Services Web Java Discussion :
From Element to SOAP Envelope
Services Web Java
    Membre habitué
    Janvier 2012
    Par défaut From Element to SOAP Envelope
    Bjr,
    Mon soucis concerne la récupération du soap envelope d'un dom document. J'ai écrit la classe suivante:
    public static SOAPEnvelope getSOAPEnvelopeFromDOMDocument(Document doc, boolean useDoom)
    throws WSSecurityException {
    Element documentElement = doc.getDocumentElement();
    if (documentElement instanceof SOAPEnvelope) {
    SOAPEnvelope env = (SOAPEnvelope)documentElement;
    // If the DOM tree already implements the Axiom API and the corresponding
    // Axiom implementation is also used as default implementation, then just return
    // the SOAPEnvelope directly. Note that this will never be the case for DOOM,
    // but may be the case for a non standard Axiom implementation.
    if (env.getOMFactory().getMetaFactory() == OMAbstractFactory.getMetaFactory()) {
    return env;
    if(useDoom) {
    try {
    //Get processed headers
    SOAPEnvelope env = (SOAPEnvelope)doc.getDocumentElement();
    ArrayList processedHeaderQNames = new ArrayList();
    SOAPHeader soapHeader = env.getHeader();
    if(soapHeader != null) {
    Iterator headerBlocs = soapHeader.getChildElements();
    while (headerBlocs.hasNext()) {
    OMElement element = (OMElement)headerBlocs.next();
    SOAPHeaderBlock header = null;
    if (element instanceof SOAPHeaderBlock) {
    header = (SOAPHeaderBlock) element;
    // If a header block is not an instance of SOAPHeaderBlock, it means that
    // it is a header we have added in rampart eg. EncryptedHeader and should
    // be converted to SOAPHeaderBlock for processing
    } else {
    header = soapHeader.addHeaderBlock(element.getLocalName(), element.getNamespace());
    Iterator attrIter = element.getAllAttributes();
    while (attrIter.hasNext()) {
    OMAttribute attr = (OMAttribute)attrIter.next();
    header.addAttribute(attr.getLocalName(), attr.getAttributeValue(), attr.getNamespace());
    Iterator nsIter = element.getAllDeclaredNamespaces();
    while (nsIter.hasNext()) {
    OMNamespace ns = (OMNamespace) nsIter.next();
    header.declareNamespace(ns);
    // retrieve all child nodes (including any text nodes)
    // and re-attach to header block
    Iterator children = element.getChildren();
    while (children.hasNext()) {
    OMNode child = (OMNode)children.next();
    children.remove();
    header.addChild(child);
    headerBlocs.remove();
    soapHeader.build();
    header.setProcessed();
    if(header.isProcessed()) {
    processedHeaderQNames.add(element.getQName());
    XMLStreamReader reader = ((OMElement) doc.getDocumentElement())
    .getXMLStreamReader();
    SOAPModelBuilder stAXSOAPModelBuilder = OMXMLBuilderFactory.createStAXSOAPModelBuilder(
    reader);
    SOAPEnvelope envelope = stAXSOAPModelBuilder.getSOAPEnvelope();
    //Set the processed flag of the processed headers
    SOAPHeader header = envelope.getHeader();
    for (Iterator iter = processedHeaderQNames.iterator(); iter
    .hasNext();) {
    QName name = (QName) iter.next();
    Iterator omKids = header.getChildrenWithName(name);
    if(omKids.hasNext()) {
    ((SOAPHeaderBlock)omKids.next()).setProcessed();
    envelope.build();
    return envelope;
    } catch (FactoryConfigurationError e) {
    throw new WSSecurityException(e.getMessage());
    } else {
    try {
    ByteArrayOutputStream os = new ByteArrayOutputStream();
    XMLUtils.outputDOM(doc.getDocumentElement(), os, true);
    ByteArrayInputStream bais = new ByteArrayInputStream(os.toByteArray());
    SOAPModelBuilder stAXSOAPModelBuilder = OMXMLBuilderFactory.createSOAPModelBuilder(bais, null);
    return stAXSOAPModelBuilder.getSOAPEnvelope();
    } catch (Exception e) {
    J'ai une erreur lors du cast qui me dit:
    exception in thread "main" java.lang.ClassCastException: com.sun.org.apache.xerces.internal.dom.DeferredElementNSImpl cannot be cast to org.apache.axiom.soap.SOAPEnvelope
    Avatar de tchize_
    Avril 2007
    ligne 5, tu traite le cas où doc.getDocumentElement() est de type SOAPEnveloppe
    ligne 16, tu est sorti du "if", tu n'es donc plus nécessairement dans ce cas là, et ton message d'erreur t'indique que tu n'est pas dans ce cas là, tu as juste un objet xml standard.
    Tu ne peux pas assumer que doc.getDocumentElement() est de type SOAPEnveloppe, rien ne te le laisse supposer.
    Membre habitué
    Janvier 2012
    Merci pour ta réponse, et il n'y a pas de possibilité pour modifier un DOM en SOAPEnvelope j'en ai besoin dans mon travail
    Avatar de tchize_
    Avril 2007
    Citation Envoyé par hajer88 Voir le message
    Ben un DOM, c'est un DOM.
    Maintenant, je ne connais pas axiom, mais en 2 minute de lecture de la javadoc, on trouve la solution
    OMelement soapElement = OMXMLBuilderFactory.createOMBuilder(new DOMsource(elementRacineDOM)).getDocumentElement();
  1. Réponses: 0
    Dernier message: 12/02/2012, 13h27
  2. with-clause referenced two different from-clause elements
    Par VirageGroup dans le forum Hibernate
    Dernier message: 20/10/2009, 16h50
  3. Réponses: 0
    Dernier message: 19/08/2009, 13h12
  4. invalid extension element: "soap:body"
    Par sebkill dans le forum NetBeans
    Dernier message: 21/07/2009, 17h51
  5. [SOAP] simpleXML envelope
    Par sk8world dans le forum XML/XSL et SOAP
    Dernier message: 09/12/2005, 10h55
