup
  1. Réponses: 7
    Dernier message: 14/03/2014, 22h50
  2. int == int probleme
    Par lrgtk dans le forum Débuter
    Dernier message: 30/08/2010, 15h18
  3. [caml light] ( int -> int ) -> int
    Par ylarvor dans le forum Caml
    Dernier message: 26/11/2009, 20h35
  4. problème JTable getValueAt(int,int)
    Par trin86 dans le forum Composants
    Dernier message: 16/02/2009, 20h29
  5. Réponses: 1
    Dernier message: 11/06/2004, 12h58
