avec Java Discussion :
[Hibernate] Problème de requête
avec Java
    Nouveau candidat au Club
    Développeur Java
    Avril 2012
    Activité : Développeur Java
    Par défaut [Hibernate] Problème de requête
    J'ai un problème avec l'exécution d'une requête avec Hibernate
    Hibernate: select this_.id as id0_, this_.nom as nom1_0_, this_.prenom as prenom1_0_, this_.age as age1_0_, this_.id_serv as id5_1_0_ from user this_
    org.hibernate.exception.SQLGrammarException: could not execute query
    at org.hibernate.exception.SQLStateConverter.convert(SQLStateConverter.java:59)
    at org.hibernate.exception.JDBCExceptionHelper.convert(JDBCExceptionHelper.java:43)
    at org.hibernate.loader.Loader.doList(Loader.java:1596)
    at org.hibernate.loader.Loader.list(Loader.java:1577)
    at org.hibernate.loader.criteria.CriteriaLoader.list(CriteriaLoader.java:111)
    at org.hibernate.impl.SessionImpl.list(SessionImpl.java:1322)
    at org.hibernate.impl.CriteriaImpl.list(CriteriaImpl.java:300)
    at com.formation.dao.userDAO.getUser(userDAO.java:63)
    at com.formation.metier.UserMetier.Recherche(UserMetier.java:54)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
    at java.lang.reflect.Method.invoke(Unknown Source)
    at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:292)
    at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:155)
    at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:122)
    at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:57)
    at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:144)
    at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:174)
    at $Proxy1.Recherche(Unknown Source)
    at com.formation.bean.UserBean.seekUser(UserBean.java:234)
    at com.sun.faces.el.MethodBindingImpl.invoke(MethodBindingImpl.java:126)
    at com.sun.faces.application.ActionListenerImpl.processAction(ActionListenerImpl.java:72)
    at javax.faces.component.UICommand.broadcast(UICommand.java:312)
    at javax.faces.component.UIViewRoot.broadcastEvents(UIViewRoot.java:267)
    at javax.faces.component.UIViewRoot.processApplication(UIViewRoot.java:381)
    at com.sun.faces.lifecycle.InvokeApplicationPhase.execute(InvokeApplicationPhase.java:75)
    at com.sun.faces.lifecycle.LifecycleImpl.phase(LifecycleImpl.java:200)
    at com.sun.faces.lifecycle.LifecycleImpl.execute(LifecycleImpl.java:90)
    at javax.faces.webapp.FacesServlet.service(FacesServlet.java:197)
    at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
    at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
    at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
    at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
    at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
    at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
    at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
    at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
    at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:859)
    at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:602)
    at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
    at java.lang.Thread.run(Unknown Source)
    Caused by: org.postgresql.util.PSQLException: ERREUR: notation d'attribut .id appliqué au type name, qui n'est pas un type composé
    at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:1608)
    at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:1343)
    at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:194)
    at org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Statement.java:470)
    at org.postgresql.jdbc2.AbstractJdbc2Statement.executeWithFlags(AbstractJdbc2Statement.java:369)
    at org.postgresql.jdbc2.AbstractJdbc2Statement.executeQuery(AbstractJdbc2Statement.java:254)
    at org.hibernate.jdbc.AbstractBatcher.getResultSet(AbstractBatcher.java:120)
    at org.hibernate.loader.Loader.getResultSet(Loader.java:1272)
    at org.hibernate.loader.Loader.doQuery(Loader.java:391)
    at org.hibernate.loader.Loader.doQueryAndInitializeNonLazyCollections(Loader.java:218)
    at org.hibernate.loader.Loader.doList(Loader.java:1593)
    ... 43 more
    ... 43 more
    ... 43 more
    Quelqu'un saurait-il m'expliquer d'où peut venir le problème ?
    Membre confirmé Avatar de dark.jabberwock
    Décembre 2009
    En tout premier lieu avez-vous déjà essayé d'exécuter la requête généré sur PostgreSQL directement avec un outil tel que PgAdmin ? Si oui quel est le résultat ? Semble-t-il correct ?
    D'autre part, pourriez-vous fournir le code correspondant à la méthode de création puis d'exécution de la requête ainsi que le mapping de la table (annotation ou hbm.xml selon les cas).
  1. [Hibernate][proxy] Problème exécution requêtes update et remove
    Par amadoulamine1 dans le forum Hibernate
    Dernier message: 08/07/2011, 13h18
  2. Problème de requête (Hibernate sous NetBeans )
    Par meryam123 dans le forum NetBeans
    Dernier message: 02/07/2011, 13h33
  3. Problème de requête sur une vue Hibernate
    Par littlebear dans le forum Hibernate
    Réponses: 16
    Dernier message: 05/01/2009, 15h48
  4. problème syntaxe requête select Hibernate
    Par Staron dans le forum Hibernate
    Dernier message: 22/05/2006, 17h54
  5. [STRUTS/HIBERNATE] Problème d'exécution de requête
    Par mc_chicken dans le forum Hibernate
    Dernier message: 21/10/2005, 10h27
