Problème avec JScrollPane
    Avril 2007
    Par défaut Problème avec JScrollPane
    bonjour tout le monde
    j'ai un problème avec jtable et jScrollPane
    je n'arrive pas à coloré jScrollPane avec couleur
             import javax.swing.SwingUtilities;
    import javax.swing.JPanel;
    import javax.swing.JFrame;
    import java.awt.Rectangle;
    import java.awt.Color;
    import java.awt.Dimension;
    import javax.swing.JScrollPane;
    import javax.swing.table.DefaultTableModel;
    import java.awt.Font;
    import javax.swing.JTable;
    public class test  extends JFrame {
    private static final long serialVersionUID = 1L;
    private JPanel jContentPane = null;
    DefaultTableModel tableModel;
    Object[][] donnees = {  {"","","","","",""}} ;
    String[] titreColonnes = {"nom", "prénom","adresse"};
    private JScrollPane jScrollPane = null;
    private JTable jTable = null;
    private JScrollPane getJScrollPane() {
    if (jScrollPane == null) {
    jScrollPane = new JScrollPane();
    jScrollPane.setBounds(new Rectangle(65, 101,350, 120));
    jScrollPane.setHorizontalScrollBarPolicy(JScrollPane.HORIZONTAL_SCROLLBAR_ALWAYS);
    jScrollPane.setVerticalScrollBarPolicy(JScrollPane.VERTICAL_SCROLLBAR_ALWAYS);
    jScrollPane.setBackground(Color.orange);
     jScrollPane.setBorder(null);
    jScrollPane.setFont(new Font("Dialog", Font.PLAIN, 12));
     jScrollPane.setViewportView(getJTable());
    jScrollPane.setForeground(Color.orange);
    return jScrollPane;
    private JTable getJTable() {
    if (jTable == null) {
    tableModel = new DefaultTableModel(donnees, titreColonnes);
    jTable = new JTable(tableModel)  {
    public boolean isCellEditable(int rowIndex, int vColIndex) {
    return false;
     jTable.setBackground(Color.orange);
    jTable.setIntercellSpacing(new Dimension(2, 1));
    jTable.setRowHeight(24);
    jTable.setFont(new Font("Arial", Font.PLAIN, 14));
    jTable.setAutoResizeMode(JTable.AUTO_RESIZE_OFF);
     jTable.getColumnModel().getColumn(0).setPreferredWidth(80);
     jTable.getColumnModel().getColumn(1).setPreferredWidth(80);
    jTable.getColumnModel().getColumn(2).setPreferredWidth(80);
    return jTable;
    SwingUtilities.invokeLater(new Runnable() {
    public void run() {
    test thisClass = new test();
    thisClass.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
    thisClass.setVisible(true);
    thisClass.setResizable (false);
    thisClass.setLocationRelativeTo(null);
    public test() {
    super();
    initialize();
    private void initialize() {
    this.setSize(580, 320);
    this.setBackground(new Color(0, 138, 255));
    this.setContentPane(getJContentPane());
    this.requestFocus();
    private JPanel getJContentPane() {
    if (jContentPane == null) {
    	jContentPane = new JPanel();
    	jContentPane.setLayout(null);
    	jContentPane.setBackground(new Color(0, 138, 255));
    	jContentPane.add(getJScrollPane(), null);
    	return jContentPane;
    Membre chevronné Avatar de billynirvana
    Architecte technique
    Décembre 2004
    Essaye avec ça peut être que ca va marcher.
    jScrollPane.getViewport().setBackground(Color.orange);
    Si cela ne marche pas essaye un truc du genre:
    for(Component c: jScrollPane.getComponents()) {
    			c.setBackground(Color.orange);
    ... mais ton utilisateur devra apprécier grandement la couleur orange ^^
    J'espère avoir pu t'aider
    Avril 2007
    merci
  1. Problème avec JScrollPane et Panel paint
    Par Sk3d4r dans le forum AWT/Swing
    Dernier message: 29/02/2008, 21h57
  2. Problème avec JScrollPane
    Par doons dans le forum AWT/Swing
    Dernier message: 23/11/2007, 12h09
  3. Problème avec JScrollPane
    Par zolotaya dans le forum AWT/Swing
    Dernier message: 17/07/2007, 21h06
  4. Problème avec jscrollpane
    Par mmb04 dans le forum AWT/Swing
    Dernier message: 11/05/2007, 14h51
  5. Problème avec JScrollPane et label
    Par gl0be dans le forum Agents de placement/Fenêtres
    Dernier message: 26/11/2004, 18h08
