Paramétres fonction def
    Etudiante
    Mai 2016
    Activité : Etudiante
    Par défaut Paramétres fonction def
    Dans mon programme je fais l'importation du module Adafuit_ADS1x15, j'utilise la fonction adc.read_adc()
    Lien de la bibliothéque: https://pypi.python.org/pypi/Adafruit-ADS1x15/1.0.1.
    Dans la fonction il est indiqué que l'on peut modifier le mode, ci-dessous une partie du code du module pour read-adc:
    def _read(self, mux, gain, data_rate, mode):
            """Perform an ADC read with the provided mux, gain, data_rate, and mode
            values.  Returns the signed integer result of the read.
            config = ADS1x15_CONFIG_OS_SINGLE  # Go out of power-down mode for conversion.
            # Specify mux value.
            config |= (mux & 0x07) << ADS1x15_CONFIG_MUX_OFFSET
            # Validate the passed in gain and then set it in the config.
            if gain not in ADS1x15_CONFIG_GAIN:
                raise ValueError('Gain must be one of: 2/3, 1, 2, 4, 8, 16')
            config |= ADS1x15_CONFIG_GAIN[gain]
            # Set the mode (continuous or single shot).
            config |= mode
            # Get the default data rate if none is specified (default differs between
            # ADS1015 and ADS1115).
            if data_rate is None:
                data_rate = self._data_rate_default()
            # Set the data rate (this is controlled by the subclass as it differs
            # between ADS1015 and ADS1115).
            config |= self._data_rate_config(data_rate)
            config |= ADS1x15_CONFIG_COMP_QUE_DISABLE  # Disble comparator mode.
            # Send the config value to start the ADC conversion.
            # Explicitly break the 16-bit value down to a big endian pair of bytes.
            self._device.writeList(ADS1x15_POINTER_CONFIG, [(config >> 8) & 0xFF, config & 0xFF])
            # Wait for the ADC sample to finish based on the sample rate plus a
            # small offset to be sure (0.1 millisecond).
            time.sleep(1.0/data_rate+0.0001)
            # Retrieve the result.
            result = self._device.readList(ADS1x15_POINTER_CONVERSION, 2)
            return self._conversion_value(result[1], result[0])
    Ainsi pour configurer le mode de lectrure de l'ADc (Single ou continus), j'ai mis:
    MODE= "SINGLE"
    adc.read_adc(1, gain=GAIN, mode=SINGLE)
    Mais j'obtiens comme message erreur: " Type error: read_adc() got an unexpected keyword argument mode"
    Comment indiquer dans la fonction que je souhaite avoir un mode Single?
    Merci pour votre aide.
    Architecte technique retraité
    Juin 2008
    La méthode read_adc s'écrit:
        def read_adc(self, channel, gain=1, data_rate=None):
            """Read a single ADC channel and return the ADC value as a signed integer
            result.  Channel must be a value within 0-3.
            assert 0 <= channel <= 3, 'Channel must be a value within 0-3!'
            # Perform a single shot read and set the mux value to the channel plus
            # the highest bit (bit 3) set.
            return self._read(channel + 0x04, gain, data_rate, ADS1x15_CONFIG_MODE_SINGLE)
    Elle n'accepte pas le paramètre mode mais appelle la méthode privée _read avec mode=ADS1x15_CONFIG_MODE_SINGLE.
    - W
    Architectures post-modernes.
    Etudiante
    Mai 2016
    Merci pour votre retour.
    J'ai modifier mon programme par:
    val = adc.read_adc(mode, 1, gain=GAIN)
    Mais j'obtiens toujours un messsage d'erreur:
    NameError: name 'ADS1x15_CONFIG_MODE_SINGLE' is not defined
    Et quand je fais:
    val = adc.read_adc( 1, gain=GAIN,mode)
    J'ai un message d'erreur de synthaxe: non keyword arg after keyword arg
    Comment résoudre cela?
    Juin 2008
    Citation Envoyé par Cerise22 Voir le message
    Il n'y a rien à résoudre: ".adc_read" lit déjà en single (voir mon post précédent).
    D'autant que ce que vous cherchez à faire (mal) ne sert à rien tant que vous n'aurez pas modifié la méthode .adc_read pour qu'elle gère un paramètre supplémentaire "mode" (dont elle n'aura que faire).
    - W
  1. Problème de paramètre fonction
    Par sone47 dans le forum MATLAB
    Dernier message: 31/01/2007, 21h39
  2. [VBA-E]paramètre fonction et tableau
    Par marsupilami34 dans le forum Macros et VBA Excel
    Dernier message: 08/01/2007, 10h56
  3. [C#] Paramètres fonctions
    Par Nico28 dans le forum Windows Forms
    Dernier message: 14/12/2006, 12h26
  4. Paramètres fonctions utilisation
    Par KinF dans le forum Algorithmes et structures de données
    Dernier message: 22/07/2006, 23h46
  5. Récupérer paramètre fonction
    Par masseur dans le forum Général JavaScript
    Réponses: 12
    Dernier message: 26/06/2006, 12h51
