avec Java Discussion :
Problème d'exécution d'une classe
avec Java
    Mars 2011
    Par défaut Problème d'exécution d'une classe
    Je ne parviens pas à exécuter ma classe.
    Voici mon code
    119
    120
    121
    package mini.projet.GWI;
    import java.util.List;
     * @author jaafar
    public class ScanIP extends javax.swing.JFrame {
         * Creates new form ScanIP
        public ScanIP() {
              AgentSnmp snmp = new AgentSnmp("");
            List<String> a = snmp.getIp();
            for (String s : a) {
                jComboBox1.addItem(s);
            initComponents();
         * This method is called from within the constructor to initialize the form.
         * WARNING: Do NOT modify this code. The content of this method is always
         * regenerated by the Form Editor.
        @SuppressWarnings("unchecked")
        // <editor-fold defaultstate="collapsed" desc="Generated Code">
        private void initComponents() {
            jComboBox1 = new javax.swing.JComboBox();
            jButton1 = new javax.swing.JButton();
            setDefaultCloseOperation(javax.swing.WindowConstants.EXIT_ON_CLOSE);
            jComboBox1.setModel(new javax.swing.DefaultComboBoxModel(new String[] { " " }));
            jComboBox1.addActionListener(new java.awt.event.ActionListener() {
                public void actionPerformed(java.awt.event.ActionEvent evt) {
                    jComboBox1ActionPerformed(evt);
            jButton1.setText("jButton1");
            jButton1.addActionListener(new java.awt.event.ActionListener() {
                    jButton1ActionPerformed(evt);
            javax.swing.GroupLayout layout = new javax.swing.GroupLayout(getContentPane());
            getContentPane().setLayout(layout);
            layout.setHorizontalGroup(
                layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
                .addGroup(layout.createSequentialGroup()
                    .addGap(56, 56, 56)
                    .addComponent(jComboBox1, javax.swing.GroupLayout.PREFERRED_SIZE, 95, javax.swing.GroupLayout.PREFERRED_SIZE)
                    .addPreferredGap(javax.swing.LayoutStyle.ComponentPlacement.RELATED, 140, Short.MAX_VALUE)
                    .addComponent(jButton1)
                    .addGap(36, 36, 36))
            layout.setVerticalGroup(
                    .addGap(44, 44, 44)
                    .addGroup(layout.createParallelGroup(javax.swing.GroupLayout.Alignment.BASELINE)
                        .addComponent(jComboBox1, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
                        .addComponent(jButton1))
                    .addContainerGap(233, Short.MAX_VALUE))
            pack();
        }// </editor-fold>
        private void jComboBox1ActionPerformed(java.awt.event.ActionEvent evt) {
        private void jButton1ActionPerformed(java.awt.event.ActionEvent evt) {
            Scan s = new Scan(jComboBox1.getSelectedItem().toString());
            s.setVisible(true);
         * @param args the command line arguments
        public static void main(String args[]) {
            /* Set the Nimbus look and feel */
            //<editor-fold defaultstate="collapsed" desc=" Look and feel setting code (optional) ">
            /* If Nimbus (introduced in Java SE 6) is not available, stay with the default look and feel.
             * For details see http://download.oracle.com/javase/tutorial/uiswing/lookandfeel/plaf.html
            try {
                for (javax.swing.UIManager.LookAndFeelInfo info : javax.swing.UIManager.getInstalledLookAndFeels()) {
                    if ("Nimbus".equals(info.getName())) {
                        javax.swing.UIManager.setLookAndFeel(info.getClassName());
                        break;
            } catch (ClassNotFoundException ex) {
                java.util.logging.Logger.getLogger(ScanIP.class.getName()).log(java.util.logging.Level.SEVERE, null, ex);
            } catch (InstantiationException ex) {
            } catch (IllegalAccessException ex) {
            } catch (javax.swing.UnsupportedLookAndFeelException ex) {
            //</editor-fold>
            /* Create and display the form */
            java.awt.EventQueue.invokeLater(new Runnable() {
                public void run() {
                    new ScanIP().setVisible(true);
        // Variables declaration - do not modify
        private javax.swing.JButton jButton1;
        private javax.swing.JComboBox jComboBox1;
        // End of variables declaration
    L'appel de méthode getIp()
    public List<String> getIp(){
        List<String> liste = new ArrayList<String>();
            for (int i=0;i<255;i++) {
                    for(int j=0;j<255;j++){
                    String address = "192.168."+i+"."+j;
                    if(ping(address))
                        liste.add(address);
                    String address = "172.16."+i+"."+j;
                    if(ping(address))
                        liste.add(address);
            return liste;
    Quelqu'un saurait-il m'indiquer d'où peut venir le problème ?
    Avatar de wax78
    R&D - Palefrenier programmeur
    Août 2006
    On ne saura rien faire de ton code, il manque plusieurs bout me semble-t-il.
    De plus tu dis que ca ne s'exécute pas, mais as tu une erreur a l'exécution, compilation ou autres parce que la ca va être difficile de t'aider.
    Mars 2011
    Citation Envoyé par wax78 Voir le message
    Le problème est que ma classe ne se lance pas et aucun message d'erreur ne s'affiche.
    Avatar de tchize_
    Avril 2007
    tu fait un ping sur plus de 200 adresses dans le constructeur de ta fen^tre. Quelque chose me dit que tu va mettre plus de 10 minutes à faire tous ces pings. => tu n'attends pas assez longtemps de voir ta fenêtre arriver.
    Affiche ta fanêtre, fait tes pings après, et pas dans le thread de swing s'il te plaît.
  1. Réponses: 4
    Dernier message: 02/06/2006, 17h30
  2. [Système] problème d'exécution d'une boucle
    Par WalidNat dans le forum Langage
    Dernier message: 02/04/2006, 01h55
  3. [VB]Problème d'exécution d'une commande dos...
    Par Empty_body dans le forum VB 6 et antérieur
    Réponses: 21
    Dernier message: 17/02/2006, 13h28
  4. Problème de construction d'une classe
    Par AraBorLeg dans le forum Langage
    Dernier message: 05/12/2005, 20h07
  5. Réponses: 12
    Dernier message: 01/07/2004, 12h03
